Question about Music
N12 and new Mac book pro with FireWire800
I've just bought Yamaha N12, download and installed most recents drivers + update AI4V4.5.2. It's working fine on PC/XP. No crackles at lower latency . it's Fine! I have also a Mac Book pro/i7 with only fireWire800 port. I have cord adapter 9pin-6pin and I would like to know if N12 could be work with this mac? I didn't try at this time cause I feard to have MAC or N12 firewire port screwed!
thanks for your help
  • Music Master
  • 5,603 Answers
As long as you power the devices from the same receptacle or plug strip the MAC will be perfectely safe. Firewire and USB are fairly safe as long as you don't drive high voltage into them from failed equipment or ground loops.
Posted on May 08, 2010
How do I download files from my yamaha portable grand DGX-230 to my computer
To download/transfer files to computer, you need 2 softwares from yamaha website. USB MIDI drivers and MUSICSOFT DOWNLOADER.
Install drivers first,and then Musicsoft Downloader.
Connect keyboard to PC/notebook by USB cable.
Run Musicsoft Downloader.
If you click "Electronic Musical Instrument" in the Musicsoft Downloader display.and then "System Drive", a file named "08PG76BUP" will appear in the lower right corner of the Musicsoft Downloader display. This is the backup file that will transfer to computer.
Usually yamaha came with CD-ROM that contain divers and softwares + user manual,so you don't need to download.
I hope this helps.
Regards.
Sep 01, 2015 | Yamaha Music
Voyetra midi orchestrator
The only Voyetra Midi Orchestra Plus software I can know was written for Windows 3.1 and Windows 95. Thus there are several reasons for it to be incompatible with Windows 8. First, it was a 16-bit software; the most common Windows 8 installs use a 64-bit OS. This means that the OS has undergone a number of major changes. The installers are completely different (format/way of talking to the OS). The DLLs that communicate between the software and the OS have also changed. The drivers for MIDI devices will be totally different in the modern OS.
The documentation for Voyetra Midi Orchestra is available here: http://www.turtlebeach.com/support/files/241/ . It is a discontinued product and no one at the company that owns it will be writing a new version of the code for Windows 8. I'm not sure this software will work in Windows 7 32-bit. You might be able to use the software in a compatibility mode from a virtual version of XP. For Windows 7 Pro, Virtual PC and the XP mode package are available as free downloads and can be used if your hardware allows. Windows 8 Pro has Hyper-V but requires a licensed version of any Windows OS that you want to use. For non-pro versions of Windows software, you would need to buy a Pro upgrade. The alternative is to obtain another Virtual machine software (VMWare, for example) and a licensed copy of XP or an older version of Windows. (OEM Windows 7 Pro licenses are still available from many computer hardware vendors.)
I hope this helps.
(Many 32-bit device drivers don't work under Windows 8; older software that didn't run under Windows 7 have similar problems.)
Nov 29, 2013 | Yamaha Music
My yamaha psre323 does not connect
I have a PSR-E323 and to connect it with my pc using a MIDI connector should i install driver from http://download.yamaha.com/usb_midi/ ??? I tried to install that.. An error msg popped up... error 25001 no device is connected. connect a device and try again. If the "found new hardware" wizard appears push the cancel button...What should I do?? Help me pls...
Apr 10, 2012 | Yamaha PSR-E323 Keyboard
I have a dgx-505 yamaha without the installation cd and i want to use it with my computer HP Windows 7 64bit. All the drivers i found only worked on XP, 98/99 and 32 bit.... PLEASE HELP ME!
I know this is an old post, but I just found my own solution to the same problem. I downloaded the 64 bit driver for the CP300 keyboard and it worked.
Sep 14, 2011 | Yamaha Full-Size Keyboard
G5 is flat. How can I bring it up to pitch?
Is your question about G5 ppc mac. or about Suzuki g5 motor cycle.-------------I assume its about g5 ppc mac.-------
Try downloaded the latest version 2.5.1 to update the 2.2 version;.---------- 1) Open Finder and go to the Macintosh HD -> Library -> Receipts folder. In here you'll see the Pitch 'n Time Pro 2.5.1 Installer.pkg file - delete this.
2) Go to the Macintosh HD -> Library -> Application Support -> Digidesign -> Plug-Ins folder. In here you'll see the Pitch 'n Time Pro.dpm file - delete this.
3) Run the Pitch 'n Time Pro installer again.
----------------- If there is no installer.pkg. File.Then However,you will see these other two files as follows :---Pitch 'n Time Manual.pkg-------
Pitch 'n Time PlugIn.pkg--------
Delete this files.-------- Then try installing latest version and see.--------- ------------- Check out, keep updated, thanks.Helpmech.
Jul 31, 2011 | Suzuki 25Note Chromatic Tone Chime Set
Installation of driver usb yamaha to host
The best thinkg to do would be to use the Yamaha's support section on their website to find the latest driver pack for this keyboard.
Once you have downloaded this, just run the install file and this will load all the vital files you need on the computer.
Aug 31, 2009 | Yamaha Full-Size Keyboard
When I plug the usb cable in to my computer and "open USB," it does not show up as a removable disk. I have used this function on the mkII many times before and this is the first time I have had a...
Hi I had exactly the same problem with my Macintosh, it worked fine until recently but suddenly stopped working. As a matter of fact it is probably due to a compatibility issue of the USB driver after a recent software update of MacOSX drivers. Fortunately I have an old Macbook pro with an old version of MacOSX and the Tascam showed up immediatly and USB worked fine. Therefore, if ou can downgrade your USB driver it might solve the problem.
Jul 08, 2009 | Tascam 2488mkii 24 Track Recording...
Tascam 2488MK11 hard drive problem
Jun 27, 2009 | Tascam 2488mkii 24 Track Recording...
Music Logo
160 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
