Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
I'm trying to separate the upper agitator from the lower to replace the dogs... won't come apart! Help?
  • 141 Answers
The agitator stem you will find the hole in that screw will be there it may Aline key type or bold type remove the bold and shake the agitator and try lift it will come easily
Posted on May 08, 2010
Agator doesn't work
Is this a whirlpool washer? The agitator dogs need to be replaced. Remove top cap on agitator, then plastic cover inside it, then remove bolt, then pull agitator off. Top can separate from bottom by standing on bottom and pulling up on upper. Go to Repairclinic.com to find agitator dogs.
Nov 19, 2011 | Whirlpool Washing Machines
Upper portion of Whirlpool agitator not turning
Your agitator dogs are worn out. Remove the agitator and seperate the upper section from the lower section. There are 4 small teardrop shaped pieces that are the agitator dogs. They have either come apart over time or at least the teeth have worn off them.
Post back with any questions. Please verify the model number. I couldn't pull up a parts list for it. I know the last digit should be a 0 (zero) instead of an o.
Thanks/Mike
Jan 07, 2008 | Washing Machines
Tip
Whirlpool: How to replace the dog kit of direct drive washers
How to replace the dog kit in agitator
To replace the dog kit in the agitator, remove the top cap/rinse dispenser and the inner bolt cover. Remove the 7/16" bolt and lift the agitator out of the washer. Separate the upper and lower pieces of the agitator and replace the dog kit inside the upper part of the agitator. Make sure the 4 pieces remain in place while putting the agitator back together.
on Feb 12, 2010 | Washing Machines
Agitator doesn't engage in roper AX5133 washing machine
Check these excellent youtube videos out I found while a surfin this here world wide web.
Old school washers:
Newer models:
May 29, 2010 | GE WWSR3090TWW
Replacing agitator dog ears
We provide free diagnostic information when you tell us what brand and model number you are having issues with.
We are available from 7 AM – 7 PM CST.
We also provide part removal/installation instructions for our customers when parts are purchased through us.
It is our goal to get you back up and running again ASAP, so please contact us when you need us to help you.
We look forward to hearing you and hope that you get your appliance problems resolved soon.
Thank you, Ella
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
Mar 09, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
How to remove agitator cam from the upper part of the agitator?
Had same problem with my washer. Check to see if there are little plastic tags holding top/bottom of agitator. after replacing dogs just ensure that you realign with tags so they do not break off.
Oct 10, 2009 | Whirlpool LSN1000LW Top Load Washer
Kenmore Series 80 Washer, Model 20852 - Agitator not turning well, making noise
Hi, If the washer spins properly but the agitator does not work, it could be the dog kit needs replaced. If the washer does not agitate or spin, it is probably the coupler.
Put the washer in wash cycle with no laundry in it and see if the lower prt of the agitator moves. If the agitator moves, try and hold the upper half of the agitator and see if it will only move one direction.The agitaor dog kit is designed to only let the top part of the agiator to grab one way. When they go bad, they can make some noise.
To replace the dog kit in the agitator, remove the top cap/rinse dispenser and the inner bolt cover. Remove the 7/16” bolt and lift the agitator out of the washer. Separate the 2 halfs of the agitator and replace the dog kit inside the upper part of the agitator.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Jul 17, 2009 | Washing Machines
How do I replace the dogs in a Kenmore Elite washer?
With a flat blade screwdriver or putty knife, remove the top cover from the agitator. Use pliers to pull out the inside plastic cover.Take a 7/16 socket on a extension and remove the nut .Pull the agitator out. It should separate. If it does not separate,stand on the lower half and forcefully pull up on the upper half.Remove the agitator dogs and spline gear from the upper agitator. Replace the dogs. Re-assemble the agitator. Wash clothes.
Jul 14, 2009 | Kenmore 15.5 in. Pedestal
One part of agitator moves the other part doesnt.
Two-Piece Agitator: Bottom Works, Top Does Not - Whirlpool brands
Some Whirlpool brands washing machines employ a two piece agitator. The bottom is call the agitator and the top is usually referred to a 'Mover'. A multi-piece cam and bearing assembly connects the two and allows the top portion to index.
If the bearing or cams become stripped or damaged, the mover will often not work. Fortunately, Whirlpool produces a cost effective agitator repair kit that replaces all of the critical components in this cam assembly. There are three different repair kits. They differ in the height of the cam.
