Question about Saeco Magic De Luxe Espresso Machine
The grinder only grinds the beans very coarsely, resulting in weak espresso. Adjusted the lever several different ways with same result. Can't figure it out! Help! Haven't had good coffee! Can't think! Also took out the top part of the metal grinder and realigned it several ways. There is red and blue nail polish in different spots to help with the alignment, but I don't know what it means.
    President:
  • 1,618 Answers
First ignore the numbers on the adjustment knob, lets fix that, with the grinder running turn towards fine as far as you can, then check grind if it is not fine enough, then remove screws in bean hopper and lift slowly until you can turn the knob without it touching the gears and move it towards coarse say #12 or so, then lower hopper so that knob sits on gears and repeat the testing until you get the best shot of espresso. Just move toward finer.
Posted on May 07, 2010
Grind time is short, puck is wet and sloppy, espresso weak
Sounds like you might have more than one problem.
From page 12 of the manual... NOTE THE LAST LINE.
"8. ADJUSTING THE GRINDER
• Open the lid of the bean container.
• While the grinder is running turn the grind selector switch to
the desired position (Fig. 6).
-The smaller the dots, the finer the grind.
-The bigger the dots, the coarser the grind.
Important:
The grinding grade can only be adjusted while
the grinder is actually grinding."
Sep 08, 2014 | Jura Capresso Impressa E8 Espresso/Coffee...
Gaggia Titanium Weak coffee medium cup only produces a dash of water and weak coffee, also the ground is very course and I am going through lots of beans done the cleaning and re-calibration but still the...
The coarse grounds is definitely the problem. make sure your machines setting are near 5-8 depending on the beans you use.
You need to make 5 cups of coffee before you see the new grind size. Do not change the grind too often or you will not see what you are looking for.
If the coffee is still too coarse you may need to replace the grinder burrs. http://www.cerinicoffee.com/grinder-burrs-saeco-gaggia-asp.html
or you should take it to a service center.
http://www.cerinicoffee.com/espresso-parts/espresso-machine-service-center-new-york.html
Aug 11, 2013 | Gaggia Titanium Espresso Machine
My coffee is weak. i have played with the grinder, placing it at different no. on the outside plus i have played with adjustment on the interior.
Hi
Check the grinds. If they are coarse you have a separated grinder. It usually means it needs to be replaced I have seen them on ebay, but if you can't find them, I have some. If they are not coarse, you have to make 3 coffees before the grind will take affect. After you change the grind you have to make 3 drinks before you will see a change. If you don't have a puck in your dredge drawer, you don't have enough coffee going into the brew unit. Push the lever behind the door in the center top back to the +, then forward 1 click, and try that. There should be a full puck going into the dredge drawer that has the consistency of coarse sugar. If it very coarse its the grinder.
Dec 12, 2010 | Saeco Magic De Luxe Espresso Machine
The user manual doesn't discuss cleaning the grinding unit. Should this be done and if so how is the best way to do this?
HI
The easy way is to push the lever below the bean hopper to the 7 and make 2 coffee's. Then when the grinder is grinding on the second coffee, pull the lever back to where it was. The coarse grind that you get with the lever bqck works like a cleaner and removes fine particles that accumulate in the grinder. If you are using a shinny bean do it twice before pulling the lever back.
Oct 23, 2010 | Saeco Magic Comfort 103467 Espresso...
Machine says beans are empty and will not brew.
Try adjusting the grinder coarser when it is running. Either the grind is too fine or the grinds chamber is blocked, remove the brew unit and check the gate to the grinder on the inside right.
Jul 30, 2010 | Saeco Magic De Luxe Espresso Machine
Saeco Italia coffee too weak - grindes too coarse
Remove beans from chamber, then remove the 2-3 screws in the chamber, then lift hopper slightly and turn adjustment knob towards the middle number, or halfway between fine and coarse. Then lower hopper make sure the gears line up together, set screws add beans and adjust finer.
Oct 08, 2009 | Starbucks Saeco Italia Digital Barista...
Saeco De Luxe Coarse Grind
You could have knocked it out of its shaft or worse, Cracked the shaft itself.
Settings could be off too, It fairly common. Recheck the chamber, and make sure the plastic casing isn't cracked and the grinder doesn't wabble at all. It should be fairly firm.
If it isn't firm, bad news, cracked shaft.
May 08, 2008 | Saeco Vienna De Luxe Espresso Machine
Coarse Grind
il y a de l'eau qui passe en dessous du plateau avec du café moulu
Grind is too coarse and "pucks" are wet and fall apart.
You say " I am getting a weak brew because of not being able to adust the grind to more coarse with the adjustment knob in the bean hopper" By making it more coarse you are making it weaker. Unless you just wrote it wrong. To make it stronger you should lower the grinder number to a smaller number. Usually about 4-6. Be sure you have the grinder grinding when you move it to a lower number. The pump noise could be that in shipping your pump came loose from it's mount. Nothing you can do without sending it to a Authorized Saeco Repair shop.
Jun 04, 2007 | Saeco Vienna Espresso Machine
Saeco Magic De Luxe Espresso Machine Logo
240 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
