Question about Lomo graphy SuperSampler 35mm Film Camera
My pictures and negatives have a white line going threw it .
    Brigadier General:
  • 3,006 Answers
It's scratch along the film and will have been caused by either faulty film (very unlikely but not impossible), or it has been scratched when running through the camera or processing machinery (sadly both very common).
Open the back of your camera and lay a section of scratched negative over the back, emulsion side down, just as it would have been when taking photos. Use the scratch to guide you to find any rough/sharp points especially across the masking frame (the 36mm x 24mm rectangular hole in the camera which determines the size of the image). If you find none, then take your negative along and ask ask at the photo lab you use whether they have had any problems. They'll almost certainly say "no" but will then quietly check and rectify their machinery if they find dirt or debris stuck in there. Frequently the fault is in their sleeving machine which cuts up the negatives into shorter lengths.
Unfortunately, it's a problem which is far more common these days. Most 35mm film cameras are old and poorly maintained, or are just overpriced and badly made plastic toy cameras like the entire Lomo range. In addition, many people get their films processed at local minilabs and as they're used less frequently now the standards of operation and maintenance have generally fallen. I find that if I use a postal processing service the large commercial labs have better maintained machinery. The downside is that the local minilab will often give a more personal service with respect to getting an accurately exposed print and the large commercial lab will not unless you pay for a premium service.
Posted on May 08, 2010
I have a 4 in wide white line running threw my screen.
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the keyword "line fault" in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jun 17, 2016 | Televison & Video
Messed up screen
Hello. You might have to have your t.v. degauzed to remedy that problem.
Apr 01, 2014 | Gateway NE56R10u Laptop
Why does my camera have lines threw the picture and vidio that i take? digital camera w1200
Hi, It's likely caused by issues with the sensor that's within the camera. Are they consistent white lines and are they there in all modes?
Jul 14, 2011 | General Electric W1200 Digital Camera
Need a radio wiring diagram for a 97 Nissan Altima i found one on line but it wasnt nothing like the colors of the wires in my car.
red = 12v ignition/acc
yellow= 12v battery/memory
black = ground
blue = power antenna
blue/white = amp turn on
black/white = amp ground
orange = illumination
orange/white = dimmer (+)
orange/black = dimmer (-)
brown = mute phone
speakers---
grey = right front positive
grey/black = right front negative
white = left front positive
white/black = left front negative
violet = right rear positive
violet/black = right rear negative
green = left rear positive
green/black = left rear negative
Dec 30, 2010 | Car Audio & Video
The picture looks bent and looks 3d...my friend who sold me the tv had the same problem and she was able to fix it but she cant figure out how to do it now ... somthing about the red and blue being off...
In the tv menu settings there should be a convergence menu or alignment menu...you need to go here to re-align the red and the blue guns to display the proper picture...most projection tv's have a setup screen for aligning the colors..you want to line up the red and the blue to get as close to white as you can
Dec 21, 2010 | RCA HD52W59 HDTV Projection Television
1/turning the unit on the screen or panel is all white
You need to resolder the video IC processor they are one smd device
Apr 15, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Theres a line threw my tv.
It has a problem in the vertical sweep circuit that puts a nonlinearity in its output and you see the glitch in the normally gradual sweep as a line. Since a hit upside the set seems to help, you should just resolder the whole vertical circuit area (doesn't take long) and see if that cures it. If not, start replacing the electrolytic capacitors in that area.
Hope Ya Fix It!
Jan 08, 2008 | Televison & Video
Lomo graphy SuperSampler 35mm Film Camera Logo
Top Lomo Photography Experts
Hashim Khan
Hashim Khan
Tony Parsons
Tony Parsons
Are you a Lomo Photography Expert? Answer questions, earn points and help others
