Xerox Docuprint C1618 Colour Laser
Definitely the right description.
This machine is located in Australia.
The OEM part number is CT350168
Regards, Carl.
  • Anonymous Mar 31, 2008
    Sorry Tryit, I am new to this site & how it works. I was not sure at what point the rating should be made. Also, I cannot see those links giving me the actual answer to my problem, which was: can I reset the counter on the existing drum unit when it says drum needs to be changed, so that I do not have to buy one immediately?
    Regards, Carlperro.
    President:
  • 2,072 Answers
I have to ask you to repost this on the main board again. Since I responded it removed your post.
I have the US and Europe documentation. I am sure that is a version of a machine i have documentation for, but I can't cross reference it. Sorry, Would like to assist here.
I tried the part number in my database and it also does not cross reference here.
Posted on Mar 28, 2008
SOURCE:
Need driver for xerox docuprint p8e printer for windows 7 32 bit to install
Try this:
http://download.support.xerox.com/pub/drivers/GLOBALPRINTDRIVER/drivers/win7x64/pt_BR/X-GPD_5.246.7.0_PCL_x64.exe
Mar 17, 2012 | Xerox DocuPrint P8E Laser Printer
How do I set my Xerox Docuprint 3290FS colour printer to work without colour cartrige
unfortunately this cannot be done - best you can do is source a replacement chip for the
cartridge - worst, replace the cartridge with either a compatible or genuine one
Aug 13, 2010 | Xerox DocuPrint C3290 Printer
Any Windows 7 64bit driver for Xerox Docuprint P8ex? The one posted by Droidd is probably 32 bit and does not work in Windows 7 x64. Thanks.
Hi, The Xerox DocuPrint P8ex understands PrinterControlLanguage of version 5e or 6 (PCL 5e or PCL 6). So actually you can use driver from every printer supports PCL 6. Driver for "Fuji Xerox AP-II C2200 PCL 6" working very well for me on Windows 7 64bit. Steps to install: From Device Manager -> Other devices ->Right click on DocuPrint P8ex -> Update Driver Software -> Browse my computer for driver software -> Let me pick from a list of device drivers on my computer -> Double click Printers -> Fuji Xerox from Manufacturer -> FX AP-II C2200 PCL -> Next
May 12, 2010 | Compaq Xerox DocuPrint P8ex Laser Printer
Xerox Docuprint 3290FS colour multifunction black overtoning badly then spilling during "calibration", leaving very dark background and blotches of toner cyan overtoning mildly during "calibration",...
Xerox does not list that model at all - are you sure the model number is correct ?
It would appear that either the cartridge or fuser may be defective.
Does the machine show any error codes at all ?
Here is a user manual for a similar model 3225 that may help under the troubleshooting section :
http://www.office.xerox.com/userdoc/N3225/pdfs/UserGuide.pdf
This is where you find manuals for all Xerox products :
http://www.support.xerox.com/go/prodselect.asp?Xlang=en_CA
Oct 28, 2009 | Xerox DocuPrint C3290 Printer
Are you certain you have typed the right model number? I can't find a Xerox 1618 anywhere. I would love to help.
Mar 24, 2008 | Office Equipment & Supplies
Fuji xerox docuprint c1618 error
001-360 Fan motor failure Check Fan Rear Check Fuser Fan Check voltage on fan rear should be between 15VDC and 24VDC. Check voltage on fuser fan should be 24VDC
Dec 29, 2007 | Office Equipment & Supplies
Xerox DocuPrint N17 Laser
The following link has a software and drivers where you can select MacOS X and find the software and drivers. Unfortunately I found no installation instructions.
Docuprint N17 Link
I hope this helps.
Dec 15, 2007 | Xerox DocuPrint N17 Laser Printer
Driver for windows vista
If found that if installed the printer as a Xerox DocuPrint 4517 instead of a Xerox DocuPrint N17b then the printer works fine under Vista.
The only thing that lead me to try this was that I found that N17b and 4517 used the same printer cartridges, so I guessed they might be similar under the hood too.
Nov 21, 2007 | Xerox DocuPrint N17 Laser Printer
123 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
