Question about Canon PIXMA MP210 Photo All-In-One Printer
Selecting cartridge Hi, I can't seem to get the printer to use the black cartridge to print. I've already did what the manual says and made sure the media is Plain Paper and Borderless Printing is not selected.
    Guru:
  • 377 Answers
Hi dear
set your printing to print in greyscale
open printer & faxs
select preference, choose coler
set to print in grayscale
oke
Posted on Mar 27, 2008
Why is my black ink not printing
Hi Colleen,
Try this > open a document (from the computer) and select print from the menu,
- In the print screen window select 'properties' Or 'Preferences' or 'Properties'
- In the next window click 'maintenance'
- In the next window there will be many options to clean, align, nozzle check etc... , there click 'Ink cartridge settings'.
- A small windows opens, there select black only. See the image
- try printing, if it fails to print, just return the cartridge to the shop and get a genuine branded one. (dont forget to change the 'ink cartridge settings to normal to 'both black and color')
Hope this help, if you are not able to fix it still, then better come to chat here , thanks! 10_22_2011_5_46_32_am.jpg
Oct 22, 2011 | HP Photosmart C6380 All-In-One InkJet...
Lexmark 3600-4600 stops at 34% when trying to print a test page. Color ink is low, but I only want black in any event.
If your color ink is already empty or not substantial for printing, then you must replace it with a new cartridge. The Lexmark printer will continue to print when there's substantial ink in the cartridges.
If you prefer to print in black and white as your default print setting, please follow the steps below: (make sure your black and color cartridges ink levels are good)
For Windows OS:
1. Go to Control Panel.
2. Open Printers and Faxes.
3. Right-click on Lexmark 3600-4600 Series print object and click on Properties.
4. In the Lexmark 3600-4600 Series Properties window, go to Advanced tab. Click on Printing Defaults.
5. In the Lexmark 3600-4600 Series Printing Preferences window, under Ink Use, select Print using black ink only. Click OK.
6. Click OK button in the Lexmark 3600-4600 Series Properties window to save the changes.
Your printer will print in black and white draft mode the next time you send a print job to the printer.
For Mac OS:
1. With the file (you wish to print) open, go to Print. A window will pop up.
2. Select the Lexmark printer.
3. Expand the arrow pointing down beside printer name if you're not able to see other options for printing. Look for Quality and Media.
4. Under Paper tab, select Print in Black and White.
5. Save this as your default print setting. Click Presets option and choose Save as. You can personalize the name for this default print setting (e.g. Black and White Draft or My Setting).
Select this Preset name every time you print your files/documents.
Aug 31, 2011 | Lexmark X4690 Wireless InkJet Printer
My canon Pixma MP620 wont print in black. All the other colors are fine. I've tried deep cleaning with no results..
Try this;
- Open the document you want to print - Go to file > Print - click properties in the print window - in the menu select 'Maintenance' - in the 'Maintenance' click 'Ink Cartridge Settings' - select Black Only - click OK - click OK - now you can print only using the black ink in the printer.
Hope this helps.
Please rate if this solution was helpful. thanks!
Jul 14, 2011 | Office Equipment & Supplies
I have a Konica Minolta Magicolor 1650en. When replacing color toner, I managed to install magenta and yellow, following menu prompts, but when I try to install Cyan, the cartridge doesn't...
I had a similar problem in that after changing one of the cartridges (I bought a whole set), the message "cannot rotate cartridge" appeared. I tried pressing the cartridge in more firmly and may have caused the carousel to rotate a little in the process. I cycled the power which seemed to clear the error message and allowed me to select the next cartridge to change, but upon opening the door to change it, was unable to remove the old one as it was positioned a little too high. I eventually cleared the problem by manually rotating the carousel by pressing in and holding the carousel release (see arrow) mmgazette.jpgwhile rotating the carousel downward slightly, to line the cartridge up as it appears in this picture. Then powered it back up and was able to do the normal cartridge replacement procedure for the remaining cartridges without further error messages.
Jun 11, 2011 | Computers & Internet
Brandnew printer nwill not print colour
Hi super_um
Assuming you have already checked the color cartridge and ink
Type something in color and try to print
Do not use the Printer Icon, instead go through the menu bar and select print
On the the print dialog screen, click on the properties,
Under color: options: you will have options like the following:
Print in color
Print in B&W
Print in grayscale
(Depending on the Brand of the printer, the wording may be different)
Make sure you select "print in color" option and leave it like that always. On the other hand, if you select black, all the different colors will be printed in black or gray.
Hope this will work for you
Good luck
luciana44
Sep 20, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Possible to print only black when colour cartridges are empty?
This printer does not let you print if even one of the cartidges is out of ink. I suggest you replace them and then in the printer properties change your settings to the way you want color to be spent.
Aug 04, 2008 | Epson Stylus CX5000 InkJet Photo Printer
Its not printing in black
you need to replace your new cartrige. Im sure it has warranty
Feb 23, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
Canon PIXMA MP210 Photo All-In-One Printer Logo
82 people viewed this question
old marine
old marine
