Question about Amana ARB2259CS Bottom Freezer Refrigerator
Freezer cools then thaws out and cools again
I replaced the compressor relay with a new unit since it was a fairly cheap purchase and a probable fix but unfortunately no go. The freezer will freeze everything and within a 24 hour period it will thaw out everything which is strange since it's not like I open it alot. Any suggestion to a fix for the freezer.The top part of the fridge works fine.
Thank you
Aleixo
  • 19 Answers
SOURCE: Freezer thaws completely then freezes again
Take loock if are dirty those coils and fan on botton or some place on your freezer. Tri cleaning all. Just be carrefuly to no brake those coils ???? Unplog from outlet bifore ??? I hop you gete fix it. I'm not shur, but tri.
Posted on Jul 10, 2007
fridgetech
  • 473 Answers
SOURCE: refrigerator compartment not cooling
If you are sure the fan in the freezer is running and you don't feel any air flow out of the top middle vent inside the fridge section, then the damper motor must be bad. The damper motor is behind that vent cover inside the fridge section.
Posted on Nov 16, 2007
  • 4 Answers
SOURCE: Freezer not working
Sounds like a defrost timer problem.
Posted on Apr 04, 2008
mikedurland
  • 481 Answers
SOURCE: Cooling Problem with Amana Fridge/Freezer model ARS2663AC
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Posted on Jul 06, 2008
Techsim
  • 59 Answers
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Posted on Nov 02, 2008
How can I defrost my Kitchenaid Superba Freezer without unplugging the entire unit?
the air from the freezer is what cools the fridge so no way to separate the cooling process for defrost
Apr 24, 2017 | KitchenAid Superba KSRS27CN Side by Side...
I opened the freezer this morning and all the food was thawed. The air blowing in the freezer was not cold at all. I opened my fridge and noticed it was feeling much less cold?
your ptc overload relay on the compressor needs replacing,unplug it off the compressor in the lower rear area of the unit and obtain an exact replacemect and it will again operate and cool
Mar 04, 2011 | Refrigerators
I have an LG fridge w/bottom freezer model LRBN22511TT approx 9 yrs old. Actually haven't had any troubles with the unit until recently. It seems the compressor isn't coming on, but there is an occasional...
The starting relay may be the culprit and is very inexpensive to replace. It is probably worth fixing.
After it is fixed, make sure you get the condenser fins cleaned.
Dec 12, 2010 | LG Refrigerators
I have a kenmore s x s refridge and the freezer is cool by everthing is thawing out. I hear a clicking noise so I took the back cover off and it seems to be coming from the compressor.
the clicking noise may be coming from the start and oveer load relay on the compressor shut the unit down until the compressor is cool replace the over load and start relay on the compressor.
if you have a clamp type power metercheck the current draw on the compressor it should be between 1.2-1.6 amps during a running load.
May 19, 2010 | Kenmore Refrigerators
I have an Amana bottom freezer refrigerator, model no. BX21V1C,it stopped cooling and freezing. The relay was replaced 6 months ago and now it has happened again. You can hear the click and buzz of the...
Good day,
Sounds as if the relay has failed again. ....or when relays start going bad, it could be an issue with the internal part of the compressor.
But the relay approach should be your first step.
Thank you for using FixYa
Jan 26, 2010 | Amana ABB1927DE Bottom Freezer...
Not cooling anything. Freezer has defrosted and
put your hand on the compressor / is it hot or not ? do your hear any clicking or humming /like on an off . you could have a bad relay that starts compressor . very common . and easy to replace .. so if its clicking or not very hot its probably compressor relay ..mm
Dec 12, 2009 | Refrigerators
Frigidiare upright freezer has just stopped cooling
I was hoping it would be something like a cracked door seal, or a faulty thermostat, etc., but after reading the rest of your info, I've concluded the likely cause is a slow leak in the refridgerant line(s). I've seen many of these fairly new upright freezers with this problem.
Finding the leak is easy for a service tech to find, but the cost of the service tech isn't cheap and unfortunately, the repair cost will probably exceed the cost of a new freezer, but you can try to call a repair tech and see if they can give you a rough estimate over the phone or if they think it's worth fixing, etc.
My advice is to replace it. The cost of food you've lost has probably exceeded the price of a new freezer - and you've had this happen twice now. These days it seems that some appliances are being designed and built as "throw aways" due to the high repair cost.
Wished I had some better news for you, but unless you've got all the specialty tools; (charging gauges, vaccum pump, Freon, etc.) needed to do the repair yourself, along with the technical knowledge, it's likely not worth having the repair service contracted. Best Regards.
Jul 30, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Frigidaire model FRT21H7AS Not cooling, compressor makes noise
HI, The relay has gone bad and needs replaced. Probably not the compressor. Fairly common problem with these new fridges.
Let me know if I can assist you further.
Vic
May 18, 2009 | Frigidaire FRT21H7AS Top Freezer...
Freezer thawed. Replaced temperature control, replaced defrost timer, replaced defrost thermostat. Compressor relay is cycling. No cooling still. Help!
Why were those parts changed? Was the compressor cycling on overload at the time?
If so, you should have first replaced the relay/overload combination and the see what happened.
Apr 26, 2009 | Refrigerators
Refrigerator/freezer is warm, fan is running.
The problem is the compressor isnt starting. The relay is probably ok. It should have 5yr warranty on the compressor. However if you purchase a Supco RC0810 start assist relay available at all appliance parts stores, it will start the compressor, however this is only a temp fix. But it should last till sears can put a new compressor in.
Sep 29, 2007 | Refrigerators
Amana ARB2259CS Bottom Freezer Refrigerator Logo
27 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
