Home | Apple | HP DeskJet 3820 InkJet Printer | HP Deskjet D4160
Apple HP DeskJet 3820 InkJet Printer
Problem for Apple HP DeskJet 3820 InkJet Printer
HP Deskjet D4160
By ursula4349 on Mar 27, 2008
I get message that says Printer is offline, Opening printer connection, printer is offline, and so on.  Also says printer is off line then, printing 15% of page 1, 30% of page 2, and so on but nothing actually printing on the paper.
Comments:
Mar 27, 2008
- Solution #1 worked fine!
Same Problem
Sep 01, 2008
-   printer offline, wont print-   Guest
Best Solution
posted on Mar 27, 2008
Very Helpful)
thumu
Rank: Guru
Rating: 86%, 128 votes
This is Vikram Kumar Thumu from India-Hyderabad. I have seen your issue and I would like to provide my solution on the issue.
Well, this is the issue that could happen with either with Printer Software or with Printer Ink cartidges that could be out of ink or very low in ink...
To isolate and to resolve the issue I recommend you to perform below solution. I hope that this will fix the issue for you.
Solution 1: Hard Reset Printer
1. Turn OFF printer
2. Disconnect Printer from Computer.
3. Remove the Printer Power Cable from wall outlet and then try to remove the ink cartidges from Printer.
4. Wait for a minute.
5. and then reseat the Printer ink cartidges and then Connect the Printer cable to the Computer and then Power ON Printer.
This should generally fix the issue. However, if the issue still persists then I recommend you to proceed further solution on the issue.
Soltution 2:
Right click on the Printer icon of HP Deskjet D4100 Series and then select the option " online " and then press F5 key in the keyboard. to effect the changes.
Solution 3:
Try to print a Cartidges Test page from Printer Properties to check the ink cartidges ink status.
if found issue with ink cartridges then replace them else try to uninstall and reinstall the Printer software.
This should resolve the issue. If the issue still persists then I recommend you to contact HP CHAT SUPPORT or HP PHONE SUPPORT team or HP EMAIL Support on this issue. They can help you further to resolve the issue for you.
If you need any further assistance you can mail me at thumuvikram@rediffmail.com. I 'll be glad to help you ...
Bye.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Apple HP DeskJet 3820 InkJet
Questions and Unsolved Problems for Apple HP DeskJet 3820 InkJet
Do you recommend Apple HP DeskJet 3820 InkJet Printer?
Answer
Answer
hi! my HP C6100 Photosmart printer has paper stuck inside and I can't reach it, It shut itself down.... (More)
Answer
Hello, my HP OfficeJet Pro K5400 Printer doesn't print black. It says on the software that... (More)
Answer
Cradle will not move on my Hewlett-Packard 3820 series Deskjet printer.
Answer
Have tried everything but do not get a printed page, new cartridges, paper is proper size, prints... (More)
Answer
When printing, the paper slides down until it has almost disappeared, and then it starts veering off... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Apple HP DeskJet 3820 InkJet...:
Top Printer Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
