Question about Toshiba DKT3020SD Corded Phone
How do you forward the phone to a cell number
  • Toshiba Master
  • 8,404 Answers
This is normally a service proviced by the telephone company ...
Posted on May 08, 2010
  • A Miller May 10, 2010
    Thanks for the 4 tumbs up ...
3 Suggested Answers
  • 16 Answers
SOURCE: how to I forward incoming calls on my phone to a cell phone 3?
Call forward, off-premise is available on the NEC Electra Professional phone system if you have the Level II system (metal cabinet, not plastic) and you have system software level 700 (7.00) or higher. To get your system software level, press <FNC> - 3 from any display telephone when idle. The procedure to forward is (with phone idle): press <FNC> - dial 60, dial trunk access code (usually - 9), dial telephone number, press <FNC>. Additionally, your station class must be set to allow this feature (by default it is not allowed) and you may need trunk-to-trunk capability turned on in system programming (which is also, by default, not allowed). Hope that all helps.
Posted on Dec 31, 2008
MaMa Jams
  • 94 Answers
SOURCE: Call forwarding
Your options are...
Option 1: Hit 7 then 2 then #. You'll hear an interrupted dial tone. Then dial the number you're forwarding to.
To cancel hit 7 then 3 then #.
Option 2: Hit * then 7 then 2. You'll hear an interrupted dial tone. Then dial the number you're forwarding to.
To cancel hit * then 7 then 2.
Posted on Jan 29, 2010
HOW TO CALL FORWARD TO CELL PHONE NUMBER
There are a couple of ways to achieve this.
First, press 355 on your phone to activate the call forward feature. Once it asks for a forward destination, press whatever number your company uses to dial an outside line. After that dial your number like normal and hang up the phone.This will forward all calls directly to your cell phone.
The second method is the same as the one listed above but it uses the feature code 356. 356 will forward calls if you do not answer from your Mitel phone first.
I hope this helps
Sep 03, 2014 | Mitel 5330 IP Phone
How to transfer main phone number to cell number
If the featured is enabled at the phone company, grab the main line, enter call forward code (maybe *72), get stutter tone, dial your cell number, hang up. In the morning cancel forwarding, access main line, dial cancel code ( maybe *73), hang up.
Apr 08, 2014 | AT&T 922 Corded Phone
How do I get my home phone number to ring on my cell phone while I am on vacation
It's called "call forwarding" and the procedure varies from company to company. With many, dial * 7 2 on your home phone, then at the second dial tone dial your cell phone number. Answer your cell phone when it rings to confirm the call forwarding. To cancel call forwarding when you return from vacation, dial * 7 3 on your home phone.
If the above doesn't work then contact your landline telephone company for their instructions regarding call forwarding.
Aug 01, 2013 | Computers & Internet
How do i forward text messages
      Create a new account with a third-party text message management client such as Google Voice, which is freeicon1.png to use. There is a link in the Resources section.
    • 2
      Set up your cell phone to synchronize with the online client. Create a new online number that you may use through your cell phone if necessary.
    • 3
      Add the numbers to additional phones. These numbers will automatically receive forwarded text messages when you receive them on your cell phone.
    • 4
      Add additional accounts if you prefer. Google Voice, for example, allows you to forward text messages to your emailicon1.png inbox.
      God bless you
Jan 30, 2013 | Cell Phones
Can I divert calls from this phone to another phone? Thanks MArk David
  • Figure out if your particular cell phone model has the option to forward incoming calls. You can do this by visiting your cell phone manufacturer's website or reading the manufacturer's manual that came along with the purchase.
  • Access the "Settings" menu on your cell phone and select "Phone Settings" menu.
  • Select the "Call Forwarding" option in the "Phone Settings menu. This option is usually found at the bottom of the "Phone Settings" menu. Selecting the "Call Forwarding" option gives you access to call-forwarding controls.
  • Switch on the "Call Forwarding" slider. The default position is off.
  • Insert the phone number you wish to forward your calls to in the "Forward To" field. This field most commonly lies below the "Call Forwarding" slider.
  • Exit the setup menu by pressing the home button. You may be asked to confirm/save the changed settings depending on your cell phone model.
  • Make a test phone call to the cell phone number on which you just enabled the call rerouting option. If the call is forwarded and received on the number you entered, it means that the "Call Forwarding" option has been activated.
  • Oct 08, 2010 | Panasonic Cell Phones
    How do you forward a text message you have recieved
    Follow the steps:
    1. Open the message, which you want to forward. 2. Highlight message to be forwarded. 3. Go to menu then select forward option. 4. Enter the number to which it should be forwarded. 5. Then send it.
    Jun 26, 2010 | HTC Tattoo Cell Phone
    How to block number on moto krzr k1
    it depends on your carrier (and most of them dont)...you register cell with the dont call registry (for telemakets) and you can also tried this trick for those unwanted (done with ex..) if you have all the numbers for this person (such as home, job, cell and etc.) forward the calls...forward their cell to their home) they call you from their cell (they be calling there home)...forward home to job numbers...forward job numbers to their mothers cell/home...you got the picture...it works like a charm the only way they get you is through an unknown number...
    Jun 14, 2010 | Motorola Mobility MOTOKRZR K1 Cellular...
    Call forward to cell phone
    Who provides your dial tone? You will have to find out their code for forwarding calls to a cell.
    SBC/AT&T/Ameritech uses #72, then dial the number you want to forward to
    Jan 01, 2009 | Panasonic KX T7235 Corded Phone
    My cell phone is not working and I want to forward my calls to my husbands cells. I have a Alltel Razor phone. How do I set up the call forwarding
    If your plan allows forwarding these are the steps
    to forward *72# XXX-XXX-XXXX (the number you want to forward to) send
    to unforward *720# send
    hope this helps
    Sep 04, 2008 | Cell Phones
    Call Forwarding
    tell her to dial *72 followed by your home phone number then press send on your cell phone. she will hear a stuttering dial tone. the calls are now being forwarded. when you get ypur cell phone, press *73 then send to deactivate the call forwarding.
    wg
    Feb 07, 2008 | LG VX-8700 Cellular Phone
    Toshiba DKT3020SD Corded Phone Logo
    180 people viewed this question
    Top Toshiba Lands Phones Experts
    Oloyede Monsuru
    JP Services
    JP Services
    Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
