Question about Yard Machines Cultivator
How to replace fuel tank Yard Machines Cultivator 21A-120R000
2 Suggested Answers
  • 61 Answers
SOURCE: fuel line routing yard machine 31cc cultivator
unit with primer bulb,,,,,line from gas tank with filter, goes to bottom of carb, from top of tank to suction side of primer bulb, from output of primer to tank return
Posted on Apr 29, 2010
Testimonial: "Thanks for the info, tiller runs fine. Phil"
HOW CAN I REPLACE THE PULL CORD?
remove the three or 4 bolts holding the starter on the motor wind the spring loaded starter backward until you feel real good tension stick a screwdriver through the starter to keep it from unwinding thread the rope through the opening in the starter tie a knot in the end of the rope release the spring that should fix it.
Oct 20, 2015 | Yard Machines Cultivator 21A-121R900
CAN THE PULL ROPE BE REPLACED?
Yes.
It's a matter of dis-assembly, replace, and re-assemble.
You should be able to get thae part (and the work done) at any local small tool rental or service shop.
Fuel line diagram for troy built tiller
Try reversing fuel lines. They may be connected to the wrong ports.
Jul 05, 2014 | Yard Machines Cultivator
Installing fuel tank to 2 cycle garden caltivator yard machine
Remove the screws that mount to the engine and slide the fuel tank forward. Slide the fuel tank out of the rear mount and remove the fuel lines from the tank. Install the fuel lines into the new tank and install it in the 2 mounts that held the original fuel tank.
Jun 08, 2012 | Yard Machines Cultivator
I have a Yard Machrines by MTD Yard & Garden Cultivator 31cc: Model No.21A-121R900 Ser.No.1A246DG1150 and I need to replace the primer bulb. How do I do that?
hello l, how to change primmer bulb,,remove the two fuel lines making note which line came off where,use needle nose pliers to push the two ears down and pull bulb out,make note on where the long and short stem was at,go to the mower shop and get a new bulb and install,put lines back on, done start engine,,hope this helps,,
Jan 27, 2012 | Yard Machines Cultivator
The yard machine 121r will start then run out of fuel.
Is this a new one or a used one? This time of year, after a machine has been stored for the winter, the most common problem is a clogged fuel filter due to old fuel being left in the tank. If that is the case, clean out the tank, replace the fuel filter, make sure the fuel lines are not clogged, and run some carburetor cleaner through the carburetor.
Mar 04, 2011 | Yard Machines Cultivator
My Yard Machine Tiller starter rope will not rewind - it is an MTD engine the model is 21A-121R900. Once I take the cover off I can't get to the rewind mechanism.
you can either drill the rivet out, or inside the shroud there are metal tabs that you can bend out, but be careful as not to break them off. Hope this helped Tim
Feb 27, 2011 | Yard Machines Cultivator
I need a diagram for Yard Machines; garden cultivator; 31cc
Here is a parts breakdown for your machine (found under MTD) with parts listings, diagrams and prices.
http://www.partstree.com/parts/?lc=MTD&mn=21A-121R900
Nov 24, 2010 | Yard Machines Cultivator
Fuel line routing yard machine 31cc cultivator 21A - 120R000
Apr 29, 2010 | Yard Machines Cultivator
Yard Machines Cultivator Logo
175 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Phil Walker
Phil Walker
Dean Gruber
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
