Question about Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV
Tv picture turns off and green light blinks on front of TV
  • 119 Answers
SOURCE: Sony KP-51HW40 No Picture, only sound
how many thimes does the light blink, it's an indication as to where you should start looking for the cause of the problem
Posted on Dec 21, 2006
SOURCE: Tv cuts off and green light flashes
I went thru this a couple of days ago. The repairman change the bulb and my TV was fix in 15 Min. I too have a Sony 60 inch WEGA.
 Now that I know I can change the bulb myself, but there's a hazmat issue on the bulb.
goog luck.
Posted on Oct 23, 2007
SOURCE: light blinks 8 times
I'm 58 years old. Have had red lines forever. Tonight turned tv on and it faded to blue.Kept on shutting off Red led light flashed 8 times Read your info. Decided I had nothing to lose. I actually fixed it myself. Probably just a quick short time fix but I'm happy tonight. I guess I'll start looking for new TV. Don't know if I'll go with another Sony. I've this one for 5 years. Should last longer than that (I think)
Posted on Jan 29, 2008
  • 4 Answers
SOURCE: no picture and no sound just a blinking stand by light on front of my sony kdl40s2000 lcd tv
I called Sony repair and they said to bring my set in for evaluation. They think it is just the back light. Maybe $300 - $400 to fix. If it is the panel I will scream!
Posted on Jan 30, 2008
SOURCE: kdf-60xbr950 - red light blinks 3 times for a minute and tv turns off
http://www.somelifeblog.com/2007/08/sony-tv-led-blinking-codes-what-does-it.html
Posted on Feb 20, 2008
Got a Samsung dnie model code spp4251x/data tv when powering up the front light comes on but no picture or anything anyone got some good info??
tv seems to turn on but no picture? - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - ... Samsung Dlp TV (HLR-5067W) it seems like the TV turns on butthere is no picture. ... the lamp is, light is visible from where the lamp is located but no picture. DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
The timer, lamp, and standby/temp. light are flashing?!
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...I Have A Sanyo TV I Can Hear But Black Screen Im 14 And Dont Know What To Do ! .... power button the power light goes from red to green, the screen flashes on then goes black ....Troubleshooting LCD Backlight Failure Samsung LNT-4066 ...
Samsung plasma tv repair blinking light no picture ...
Jan 09, 2016 | Samsung Televison & Video
After researching online, my TV problem seems pretty common. TV - Mitsubishi 1080 series WS 55511. Green blinking light blinks for 3 seconds, then goes out and TV never turns on, but I hear a slight...
The green light is known as "The blinking green light of death". This refers to the green LED on the front panel of the TV that normally blinks when turned on after a power failure or when unplugged: the green light is supposed to flash for about 1 minute while both microprocessors boot up: If it won't stop blinking it means that they aren't communicating w/each other. Unfortunately, it's common in Mitsubishi & other RP TV's. Getting this fixed by a professional is around $6-700 with labor, parts, etc. It's really not worth it in my opinion. I would go out and buy an LCD or an LED TV.
Nov 28, 2010 | Televison & Video
We have an older Phillips Magnavox tv. The tv will turn on & we will see the picture for a short time but then the screen turns grey. We still have sound, just no picture. Also, the green power light...
Hello, the grey screen could be due to a missing 220Volt source which feeds the color (RBG cathodes)inside the CRT(picture tube). When this happens the beam current inside the CRT goes high in a matter of second, thus triggering the beam current protection circuit(blinking green light)shutting down the TV. Repairing the secondary voltage source is necessary to get the TV working normal, a good technician should be able to repair it for between 80 to 100 dollars parts included, except a picture tube, which could be also the cause of the problem(K-A shorts).
Nov 06, 2010 | Philips Magnavox 27MS343S 27" TV
Tv won't turn on. It blinks green then red.
Question shows tv is Sony KDF-60WF655.
Green light blinks when tv gets prepare to fire up lamp, check internal circuits then show picture on front screen.
Red light blinking shows some kind of internal problem during circuit check and protection got activated upon some failure.
Count the red light blink as you will see 3 second long pause and post it here to diagnose what section of tv got problem.
Did you replaced its lamp in last 2-3 years?
Thanks.
Jun 01, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
WS-55517 Mitsubishi Rear HDTV projection tv will not turn on
2 blinks followed by 1 blink is the X-Ray protection-----means some problem in the High voltage circuit ---set produces over 25 thousand volts to fire the 3 picture tubes inside up----It could be excessive high voltage-------I think you would have to get lucky for someone to find and fix it in your home----more likely it will need a visit to a Repair shop.
Aug 20, 2009 | Mitsubishi VS-50605 50" Rear Projection...
The green light blinkig and does not stop, no picture
Did you try unpluge from the wall, and repluging back after 10 min.
Also run the self diagnosis by pushing the menu and device buttons on the front and let me know the code?
Thanks
K
Apr 23, 2009 | Mitsubishi WS-65909 65" Rear Projection...
No picture, no sound.
Hi i have a pilips 42" plasma tv (42PF5320/79) i can hear clicking the green light is on and the tv will go into stand by if i press the power button and the red light also comes on .I have turned it on and off and it works now nothing just the light on the front as if its working looking at the back through the slots two green lights come on then the tv clicks and they turn off,thanks
Aug 06, 2008 | Philips 42PF9630A 42 in. Plasma Television
Green flashing light - no picture
If the green power light is blinking and you have no picture, then your light bulb has burned out and needs to be replaced. It is not a cheap bulb to replace. If the TV is less than 1 year old it should be covered by the warranty
Nov 03, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV Logo
16 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
