Question about Whirlpool Duet GHW9150P Front Load Washer
Water left in machine (clothes dripping) after delicate cycle
When i run the washer on delicate or handwash, when the cycle is over and the machine indicates I can open the door, there is often a pool of water (several inches deep sometimes). Even if there isnt a pool of water, the clothes are often so wet that they are dripping wet as I remove them. I can improve this if I put more minutes on for wash time (or use the other more rigorous cycles) but the point of using these settings is I dont want to overwash/overspin my delicates and handwashables. A big reason I bought this particular machine was the ability to use settings for finer materials. What do you suggest?
  • 141 Answers
Whirlpool is best in the standards of top loading washing machine when you are going for the front loading you can buy the IFB washing machine to get the better result
Posted on May 08, 2010
Will not spin the water out of the clothes
call a repairman sounds like a controller problem or transmission not getting final rinse signal
Mar 15, 2015 | GE Profile PTWN6050MWT 27" Top-Load Washer...
Clothes too damp after spin cycle
Front loading washers are notorious for not spinning the water out of a small load of clothes. This is because there is not enough clothes in the washer to balance the tub during the spin cycle.
Try washing a slightly larger load with a minimum of six items or more. This is one of the downsides to front load models and no specific brand is immune to the problem.
Mar 17, 2013 | Washing Machines
The ultra Handwash & Delicate cycle leave the clothes soaking wet, how can I fix
You gonna think this is weird but I believe you might not have enough items in the washer. ebfcdfa.jpgYou might have to use a mesh bag or add a garment to get the machine to act right.897ed48.jpg If F-21 you gotta remove the bottom panel screws and panel and get the junk out the sump19223ec.jpg
Apr 19, 2010 | Kenmore 44072 Front Load Washer
Clothes remain dripping wet after the wash cycle is complete.
I assume you have removed the lint filter at the bottom of the machine and cleaned it out to make sure the pump is not stalled on a 1 pence or bra clip. Can you hear the motor start to spin? If not its probably because the water level switch is gunged up at the bottom of its rubber tube where it comes from the drum. Remove the top of the machine and locate the pressure switch - usually a round black or white device about 80 to 100mm across with a rubber pipe on a small spout 8mm diameter. Take the pipe clip off using pliers to compress it and move it back down the pipe. Remove the pipe and blow hard down the pipe to try and clear the blockage - you will hear bubbles blowing in the bottom of the drum water. Also you could very very gently blow into the switch stub pipe and listen for it changing over - clicks usually twice each way - blow - two clicks, release - two clicks. Restore swtch pipe and try the machine again. Good luck.
Apr 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
Steam cycle runs on every setting
The steam will only run on certain cycles. If you look at your dial you will see a pink line which indicates which one. Your unit does have a recirculatting pump, maybe you are confusing the two. One way to check is to run a delicate cycle. During the operation press the wash/rinse and soil level buttons together. Hold them, a display will pop up with readings in the second coloumn, and second row it will display the tempurature of the steam generator in ceilsus. This will confirm whether or not it is on.
Sgt. 48
May 29, 2008 | LG WM2688H Front Load Washer
Water
its probably normal as new machines now only put in enough water to saturate the clothes its only the rinse or wool/delicate cycles that use a higher water level
Mar 01, 2008 | GE Energy Star WCVH6260F Front Load Washer
No longer spinning/loud noise
Did all the standing water pump out?? If sou you may have broken a drive coupling
Jan 22, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Dial won't turn to delicate or handwash...
Is it brand new?? if it is the factory did not align the knob (dial assy) properly with the main computer, and on top of that all the cycles you think you are selecting really isnt that cycle at all!! It is two back from full left or right whichever way is not fully extending. It is quite frustrating for me to get it back right when i replace the main computer! The first one or two took me a while to get it right again. PLEASE rate my solution as solved if you feel I answered your question accurately. Thank you
Oct 02, 2007 | Frigidaire GLTF2940ES Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
233 people viewed this question
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
