Question about Maytag Neptune FAV6800AW Top Load Washer
What does the code "UC" mean? The "U" is half as tall as the "C"
  • 555 Answers
It is related with the improper balance of the machine or a problem of the sensor. You can get a full explanation about this error here:
http://appliancejunk.com/forums/index.php?topic=2003.0
Posted on May 08, 2010
  • 526 Answers
Is you wash tub banging around in Spin Cycle of the Wash Cycle when you Control Board signals a uC error code to the console? If so then I feel your TDS is working as designed.
Try the thru the lid test of the TDS in the Service Manual to see if it’s operating within the range of motion of design. See page 19 for the test. Most times this is a Clutch malfunction see my Clutch Fix post for more info related to dC and uC unbalance errors with the FAV6800A and FAV9800A TL’s…….Rich
Samsung washing machine error code uc
Since you are receive UC error code, Please call the after-sales service.
Source: Samsung CS Portal
May 24, 2013 | Washing Machines
I have spent over an hour looking for information on how to set a code for my Schlage BE365 CAM 619 keyless access deadbolt. I want a very SIMPLE explanation. Don't tell me to go to the Schlage web...
First make sure you have a fresh new battery installed
Next if you feel you have fiddled with it so much you can reset the lock to the factory default settings, to do this
1.Disconnect the Battery
2. Press and hold the Schlage Button while reconnecting the battery
However proceed before resulting to a reset and see if you are sucessful.
There are preprogrammed user codes already programmed into the unit
These two USER CODES (UC) are on the Yellow Sticker and on the Installation documents that came with the lock. Also the 6 Digit PROGRAMMING CODE (PC) is listed in the same location.
Assuming the lock was installed correctly and tested for correct operation.. proceed...
First.. I agree with you about the instructions.. many places they use the word "press" when they should have used the word "enter".. or phrase.. "enter the user code by pressing the corrosponding numbers".. however..
With the door open test the lock function
Press the Schlage button.. this should extend the bolt
Next Enter one of the two supplied preprogrammed user code (a) or (b) and rotate the thumbturn away from the door edge (generally to your left or counter clockwise) This should retract the bolt.
To Enter a New USER CODE (UC)
1.Enter the 6 Digit Programming Code (PC) via the key pad
2.The Schlage button will glow Orange
3.Press and release 1 on the keypad
4.Enter your new/desired 4 Digit USER CODE (UC) via the keypad
5.Enter the new/desired 4 Digit USER CODE (UC) via the keypad again (yes a second time)
The Schlage button should flash green.. signalling the program was sucessful
Repeat the lock function test using the new User Code (UC)
Make sure you write the new UC number down.
This lock will store up to 19 UC codes.
Good Luck!
Mar 11, 2011 | Schlage BE365-CAM BE365CAM619 Satin...
Samsung DMR77LHS Tall Tub Dishwasher displays HE code (flashing) and does not finish the cycle. I am very handy and would like to repair this myself. so as much detail as possible is appreciated.
EE1/HE/HE1
  • The EE and HE codes refer to temperature errors. The EE1 designation refers to a thermistor issue, and the HE codes refer to heater problems. These are all functional errors that require a certified service technician, but disconnecting the circuit breaker in the meantime can prevent the problem from growing worse.
  • 4E/4E1
  • The 4E codes indicate a problem with the water supply. If you see the 4E code, make sure the water supply line is correctly attached and open and not frozen or clogged. If you get a 4E1 code, check the temperature of the incoming water supply and ensure that it is below 176 degrees. If either of these issues persist despite your best efforts, contact a repair center.
  • 5E
  • The 5E code means there is a problem with the drain. Make sure the drain hose and openings are not clogged or obstructed. If they are not, and the code remains, disconnect the circuit breaker to reduce the risk of electric shock and contact a service center.
  • oE/9E
  • The oE and 9E codes refer to issues with the water level. The oE code means that the dishwasher is filling too much, and the 9E code means it is not filling enough. Disconnect the circuit breaker for safety and contact a repair center.
  • LE
  • The LE code indicates a leak. To keep from voiding your warranty, do not attempt to diagnose and repair the leak yourself. Close the water supply valve and disconnect the circuit breaker to avoid electric shock and contact a repair technician.
  • 6E2/PE
  • The 6E2 and PE codes both indicate functional errors that must be repaired by a professional. The 6E2 code indicates a pressed key error, and the PE code refers to a problem with the half-load function. Disconnect the circuit breaker in either case and contact a repair service.
  • Jan 14, 2011 | Samsung DMR77LHS Tall Tub Dishwasher
    How do I get messages when I am away from home
    The remote operation instructions are on the right half of the first page of the manual at
    http://www.radioshack.com/graphics/uc/rsk/Support/ProductManuals/4303829_PM_EN.pdf
    Nov 08, 2010 | Radio Shack (43-3829) Digital Answering...
    How do I access messages remotely?
    Oct 04, 2010 | Radio Shack (43-3829) Digital Answering...
    How do I access my answering machine 43-3829 from a remote phone? I tried calling and using the remote code but since I mislaid my manual I may not have followed the correct protocol.
    The instructions are on the right half of the first page of the manual at
    Sep 25, 2010 | Radio Shack (43-3829) Digital Answering...
    Remote access code to retrieve messages
    May 19, 2010 | Radio Shack (43-3829) Digital Answering...
    UC-21 code and the service manual only goes to UC-20 Model sharp MX-2300
    I will have to take a stab at this at this code is not listed in the service manual. The UC codes deal with Counterfeiting! Either the user wanted to try and copy money or they copied something that had the colors very close to money so the only way to fix this is to have an authorized dealer call Sharp and have the boards ordered.
    Apr 30, 2009 | Sharp MX-2300N Color Copier
    Uc code error
    uc code means unbalanced condition. My research shows this as being an unbalanced load or a faulty control board.
    Make sure your load is balanced, otherwise you may have to replace the control board.
    Jun 04, 2008 | Maytag Neptune FAV6800AW Top Load Washer
    Maytag Neptune FAV6800AW Top Load Washer Logo
    447 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
