Question about Refrigerators
We have an AGA HA350 Refrigerator which has been serviced today and now keeps going into defrost mode evry few hours how can we stop this happening
Call the servcie guy back?
Posted on Aug 25, 2010
Troubleshooting: currently running temp is 10 degrees instead of 3
Switch it off and defrost that patch of ice , switch it on and check temp after a few hours may fix it if thermostat was frozen, if not check for gas leak or faulty thermostat.
Mar 03, 2016 | AGA Refrigerators
Everything is out, we have it off, no water is draining. The freezer just stopped cooling, hence the refridgerator side stopped too. I just turned it on after 5 hours. The motor is running and so is the...
Could be that your self defrost mechanism is not working and unit is freezing up and not cooling. Till fixed just defrost overnight and turn on next day. It will run fine for a few days till it freezes up again.
Probably need to replace open heater element. Go to sears web site for part number and then purchase it for less money on ebay.
Sep 18, 2017 | Amana Side-By-Side Refrigerator 26 cu. ft....
Liebherr KD 900 fridge freezer bought 2001. Both the freezer and fridge are losing temperature, as though it is defrosting and then clicks back on and seems to regulate itself again. This has happened...
The defrost timer sticks in defrost mode and then comes out of it. I've been out of the service industry long enough to not be able to tell you on your model where it is located. Defrost timers on frost free refrigerators are a very common problem.
Oct 11, 2017 | Liebherr KES3660 Stainless Steel...
Evaporator coils ice up after a few days and the refrigerator comparment only stops cooling. The unit is 2 years old. When removing the backing from the inside of the fridge and after thawing out the coil...
I have some information on your model and that would involve forced defrost by the service manual page 28 at bottom. How old is your Samsung? Forced Operation Function (Pull-down / Refrigerator Defrost / Refrigerator . Freezer-Defrost / Cancellation)
● This function enables a pull-down mode, a defrost mode for the refrigerator only, a defrost mode for the freezer and the
refrigerator at the same time, and a cancellation of this function.
● Press Power Freeze and Fridge Temp. buttons for 8 seconds simultaneously to get in the ready mode for a forced
operation.
● The display panel will return to normal after 20 seconds in the ready mode.
● At the ready mode, press any button(except Ice Type and Child Lock) once to start a pull-down operation, twice for a
defrost cycle for the refrigerator, three times for a defrost cycle for the freezer and the refrigerator, and finally four times
for cancellation of this function.
● Another way to cancel this function is to simply plug out and in the power cord.
1) Pull-down
1-1) At the ready mode, press any button once then the buzzer will beep (ON for 1/2 second and OFF for 1/2 second)
until this mode is cancelled.
1-2) At this pull-down mode, the compressor will start immediately (No 5 minute delay) and if the system is in the
defrost cycle, it will be cancelled right away.
note) If this pull-down mode begins right after the compressor was off, the compressor may not start to run due to an
overload condition.
1-3) At this mode, the compressor and freezer fan will operate continuously for 24 hours and the refrigerator fan will be
on and off according to the set temperature(34℉)
1-4) After 24 hour operation, the system will be cycled at -14℉ for the freezer and 34℉ for the refrigerator.
1-5) In order to cancel this mode at any time, select the next mode on the ready mode or power off the system.
2) Refrigerator Defrost / Refrigerator . Freezer-Defrost operation
2-1) At the pull-down mode, press any button again on the ready mode to begin the defrost cycle for the refrigerator.
2-2) The beep sound continues for 3 second at the beginning, then ON for 3/4 seconds and OFF for 1/4 second until
this mode cease.
2-3) After this operation, the system will come back to normal operation.
2-4) At this mode, press any button again on the ready mode to operate the defrost cycles for both compartments.
2-5) The beep sound continues for 3 seconds at that time, then ON for 1/4 second and OFF for 3/4 seconds until the
defrost operation cease.
3) Cancellation
3-1) At the R,F-Defrost mode, press ant button again on the ready mode to return to a normal operation.
3-2) Simply unplug the power cord, then plug it again to return to a normal operation.
Press both button for 8seconds at the same time Send maual in one moment, Thanks, Sea Breeze
Jan 20, 2010 | Samsung RS267LBBP 26.1 Cu. Ft. Side by...
No cooling
Call a service person--if this happened rather suddenly, it is likely a refrigerant gas leak. Unplug the unit for now to save the compressor. Buy some dry ice to keep things cold while waiting for repairs.
Aug 14, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
GE Profile Fridge/Freezer defrosting
You will need to replace the electronic mother board which is located in the back of the refrigerator,Inside rectangular cover near the bottom left.
Feb 28, 2009 | Magic Chef (CSD2610KRW) Top Freezer...
Freezer not working but fridge is
tratra72
You said,
I opened my freezer today and everything was defrosting. The fridge is working fine. I thought maybe did not shut properly so made sure it was closed and 8 hours later it is still not freezing. The fan is working but the air is refrigerator. HELP!!!
1.Try unplugging the fridge for 5 minutes and then restarting it! This may reset the system!
2.If the freezer is so full that the rear vents are blocked then this may happen. Because the fridge and the freezer share the air!
3. If not then the freezer and the fridge have different controls and the freezer control if faulty!
then you need service. ur site has good service companies in your are for our customers!
Bless You,
please give me a good rating before you sign off!
thank you
Sep 14, 2008 | Roper RT21AKXKQ Top Freezer Refrigerator
Frigidaire GS26HSZCC7
it sounds like it could be the defrost timer/board hanging up in defrost periodically. this refrigerator has an adaptive defrost control board that acts like a defrost timer. it keeps track of how long it takes the freezer to defrost and schedules the time between defrost cycles accordingly (to save electricity). old defrost timers would go thru a defrost cycle every 12 hours whether it needed it or not. so i would suspect that this control board may be malfunctioning. the control board is item # 1036287 at repairclinic.com. you will need a repair technician to test it and make sure it is bad before spending $75 on it.
Jul 10, 2008 | Frigidaire PLHS237ZD Stainless Steel Side...
Refrigerators Logo
178 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
