Question about E-Machines eMachines Desktop PC
I disconnected 3 sets of wires from my start button and don't remember in what order or on what pins they go back to. The wires are labeled Power SW; Power LED; HDD LED. I j have an e-Machine T6520. Is there a wiring diagram I can refer to?
    Problem Solver:
  • 17 Answers
It should be printed on the motherboard itself. if not, go google emachine t6520 front panel connections.
Posted on May 11, 2010
Power on password - can't remember
Turn the computer off.
Disconnect the AC power.
Remove the side-panel to expose the motherboard.
Find 3 gold pins in a row, labelled CMOS RESET (or something similar).
Move the jumper from pins #1 and #2, to connect #2 and #3.
Count to ten.
Move the jumper back to its original position.
Connect the AC power.
Turn the computer on.
Enter BIOS SETUP.
Choose LOAD BIOS DEFAULTS.
SAVE the settings.
Jun 21, 2011 | Compaq Presario 5000 PC Desktop
Power switch hook up on e machine t3624 front panel as 3 hook up each has 2 wires with letter labels wire hook up r label HDD LED wires red white / labelPWR SW black white / label PWR LED wires blue...
This is not a photo of your motherboard. Please use it as a general guide on what to look for on your motherboard. Most brand name systems will have the connector pins placef on the edge of the motherboard that is closest to where the wires coming from the power button are being routed. Pay attention to a set of pins that equal the amount of connection wires you have. When you see it, look around the pins and you will see etchings that describe which wire goes on what pin.
NOTE: Please remove the AC cord from the computer and that all keyboard, mouse, video, network cable and usb slots are disconnected and empty. Do not power the pc until you are certain you have matched the connectors to the right pins.
Jun 01, 2011 | E-Machines T3624 PC Desktop
Hi sir the problem which i am facing is that i unplugged the 4 pins which are these rest sw,power sw, hdd led and + and - now i forgot how to place it back in right sequence so plz help me out thanks.
Hello myasinmalik,
this is a [Picture Diagram] of the {PIN Sequence], in the order of "Connections."
!Warning: "Before disconnecting, or connecting: Cables, Wires, Power Supplies, or Pins!"
"Unplug "All Power Sources" from {'Wall' AC - Power Outlets}."
This can cause "Injury to Persons, and or Damage to Equipment."
If this information helped? Return and give a "Helpful Rating," please!
Thanks, paul7of9
Feb 23, 2011 | Mercury P4VM800M7 Motherboard
Problem with panel front conector in Dell Dimension 2200 motherbo
The following information is to assist you in performing the right connections. You should take precautionary measures such as grounding yourself and completely disconnecting the PC form any source of power.
This picture shows the connector for the front panel power button, reset button, and power and hard disk lights: an 8x2 pin connector with 1 pin missing:
The table below lists the pinouts for the connector. The orientation of this table is the same as the picture above, this shows the top part of the connector. All the pins below pin 8 appear to be non-connected.
Each pair of pins labeled Power and Reset goes to the 2 wires for the corresponding button. The hard disk and power LED wires connect to the corresponding LEDs, you need to ensure the proper polarity of the + and - wires for each LED or it will not illuminate.
The above information is for your information only.
Mar 01, 2010 | Dell (2M502) Motherboard
CASE WIRES TO PANEL1 CONNECTIONS
The hdd red wire gooes to pin #1 the hdd white wire goes to pin #3 the power sw orange wire goes to pin #6 the power sw white wire goes to pin #8 The reset sw blue wire goes to pin #7 the reset sw white wire goes to pin #5 the power led green wire goes to pin #2 the power led white wire goes to pin #4.
Now the layout of the pins is the long row (5) pins are the odd number pins 9 being the odd one and 1 is the other end of the row. 2 through 8 start at the pin accross from 1 : : : : . I hope this helps you.
Aug 22, 2009 | PC Chips MB PCCHIPS SiS746FX M848A V5.0...
Configuration
Hi
The wires that read +5 -d +d and ground those are USB connectors each usb connector will have 4 wires, +5 -d +d and ground so that goes to usb pins.
The sw must be power switch
The HDD led is the load light
Reset is the reset button
Power led is the front power light
SPK is the speaker / beeper.
Can you tell me the brand and model of the motherboard? They are documented in the user manual. but generally in the bottom right corner of the motherboard you have the connectors for the leds and buttons, its all written into the motherboard with small white text. but I can get clear instructions from the user manual for you.
You can look for the motherboard details between the expansion slots and between the cpu and memory.
Thanks,
Ekse
Feb 03, 2009 | Intel SVM266A VIAP4M266A (SYNTAX SVM266A...
Connecting startup leads to ABIT NF7 motherboard
Below is a link to the manual for this motherboard, It should be able to show you where each of the leads on your dislocated panel wires go to.
http://www.uabit.com/index.php?option=com_content&task=view&id=32&Itemid=48&page=6&category=5&subcategory=247&model=8&product_name=NF7
Hope this helps
Thanks
Dave
Nov 20, 2008 | Abit Computers & Internet
Hooking my Neo4 mobo back up.
Hi weeman105, case wire colors do vary from case to case. The most common case wire colors for negative are "white & black". All other colors like blue, green, red orange are most commonly "positive". The four pin connector with only the ends with wires is the internal speaker. Most boards use one set of pins where you hook everything up. The MSI K8N Neo4-F uses two separate motherboard pins, Front Panel Connectors: JFP1 & JFP2 as shown on the top page 2-19. Now that you know what color is positive & which is negative things should work out just fine.
Downloaded manual from MSI link: http://global.msi.com.tw/index.php?func=downloadfile&dno=4117&type=manual
If you run into any other troubles, just post & we'll go from there.
Good luck weeman105!
Mike
Sep 13, 2008 | MSI K8N Neo4-F Motherboard
Gateway wont turn on
Usually in the motherboard it tells you where those plug correspond to the board. to you see and pins on your board that are labeled?
Jul 05, 2008 | Gateway 507GR PC Desktop
Icute to motherboard wiring
Hi, on the edge of your mother board closest to the front of the computer, you will find a double row of pins. Use a torch and if needed a magnifying glass and study these, you will find they are labeled the same as your cables from the case.
In some cases the plugs are set as a 3 space plug, if you find one of these that wont fit. just split it. If you plug the LED wire back to front, don't panic it won't hurt they just wont work. The power and reset are not pole sensetive.
Goodluck mistyman
Dec 23, 2007 | Computers & Internet
E-Machines eMachines Desktop PC Logo
446 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
