Not powering up ..... will turn on but after what appears to be some internal check it shuts down. Sherwood amplifier.
    Problem Solver:
  • 12 Answers
Disconnect all inputs, then add one at a time to see what happens. If that doesn't work, disconnect all speakers, then add one at a time.
You may have a short-circuit in one of your inputs or speakers, and the amp is detecting this.
Posted on May 11, 2010
Sherwood rx-4105 receiver that when turns on stays on for approximately 4 seconds and then shuts down.
Sounds like you have power supply issues, pull the cover off and see if you can see any bad capacitors for starters
Jan 07, 2018 | Sherwood Audio Players & Recorders
I have Sherwood rd-6106 amplifier and when i turn him on it goes back to standby after few seconds. can anyone help?
bad fuse, something is sending it to sand by to keep from ruining the rest of it, have it looked at by a pro technician
Feb 02, 2015 | Sherwood Audio Players & Recorders
Amplifier auto off when too loud
check your speakers. If a speaker is going bad or is being over-driven the amp will shut down to protect itself
Nov 20, 2013 | Sherwood Audio Players & Recorders
Amplifier shuts down soon after turned on with a "click" sound. This happens intermittently but less common in cool weather. Nothing is placed on it and it is in a relatively dust-free...
Hi, This is a (thermo switch) heat is being generated through the unit. This switch turns it off when the amp gets to hot. My suggestion is you can place a fan near the unit to cool it down. Good luck.
Jul 22, 2011 | Sherwood Audio Players & Recorders
Sherwood SEL-400 Int Amp - Strange Power Issue
I have one with the exact same problem. I think it is in the protection circuit. I am waiting for my tech to have the time to recap and fix it.
Mar 03, 2009 | Sherwood Audio Players & Recorders
Sherwood rx4105
you may be using an equalizer? try to pop-up the volume with all tone controls in flat mode. see if it still cuts off. if this is the first time youencounter this then something must be wroing with either your speakers or your amp. unless your ventilation is not good enoughg, you can also try placing a blower on top of your unit to cool it down
May 04, 2008 | Sherwood RX-4105 Receiver
Insignia NS-R2000 receiver
Check the impedance ratings of your speakers. Sherwood, the actual manufacturer of the NS-R2000 receiver, suggests that you use speakers with an eight ohm impedance if you have only one pair attached. If you have two pairs of speakers attached, the impedance rating of each pair should be sixteen ohms.
This is because Sherwood wired the receiver such that an additional pair of speakers is placed in a parallel circuit to the first set. When this is done, the impedance (resistance) of the load seen by the amplifier drops. As resistance drops, you get closer to a short circuit (no appreciable resistance).
Many other receivers wire the speakers in series, which causes the impedance to go up.
Personal experience seems to suggest that the amplifier is OK with a four ohm load on it. It does run warmer with a four ohm load, which is what you'd expect. It's when you have multiple sets of four ohm rated speakers that you will get into trouble, as this means the receiver only sees a two ohm load. This will cause overheating and shutdown.
At this point the power transistors in the amplifier may have been damaged. It may require repair. Fortunately, replacement parts are readily available (though not from Sherwood or Insignia). If it continues to shut down, stop using it. You could end up burning out your speakers.
Jan 09, 2008 | Yamaha RX-V2400 Receiver
Connecting remote cable to other port from the car stereo
You can tap the amplifier's remote wire into the accessory power lead at the back of the head unit. On most head units this is a red wire. Doing this will make your amplifier turn on and off with the key switch, rather than the deck power.
Jul 01, 2007 | Sherwood XCM-6870R CD Changer
Sherwood amplifier rv-5106r
if your skilled enough,concentrate only on the power supply circuit and try to check some chips,if not see a qualified tech.
Dec 03, 2006 | Sherwood A-965 Amplifier
87 people viewed this question
 Grubhead
Grubhead