Agitator Removal Instructions:
Remove Dispenser or Cap:
Some models of washing machines utilize a fabric softener dispenser that resides on top of the agitator. This dispenser simply snaps onto the top of the agitator. Other styles utilize a decorative cap. To remove the dispenser, simply grab it and firmly pull up. To remove the agitator cap, insert a small flat-head screw driver into the seam between the agitator cap and the upper agitator (mover). Use a twisting or prying action to pop the cap off of the agitator.
Remove Internal Debris Cap:
Inside the agitator you will see a cap with a raised handle, much like that of your automobile. Simply reach into the agitator and twist the cap while pulling up. This will remove the cap and its o-ring.
Remove Agitator Stud:
When looking into the agitator assembly, you will notice a single nut in the center of the agitator. Use a socket kit or nut driver to remove this bolt (agitator stud).
Remove the Upper Agitator (Mover):
With the bolt removed you should be able to remove the upper half of the agitator (mover) by simply pulling up. Sometimes pulling up will actually remove the whole agitator assembly. If this happens, place the Lower Agitator on the floor and stand on the flat lip. Then Pull up to separate the Upper Agitator (mover) from the Lower Agitator.
Remove the Cam and Clutch Dogs:
When you remove the upper agitator (mover) it contains the cam and clutch dogs. Tun the assembly upside down. The cam and dogs should then come out.
-- Stop Here if Replacing Cam Kit --
Remove O-ring:
The lower agitator remains on the transmission shaft. On the top of the agitator, there is an o-ring. Remove this o-ring.
Pull the Lower Agitator:
All that remains is the lower agitator. This can be removed by simply pulling straight up on the agitator.
Agitator Installation Instructions:
Set Lower Agitator:
Slide the lower agitator onto the transmission shaft. Rotate the lower agitator until the splines in the shaft match those in the agitator. Once aligned press the agitator down. Install the o-ring into the top of the lower agitator.
-- Start Here if Replacing Cam Kit --
Assemble Cam and Dogs:
Turn the cam upside down. Place the small round ear of the dog into the corresponding slot on the cam. Repeat this for each of the four cams.
Install Cam and Dogs into Upper Agitator:
Invert the Upper Agitator (mover) and slide the cam/dog assembly inside. The cam should be pushed into the mover until it shoulders. Then rotate the whole assembly upright.
Install the Upper Agitator (Mover) on the Lower Agitator:
The lower agitator has two tabs that stick up that are 180 degrees apart. These tabs fit into two slots on the bottom of the cam. Align the matching tabs and slots and place the Upper Agitator (mover) and cam assembly onto the lower agitator. Push down until the cam snaps onto the Lower Agitator. If the dogs fall out during this step it is necessary to return to the 'Assemble Cam and Dogs' section above and start over.
Install the Agitator Stud:
Place the bolt (agitator stud) into the hole in the bottom center of the cam. Use a socket kit or nut driver to tighten the bolt .
Install Internal Debris Cap:
Install the o-ring into the groove on the OD of the debris cap. With the o-ring in place, push the cap into the Upper Agitator (mover). It is important that the cap is pushed past the ports in the Upper Agitator (mover) so that the wash water can enter and exit as designed.
Install the Dispenser or Cap:
The final step is to replace the top cap. Both the cap and the dispenser simply snap into place. Just make sure they are installed as far down a they will go and are firmly in place.
Apr 07, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
No agitation
I have a Whirlpool Utlimate Care II LSQ8520JQ0. For those having a problem separating the upper and lower agitator halves, here's how I solved it after about 2 hrs of aggravation.
Called Sears and Whirlpool with no help (didn't have tech manual...go figure).
I saw the same post with the problem with melted hooks (I called them tabs) ontop of the dog housing being melted. You can differentiate the melted tabs from the dog housing as the dog housing is usually clear plastic (after wiping all the crud off) and the tabs are white as they are part of the agitator. There will be four white tabs on top of the dog housing. They look both smashed and melted. I took a flat head screw driver and and hammer and chipped off the white melted tabs visible on top. I inevitably also chipped some of the dog housing but only marginally. Once chipped off you'll see the tabs are actually rectangular in shape. At this point I EASILY pulled the top and lower halves apart. Those retangular tabs are the molded part of the agitator housing extending down past the dog housing. You're home free at this point.
It's the melted tabs on top of the dog housing that keeps you from separating the halves. What a pain but finally figured it out.
Oct 19, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
325 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
