Question about Kenmore Kitchen Ranges
Where is my ignition switch and how do I install a new one? Jenn Air Model # SCG20200W
    President:
  • 1,015 Answers
Remember to disconnect the power before you start working on the range. There are igniter switches located at each burner valve. You will need to remove the burner knobs and then remove the panel that covers the front of the burner valves. Once this panel is removed you will then be able to see the ignition switch on the burner valve stem. Now you will need to locate the defective switch. Once wires are disconnected the switch should slide away from the burner stem. Then you can reverse the installation process with the new switch to finish the job. The switch can be located here http://www.appliancepartspros.com/part_details.aspx?part_id=4101554
Be gentle with the part because they are plastic and can be damaged if forced.
Posted on May 08, 2010
Jenn Air JGR8750 - Oven heats _very_ slowly; take 45 to 60 minutes to heat to 450ºF. I can hear faint ''whump whump whump'' from the oven as it heats. Purchased in 1998.
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Sep 28, 2010 | Jenn-Air JGR8750 Gas Kitchen Range
Jenn air downdraft cooktop. We had a new Jenn Air
This is normal, Jenn Air along with many manufactures use one ignition module for all the burners. So when you turn one knob on all the ignitors on top will spark but gas will only flow to the burner with the knob on.
Here is a copy paste from a Jenn Air Owners Manual, I do not have your model number so I cannot be sure this is the exact phrase in your book.
I hope this helps!
To Set:
1. Push in and turn knob counterclockwise to light the burner.
All surface burners will click. Only the burner that has been
turned on will produce a flame.
2. Turn knob to anywhere between HIGH and LOW. Use the
following chart as a guide when setting heat levels.
May 02, 2010 | Jenn-Air Freezers
All cook top burners spark when any is turned on
OK, the best action is to call for service, if the unit was just installed, and purchased. This unit should be covered at this time, by the manufactures warranty, or store 30 day warranty. This repair should be free. The culprit will be a faulty spark ignition switch, and module. Testing is required. Once this switch, or(module), is replaced, the unit will operate correctly.
Nov 04, 2009 | Jenn-Air JGC8430 Gas Cooktop
How to replace spark igniter - Jenn-Air SEG196 gas-electric range
took off the knob to the ignition system to clean and spray got onto the ignition under the dial and now the two front burners won't ignite unless I turn on one of the functional back burners then turn on the front burner. How do I repair this?
Jan 22, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
Switch assembly
See www.whirlpoolparts.ca/parts and enter in the model number. You will seea 10 page parts repair list including switch and ignition assemblies. Good luck
Aug 06, 2008 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Front igniters intermittent - how do I get the top off?
The igniter are too far need to adjust /if you connot reach to take a butter knife use two step ladder.
Aug 06, 2007 | Jenn-Air JGS8750 Gas Kitchen Range
Jennair gas stove
500 dollars shoud do just fine
May 22, 2007 | Jenn-Air JGS8750 Gas Kitchen Range
Jenn-air downdraft fan not working
there are 4 wires for that red white black and green sure you didnt miss a wire
Apr 15, 2007 | Jenn-Air JED8430 Electric Cooktop
Kitchen Ranges Logo
100 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
