My Rheem Ruud 25M01A water heater flame goes out before the thermostat is satisfied. The igniter goes into a ignition sequence from here on trying to get the flame to ignite for ever. If i turn the unit off for a few seconds and then back on the igniter continues its on/off dance. If I keep the unit shut off for about 10 minutes it starts up as it should, runs for a while end stops premature. I have replaced the flame rod, it did not change anything, but I noticed that after the flame starts up it goes full flame, nice and blue then after about two minutes the flame goes smaller to about half the normal size and its color turns to orange/yellow for a minute before the flame shuts off. I had a service man in here right from the start but he walked away stating that he would be back after he got some more information from whoever he was going to get it. That's four days ago now.... In the mean time I have been trying to get some warm water back in the house. Please could you give me some help with this? Thank you. joe_van_rooyen@hotmail.com
  • 674 Answers
Check the air lines going to air pressure switch for cracks or splits. I know that will affect the gas valve but not sure if that is your problem.
Posted on May 07, 2010
  • Brian Niten May 08, 2010
    Have you checked the combustion air openings to make sure they are not blocked? Also, I've been to the rheem website trying to find you model and can't get anything. Do you have a schematic you could send me?
Rheem Rudd G91-200 will not start. After waiting 10 minutes, it does fire up for about 2 minutes, then it locks out. Bad gas valve?
ive never seen one of these water heaters but most gas apps have a thermo-couple which the ignition flame needs to heat the top of.if the ignition flame is missing the top of this the main gas valve will shut off.it may just be a bit of dirt in the flame director.which aims gas at the couple and main gas burner.hope ive helped.good luck
Mar 16, 2013 | Rheem Tank Water Heater G91-200, 91 Gallon
RUUD PVP75E-1 Gas Water Heater short cycling
1) Copy following link to troubleshoot by type of gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
2) Otherwise Rheem-Ruud does not post service manuals
http://www.ruud.com/products/tank_water_heaters/gas_water_heaters/
3) Sound like bad gas control valve thermostat.
Newer Honeywell electronic controls can be replaced without draining tank.
Older mechanical controls are replaced by removal from tank after tank is drained.
Feb 01, 2013 | Water Heaters
Ruud PVP75E-IP Water Heater
Rheem-Ruud does not post service manuals.
Tank-type?
Copy following link to troubleshoot by type of gas control valve.
Tankless? Don't buy a tankless.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Oct 06, 2012 | Water Heaters
Rheen PVW50 Hot Water Heater Making Buzzing Noise and Doesn't Light
Why is it always Rheem problems?
Every water heater problem is Rheem.
And Rheem doesn't post any service manuals, like the other two big manufacturers, AO Smith-American, and Bradford White.
Copy following link for troubleshoot by gas control valve.
Scroll up and find pressure switch heading among links.
You can install gas control valve yourself.
http://waterheatertimer.org/pdf/How-to-replace-water-heater-gas-valve.pdf
Sep 06, 2012 | Rheem Water Heaters
No hot water. Constant beeping at the tank. Tempature gauge flashing 11.
Before calling service technician, open following links for Rheem troubleshoot resources including Rheem chat and typical service manual and typical product manual.
Error codes are start place for troubleshooting:
Error 11 is 'gas is inadequate' or 'ignition failure'
Open gas valve so handle is parallel with gas line.
Bleed air from gas lines.
Check that appliance is grounded.
Check igniter wires and harness for damage.
Check that vertical vent length does not exceed limit.
Other causes: Gas inlet solenoid valve, bad igniter, solenoid valve, flame rod.
Jun 14, 2011 | Rheem Tankless Hot Water Heater...
I have a 2 year old rheem power vent water heater model # 42vp50fw. It suddenly stopped working. It will try to ignite. The igniter will glow and the call for gas will ignite the burner. After a few...
The flame sensor is bad....and it is not sensing that the flame has lit....
Some models have a separate flame sensor and some use the ignitor to sense the flame...
If it has a separate sensor then clean it with a soft cloth... if it is the ignitor then the ignitor is bad...
heatman101
Nov 25, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
Water heater not firing up
Make sure thermostat is turned to 120 to 150 degrees Fahrenheit. Turn the thermostat down and back up to see if it ignites. If it lights put the cover back on and set it to temp you want it to be. if not, you have a bad thermostat.
Hope this helps.
Aug 14, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
Rheem powervent ignites then goes out, electronic ignition.
Sounds like a bad thermocouple. This part sends a millivolt signal to keep the gas valve open but shuts it off when it cools - or if something goes wrong with the ignighter - to prevent fires. It's easy to replace and not super expensive. See your local Rheem dealer.
Aug 13, 2009 | Water Heaters
Heating & Cooling Logo
186 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
