Question about Acer Computer AOA150 Notebook
I can not record anything on my internal microphone on my Acer Aspire One. I am having problems recording things. My computer says I don't have an internal microphone even though I really do. I accidentally uninstalled my internal microphone and now it says it doesn't even exist on my computer. I have been looking everywhere to find drivers for my microphone and I have made sure it isn't muted.
    Guru:
  • Acer Master
  • 468 Answers
You can reinstall it. Click on Start Menu> All Programs> Acer erecovery management> Restore> Reinstall Application & Drivers> Select the appropriate sound driver (Realtek) and install it. Also visit http://support.acer.com/drivers_download.aspx
and select the appropriate model number and sound driver (realtek)
Posted on May 09, 2010
Why dont i have an internal recording device?
you have an internal recording device. It consists of a built-in webcam and microphone. to make a recording, use the cyberlink webcam program that's pre-installed on your laptop. you'll find it listed somewhere in the start / all programs list in windows 7. also, for sound recording only, the windows 7 audio recorder is located under start / all programs / accessories / sound recorder. select it and click the red record button. also, windows 7 has a feature or program called problem steps recorder. it records activity on your screen including mouse movement. i don't know if it records sound. to access it type psr in the search window and select psr in the search results, then click on start record.
Apr 14, 2014 | Acer aspire 5733z4851 intel pentium...
ACER ASPIRE 5536 MICROPHONE
Do you have an internal microphone? If not plug an external microphone into the microphone jack. Look at your Audio/Sound properties to see if the volume is turned up, not muted and that there is a microphone and it is selected as a device. Most times you can right click on the megaphone down at the bottom right near the time and select properties to get into the audio properties.
One other thing you can do to test the sound is to click Start/Programs/Accessories and look for sound or sound recorder. It might be under Entertainment after you click Accessories. Open the sound recorder and you can do a simple test. It will allow you to do a voice recording, save it and play it back.
You can also click Start/Control Panel and look for Sound and Audio Devices there.
Apr 01, 2012 | Acer Aspire 9410-4317 Notebook
Acer aspire 4720 microphone problem
You can try these steps :
1. Goto Start >> Control Panel >> Sounds >> Recording.
2. Open the 'Microphone Properties' from the list of devices.
3. Change the status of 'Device Usage' to "Use this device (Enable)".
4. Apply settings and close the window.
5. If still the Microphones are not working, try to reinstall the Audio / Sound drivers. Restart your system.
please rate this advice if it helps.....tc! :)
Jan 11, 2010 | Acer Aspire 4720 Notebook
Skype video using Acer Aspire Mini Laptop camera?
If you have a WEB camera you need to configure your video Webcam settings. Open Skype click on Tools - Options - Video Settings - select your Webcam model. When you open Skype click on Tools - Options - Audio Settings and click on Microphone and select the microphone you are using and save the setting.
If you still have problems with your mic. then - To test if the microphone is working, go to Start - Programs - Accessories - Entertainment - Sound Recorder and record you voice. Can you see your voice recording, the green line should vary as you speek.
If you see a flat green line, then the microphone is either faulty or the wrong microphone is selected.
Jun 15, 2009 | Acer Aspire One AOA150-1949 Laptop
Acer Aspire internal mic won't work.
You need to check the record settings and make sure the mic is not muted or turned down to low. Click START, CONTROL PANEL, then SOUND icon. Click the AUDIO tab up top. Make sure that your sound card is selected in the drop down menu under Sound Recording. Now click VOLUME tab. A new window will open up. Click OPTIONS then PROPERTIES. Make sure you have a check by the MIC and click OK. In the Recording Control window, turn the level up for Microphone and make sure it is not muted. Let me know what happens.
May 02, 2009 | Acer Aspire One PC Notebook
Internal Microphone not working
This is not a problem with mic. Settings in System was changed so that mic has been muted. To enable goto contol pannel and Select Sound & Devices and Select Advanced in Device Volume there you will get Master Volume Settings Menu So that uncheck the Mic option and check for Mic Setting in that.
hope this will be helpful.
Thanks & Regards Nanda Kishore.
Apr 10, 2009 | Acer Aspire One Netbook 8.9" Notebook
How to record sounds using external mic on acer aspire 4315???
go to the sound recorder available at start ---> programs ---> accessories then entertainment ----> sound recorder.
click on edit -----> Audio properties -------> default input device and change it to the external Mic you have connected.
let me know if this helped, good luck :)
Jan 05, 2009 | Acer Aspire 4315 Notebook
My microphone on my acer aspire one isnt working
This solution works for the Windows XP version. Go to msconfig.exe, then the Startup tab. UNCHECK rthdcpl and restart. Realtek driver doesn't load, but who cares...the microphone works now.
Aug 09, 2008 | Computers & Internet
Recording and sound card
Reinstalling your software for soundcard may help solve your problem. :)
Aug 07, 2008 | Acer Aspire 5630 Notebook
Internal and external microphones don't work when used for speech recognition
My brother was having the same problems,
U need the exact speech recongnition software drivers for windows vista. The EXACT DRIVERS!
Oct 10, 2007 | Acer Aspire 5630 Notebook
Acer Computer AOA150 Notebook Logo
325 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
