Question about Canon PowerShot A430 Digital Camera
When I place the memory card in camera it says error memory card locked
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Posted on May 07, 2010
I am getting memory card error - card locked when I switch on my Canon SD 990. It was recently repaired by unauthorized dealer for switch on problem and then on I am facing this problem. I veirfied the...
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
Jul 04, 2011 | Canon PowerShot SD990 IS / Digital IXUS...
Memory card error it says card is locked I slid the switch back an forth but still says memory card
I'll include a diagram of the little lock switch so you know the correct position to be able to load pictures to it. Another reason for getting the card locked error is if the memory card hasn't been formatted in the camera it's being used in. Formatting is necessary after downloading pictures to the computer as well.
Diagram
Mar 02, 2011 | Canon Cameras
My camera says memory card error. I think the memory card is locked. I don't know what to do.
Cameras usually use words like "Locked" or "Protected" in error messages if it refers to the small "lock" slider on the memory card. "Memory Card Error" sounds like dirty contacts or a format or filesystem error.
This problem is so common that there's a whole blog about it here:
http://hubpages.com/hub/Canon_Powershot_Memory_Card_Error_Fix
You don't say if your camera is a Canon or not, but the principles will be the same nonetheless.
It seems that the camera gives this error when it has problems reading/writing the card. The fixes they suggest there are to do with cleaning the contacts. It's pretty easy to clean the contacts on the memory card, but much harder to clean the camera. I don't suggest following the instruction to spray cleaner into the slot... that sounds like a recipe for getting it all over the inside of the camera!
I would start by cleaning the memory card's contacts. You can either use a solvent such as Methyl Hydrate (US) (= Methylated Spirit (UK)) and a kitchen towel, or you can actually rub the contacts clean with an eraser (US) (= rubber (UK)). It's probably worth looking inside the camera too, to see if any of the contacts are obviously bent in the card slot. I've seen that in a Nintendo DS which is similar. If a contact is bent, nothing's going to work unless you can get it back in place.
Feb 01, 2011 | Cameras
Hello my camera doesnt accept hp 4gb sdhc card.when i placed card in, it says card error.... Also,i cant format when sd card is in and ''card error'' on screen...(my sd cards are brand new) plese give...
Okay we have a problem, to properly answer this question "we" collectively need to know what make and model the camera is. However one clue to your problem was that you said SDHC and 4gb.
I'm going to give you a diagram on the SD card type lock make sure it's in the correct position (not locked) Also the SDHC is a newer style memory card and 4 gig is a ton of memory for point and shoot cameras.
If the card lock thing doesn't work and you still can't format then I'm going to say that your camera can't handle the memory capacity of the 4gig SDHC memory card.
Don't panic yet, you may be able to go onto the camera manufactorers web site sift through the models and find the firmware updates for your camera. Updating to new firmware editions could open the possibilities of using a larger card.
Here is the diagram hope this is all that is needed.
Diagram
Jan 05, 2011 | Cameras
I place the card in the camera, close the door and turn the camera on. The message "card locked" appears on the screen and I cannot use the camera at all. How do I unlock the card?
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Oct 19, 2010 | Cameras
My canon camera keeps displaying 'memory card' error and 'memory locked', what do I do?
check you sd card there is lock and unlock switch. unlock that button
Aug 08, 2010 | Canon Cameras
The phone is saying card locked
there should be a little lock ontop of the memory card switch it to unlock and place it back in
Jul 12, 2009 | Casio Exilim EX-Z750 Digital Camera
Sd card won't stay in the slot of my nikon coolpix S210
See fix 4 http://camerarepair.blogspot.com/2009/07/simple-fix-for-memory-card-locked-error.html?m=1
Jan 16, 2009 | Nikon Coolpix S210 Digital Camera
Canon Camera - Memory Card error & Card locked error
Try reading the card independent of a camera i.e. on a computer or a photo kiosk to determine if the card is readable damaged
Jan 07, 2008 | Canon PowerShot A410 Digital Camera
Canon PowerShot A430 Digital Camera Logo
147 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
