Question about Dryers
Dryer not heating
Dryer spins the timer works but it wont heat i didnt see the heat elemnt come on when i open the door and push the button in on the door latch and wath it spin is it the thermostat or the coil its a kenmore model# 11066662501
  • 185 Answers
Is this a gas or electric
Posted on Mar 27, 2008
I have a MEDC400VWG drier.Woked fine yesterday. Put clothes in it today. Pushed start button. nothing happened. Smelled somthing getting hot. opened drier. Heating coils lit up. (with door open). Turned...
Sounds as if the motor centrifugal switch is stuck. Check to see if lint built up around switch or centrifugal mechanism on motor shaft. Rap switch with the handle of a screw driver hard but don't break it .
Nov 01, 2010 | Maytag PYE3300 Dryer
When dryer is started the timer can be heard and if the door switch is activated, the heating element will heat, but the drive motor does nothing. belt is ok
try holding the door button, have someone push the start button and you spin the tub at the same time. If it starts, it is most likely the start capacitor on the motor. If it does not start, look at door button, start switch/button, and lastly, the timer.
May 01, 2010 | Whirlpool ET8CHEXSQ Dryer
Hotpoint Dryer Heater stays on when door is opened
Strange. Heaters usually shut down with the spinning drum when door is open. If you check the schematic for unit you can check to see if in fact this is correct operation. Attached site usually has schematics for appliances. You might want to check. Search Over 2 1 Million Appliance Parts
Sep 01, 2017 | Hotpoint NVL333EY Electric Dryer
I have to hold the push to start button for the dryer to run
Ok you are really not that ignorant, all dryers shut off when you open the door and no holding down the button won't make it work.
Mar 20, 2009 | Kenmore 63942 Dryer
Whirlpool LER5644A No heat and motor wont Turn
Replace the dryer wires.
Put your meter leads into the 4&5 slots.
Make sure the door switch is closed or jumpered.
Push the start button.
If you read no voltage the issue is with the wiring, the timer, or a relay.
Mar 11, 2009 | Whirlpool LER5636P Electric Dryer
Roper Electric Dryer Heats but drum won't spin
Yank the filter out the top. Remove the 2 screws in the filter housing. Use a putty knife to pop the top and then remove the screws holding the front on. NOTE: raise up on the front panel slightly so you won't damage the bottom clips. Get the front out yer way and remove the drum. Clean out the dryer and oil the rollers and idler. Use this handy ROUTING GUIDE to see how to put the belt back.
Jan 20, 2009 | Roper REX3614KW Electric Dryer
Dryers Logo
137 people viewed this question
Top Dryers Experts
