Question about JBL CREATURE II Computer Speakers
One speaker no sound
Speaker with volume controls has very very faint sound.
I just want to confirm that the solution on another page from francis 8 works perfectly ( http://www.fixya.com/support/t3709832-speakers_stopped_working_cannot ). We have two sets of Creatures in our offices, one had been shelved (by someone less persevering than me) due to this problem years ago and my set started this trouble a few days ago. Troubleshot everything, every cable, setting, combination, spare speakers etc - nothing worked. Opening the offending speaker and pulling back the metal weight behind the speaker cone was the solution for BOTH of our units.
Big smiles all around :-)
Note - When you've opened the plastic shell and loosened the speaker from its mounting, the the big round metal piece/magnet sits within the actual speaker 'cage', slightly behind the speaker cone. It's tight but movable and can be pulled all the way back as far as it can go inside it's housing, away from the speaker cone.
Not sure why it gets pulled forward, but it isn't fixed in position and so could clearly get bumped by dropping the speaker or a reasonable impact of some sort. Once bumped forward it would severely limit cone movement and therefore volume.
Posted on Jul 30, 2010
  • 1 more comment
  • donp74 Dec 31, 2010
    same thing happened to me. i followed your instructions and it worked! thanks a million!
  • chipchipchip Mar 22, 2011
    The francis8 solution worked for me, too!!!!!!!!!!!
    Thanks to you, I fixed a "broken" creature that I paid only $21 (because it was "broke"), and am listening to tunes on speakers with no price point peer.
    I don't know how the magnet moves forward, maybe it gets jarred if dropped. But that was the easiest fix ever.
  • Baabaabing Jun 02, 2012
    The glue that holds the magnet gets weak and as a result the magnet slides forward.
    fantastic solution and in my case the magnet was forward but even after sliding it back in place it still won't work, and yes the green lights on, so a solution found as to why but still no joy for me...****! what a shame as I am a fixer by heart and hate the thought of a.buying another and b.throwing them away ouch that hurt just to type the thought :)
    Brigadier General:
  • 10,406 Answers
On your computer, double-click the "volume" icon, to open the "sound mixer" application.
Check that you have not "panned-100%-left" or "panned-100%-right" the sound-output.
On your speakers, "pan" the sound to 50%-left-50%-right.
Try the speakers on some other computer, e.g., a laptop, to see if they work at all.
Posted on May 07, 2010
2 Suggested Answers
SOURCE: My speakers stopped working. Cannot increase the
I fixed a similar problem I was having. It requires a little work.
Take out the four screws from under the broken speaker. Carefully remove the cover, separating the speaker from the base. The two are wired together so don't pull them apart with force. Then remove the single screw, which is much larger the the previous four, and separate the speaker from the top cover.
If you chose you can remove the wires from the speaker, they just snap on, but its not required.
What I found is the speaker issue is not with the wire or the power, but the speaker it's self. On the back there is a big round metal piece. On my speaker that piece was pushed towards the front of the speaker. When I looked at the good speaker, that big piece was all the way back. So I simply pulled it back and presto, instant fix!
I hope this works for you.
Posted on Jan 06, 2010
Where is adjuystment page for audio
click start control panel sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place icon in taskbar for any
further volume control settings you will need to right click on the speaker volume icon system select adjust volume
hope this helps you
Mar 22, 2012 | Logitech Audio Players & Recorders
Sound is very faint and distant
hope this helps
My speakers used to work. They have only been used a few times. The volume settings on my computer are turned up and I have checked all the wires. I have also tried the speakers on two different computers....
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
hope this helps
Feb 02, 2011 | Computers & Internet
Same problem, brand new Dell Vostro, hooked up Polk Audio speakers from former computer and get very, very faint music. Need a solution
if the sound is very faint. you can check the volume properties if it is set to maximize and also check the physical volume control on the actual speaker - also Disconnect Any Headphones That May Be Connected to the Computer - Check for and remove any headphones connected to the computer or speakers to prevent them from muting the external speakers.Click Start, and then click Control Panel.Double-click Sounds and Audio Devices. Click the Sounds tab. You can also try head phone if it is Crystal Clear on headphone then the problem is with the Speaker as Dell might need to replace it. :)
Dec 08, 2010 | Dell A215 Computer Speakers
I can only hear a faint sound from the speakers even when all the volumes are turned up. Where can I go to look for the problem?
you might have to uninstall then reinstall either the driver or the sound devices
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers or right click select properties to either troubleshoot,uninstall,rollback driver
hope this helps
Nov 12, 2010 | Logitech SoundMan S-20 Computer Speakers
Very faint sound on everything, including system sounds. when playing a cd, can hear music, but not lead vocals except faintly. are the speakers shot? Everything was okay yesterday, and no settings have...
First of all, if you have volume controls on the keyboard, please make sure you turn the volume up from that location.
Next, locate the Speaker icon next to the time in the lower right corner of the screen. Double or single Click on that and make sure the volume slide bar is all the way to the top. If you don't have a speaker icon, roll over these icons slowly and an info bubble will pop up. Look for one that involves audio. If you right click on the icon, you may be able to select volume mixer or something similar, there you will find multiple volume settings, turn all up.
Finally, if you are having this problem when using a media player (Windows Media Player, VLC, Quicktime, etc), there will be a separate volume control within the player itself. They are usually a slide bar underneath the video or graphics display. Turn this up also.
Please note that if you are using a laptop, Laptop speakers are notoriously of poorer quality and lack the wattage of desktop speakers. In turn, it may not be a problem with your laptop2_bing.gif. You may need to look into purchasing an inexpensive set of external speakers.
Feb 26, 2010 | Logitech Audio Players & Recorders
Creature III brand new faint sound!
Check out here:http://www.fixya.com/support/t3604714-jbl_creature_speakers
Jan 10, 2010 | JBL CREATURE II Computer Speakers
Output port for left speaker Z2300
I've been having the same problem actually.
In my situation, turning the volume up and down using the speaker volume control will fix the problem. I only have the faint volume problem at some positions of the dial. turning it up usually fixes it. I'm thinking that opening it up and cleaning it might fix the problem (it used to work with an older set of Creative speakers i had).
If that doesnt work im going to try to get a new remote from logitech.
Jul 02, 2009 | Logitech Z-2300 Computer Speakers
Control pod on bose companion 3
try to check the circuit board with an expert
Nov 16, 2008 | Bose Companion 3 Computer Speakers
JBL CREATURE II Computer Speakers Logo
1,919 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Vito Vacirca Jr.
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
