Question about Sony PlayStation Portable (PSP) Console
Not turning ondespite good ac adapter and power cord I don't see orange light any solution?thanks
    Problem Solver:
  • 8 Answers
Changeyour ac adaptor or buy a new one the only solution. good luck
Posted on May 08, 2010
Emachine e730 won't turn on. Havit on power supply and the light is orange. Worked on it for a bit without charge and shut it down, went out, Came back tried to switch it on but nothing.
Hi
Remove the battery but leave the ac adapter power cord in if it still doesn't start
you have to eliminate the ac adapter power cord
try a different adapter power cord
25717659-m35oz4jvdfvvmght4a51n0jl-2-0.jpg if it still dosnt start but you have the orange light on
it could be the laptop power jack is faulty and has to be replaced
25717659-m35oz4jvdfvvmght4a51n0jl-2-1.jpg laptop power jack
i hope this helps
cheers
May 28, 2015 | Computers & Internet
Battery light blinking orange
1. Disconnect the AC power adapter cord, remove the battery, and hold the Power button for 30 seconds. This will discharge the notebooks system capacitors.
2. Connect the AC adapter to a working power outlet or surge protector and connect it to the notebook.
3. Press the Power button to turn on the notebook.
If that did not help, go to the HP Customer support and search for Troubleshooting Battery Power
May 12, 2014 | HEWLETT-PACKARD Computers & Internet
Laptop will not turn on
There are three possible reasons why it's acting like that.
1. Defective AC Adapter or Power cord
2. Defective Motherboard
3. Defective Battery
First off, you need to isolate the part which causing the issue. Please follow the following steps:
1. Remove the battery and use the power cord alone in powering up your computer. If it goes well, then you need to replace the battery. If no go, then try using a different known good outlet.
2. Check the AC Adapter (the box) if there's a light lit. If it's green, then it's should be working fine. If it's amber or nothing at all, then there's a problem with it. You might need to replace that.
3. If the AC ADapter looks good, then try to wiggle the cord so that you can check if the cord is properly connected to the computer. Usually, cords get loose and it causes problems. If it has this kind of problem, then you need to get a technician to check that for you because you might need to buy a new motherboard for that.
Please do the above simple steps, and let me know if anything happens. I hope this can solve the issue.
Dec 04, 2012 | Toshiba Satellite A100-S8111TD Notebook
Wont start up
Remove the battery and AC Adapter cord, and press and hold the power button for 30 seconds. Then, without replacing the battery try plugging in your AC Adapter to see if you get any love. If that doesn't work, remove the AC adapter, reset the board again, and this time hold the power button down as you plug in the AC Adapter cord. If you still don't get any lights, you could try removing your memory, reset the board, replace the memory, plug in the AC Adapter, and try one more time.
If all of this fails...you should take advice from experts,call at-http://www.vtechsquad.com
Sep 05, 2012 | Acer Aspire 7750G-6662 - Core i5 2.4 GHz -...
The light is flashing orange on adapter and no power to system when turned on
It is possible that there is some foreign particles inside one of the connectors. Since the power supply does come apart and also disconnects from the unit, you can try to clean it to see if it will sort out your problem. Here's what to try:
1. Disconnect the AC adapter from the wall and the console. Let it rest for a few hours so that you do not electrocute yourself.
2. Disconnect the wall power cord from the AC adapter brick. Check the connections on both ends to see if it needs to be cleaned.
3. Clean any ends of the adapter with alcohol solution (isopropyl, or "rubbing" alcohol). Make sure the connection to the console is clean as well. Allow to dry.
4. Reconnect all necessary parts and try your console again.
If that does not work, there could be another problem with power flow to the AC adapter or a problem with the adapter itself.
Feb 28, 2011 | Microsoft Xbox 360 Console
Advent N270 netbook will not charge. Orange light comes on initially then goes off. Also when I wiggle the plug into the laptop the light flashes on and intermittently.
It sounds like either a bad connection on the motherboard or a broken wire in the adapter making intermittent connection.
1. With the power adapter disconnected, do you have a power light? This would indicate the adapter is good and the plug is questionable.
2. Check your power adapter output with a multi-meter.(be sure to wiggle the wires around) If the power fluctuates, replace the plug.
3. If the power is solid, replace the motherboard connector.
Nov 22, 2010 | Intel Computers & Internet
I have dell c840. Suddenly only the left most light of the three lights gets orange when power is switched on and then there is no activity and screen remains blank. Bty light when plugged in also remain...
hello
shut down computer - unplug power cord from laptop - remove the battery from laptop - plug Ac adapter into computer and Ac outlet (wall)
turn on computer
if computer does not turn on, replace the AC adapter and cord - then place battery back into computer
plug in new Ac adapter and cord - recharge battery - if orange light stays on after 4-6 hours of charging battery, you need new battery as well - replace battery, charge it up and it should be fine
if you have attempted these steps before and no change occurs, then you may have issue with power connection in computer - locate a service centre to replace power connection on computer
Nov 07, 2010 | Dell Computers & Internet
My vaio will not turn on. The green light and
  1. turn off the computer
  2. disconnect the ac adapter and remove the battery
  3. reseat the RAM or memory
  4. press and hold down the power button for 7-10secs to release static electricity
  5. reconnect the battery and ac adapter
  6. try turning it on
if still no go, unit needs service
Feb 08, 2010 | Sony VAIO Notebook
DC in light flashes orange
You need to test the AC Adapter For Correct Power Flow-Through... Use A Multimeter (available at any Home Improvement Store)
If That Tests Good.....
You Will Need To Test The DC Jack (the port where your Charger Cord Plugs Into On The Laptop.....)
If An Incorrect Adapter Was Used, You Might Have Shorted Out The Motherboard..
Dec 01, 2009 | Toshiba Computers & Internet
Nintendo dslite wont turn on.tried charging it wit 3 different charges and it still wont charge
Ensure that you are properly recharging the battery.
1. Insert the small end of the adapter into the external extension connector (labeled "5.2V=IN") on the back of the Nintendo DS Lite, just next to the SLOT 1 Game Card opening.
2. Swing the prongs on the AC adapter until they lock into place, then insert it into a standard (120 volt) outlet.
The plug should be mounted vertically or on a floor outlet (such as a power strip).
3. Once the adapter is properly inserted, the unit will begin to charge (the orange charging light will display).
4. Once the DS Lite is fully charged, the orange charge light will go off.
Check the AC Adapter for damage (such as bent prongs or split wires). If you see damage to the AC Adapter, purchase a replacement from Nintendos Online Store.
Try plugging the AC Adapter into another wall outlet. Its possible the outlet is not working properly and has not been charging the Nintendo DS Lite.
If you are unable to get power to your Nintendo DS Lite, despite trying to properly recharge the unit, then your system will need to be repaired.
Nintendo offers convenient repairs, fast turnaround times and, for all systems repaired, a new one-year manufacturer's warranty.
Jul 14, 2008 | Nintendo DS Lite Console
Sony PlayStation Portable (PSP) Console Logo
112 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
