Question about Zebex Computers & Internet
Hand held scanner
Turned on computor after two week holiday,scanner only partially lights ie only small red and green lights,and will not scan,can you offer advice please, regards Brian.
After a few minutes the scanner kicked into life and is now fully functional,have no idea why the problem occurred.Thankyou for your interest,regards Brian.
Posted on Mar 28, 2008
Scanner stopped in middle of scan . green light in front went out. later red light came on. message on screen said that the carriage was locked. I tried turning scanner on and off and green light comes on...
test the power supply to the scanner also test the leads that attach from the power supply to the scanner if its connected to a computer you might have to uninstall it then reinstall it this applies the driver aswell you can do this control panel admistrive tools,computer management,device manager scroll down you should see a yellow question mark? right click to reinstall drivers or ports(com&lpt)ECP printer port right click update driver
hope this helps
Oct 27, 2010 | Computers & Internet
I was in the middle of an order and the red scaning light still working but will not scan the product, I downloaded what was on the scanner and that worked, but still not getting a beep after scanning the...
Push and hold down the big button for a while until it beeps. This scanner has a feature to disable the confirm beep that gets activated if you hold down the scan button too long!
Regards, Alan
Oct 05, 2010 | Opticon OPN 2001 Mobile Data Collector...
My epson scanner 3170 is flashing a red light and won't scan
This happened to both mine and my sister's 3170. The plate holding the belt pulley wheel is held by two very small plastic flanges. At between a year to a year and a half the flanges fatigue and break causing the forward pulley wheel to break free. With the belt no longer able to turn the scanner won't initialize, the lamp won't light and the red flashing light comes on. The fix is rather simple though. Simply drill a small hole through the bottom of the case and place a small metal screw through with the screw head placed so that it overlaps the pulley wheel base thus holding everything down snugly. Fixed both scanners with this fix. In my opinion, just poorly engineered and perhaps even "designed in obsolescence". Most people would simply toss it and buy another considering what it would cost to send it in for service. You might even get charged for a new lamp that you didn't need. That was what Epson Service diagnosed the problem as over the phone.
Dec 21, 2009 | Epson Perfection 3170 Flatbed Scanner
Paslode im350 has indicator light flashing red/green
The nailer’s electrical system has gone into overload protection. There may be something wrong with the fan motor or the wires going to the fan motor. Remove the cap and grill to inspect the red and black fan motor wires. If the wires are pinched or broken, that may be the problem. It may also help to disconnect the small white connector on the wire assembly that goes to the motor and then reconnect it.
Jun 22, 2009 | Tools & Hardware - Others
Hand held pro 83 scanner
http://support.radioshack.com/manuals/ome20-501.pdf
May 30, 2009 | Radio Shack Pro-82 Scanner
The wii wont turn off and the light stays green
Hold the power button on the console for 4 seconds, it should override everything keeping it on and the light will turn red. If this doesn't work sorry, thats all I know.
Apr 08, 2008 | Nintendo Wii Console
Minolta Dimage multi pro
Initially, I get a green flashing light when unit turned on, but after a minute or so, it turns to a red flashing light. It will take in the film tray only when blinking red, not when blinking green. My iMac has a hard time seeing the scanner, keep getting "scanner not found" messages. I have to go to system profiler and have it refresh and then it finds it, then the scanner software sees it too. But I have been unable to one preview out of it, says LED error and that's it. Using 10.4.10 on an iMac 20" with 2.5gb of RAM, using Pshop CS2 or going through Minolta Driver of OSX I got off of VersionTracker. I did remove the screw for transport right away. Will feed in 35mm tray with red blinking light, will not feed in 120 tray except partially with red blinking light, and only a couple times out of maybe ten tries.
Aug 23, 2007 | Konica Minolta Dimage Scan Multi PRO Film...
Scanner not responding to preview scan
Try this as a last ditch effort. Remove the software. Reboot the computer and come off line. Disable the Anti Virus program. Now install the soft ware. Then try. If the red light still flashes then assume it is new scanner time.
Jul 26, 2007 | Epson Expression 1640XL Flatbed Scanner
Computers & Internet Logo
190 people viewed this question
Top Zebex Computers & Internet Experts
David Payne
David Payne
Are you a Zebex Computer and Internet Expert? Answer questions, earn points and help others
