Question about Poulan ES350 16" Chain Saw
Replacing gas line
How do you replace the gas line and the air line when the old lines are not there? (rotted away) Its a 16" Poulan 350
    New Friend:
  • 100 Answers
Your fuel lines are routed like the schematic below. I suggest you replace the filter, all hoses (2 different sizes), and the purge button (bleeder).
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
Posted on Mar 31, 2012
    President:
  • 2,220 Answers
I find no Poulan 350 gas saws. A Poulan ES350 is electric. I think your saw is a Poulan "PP3516 Poulan Pro Gas Saw Type 2" and a link follows (may not be your saw):
http://www.ordertree.com/modelinfo/PWE/PP3516-Poulan-Pro-Gas-Saw-Type-2/75.PP3516-Poulan-Pro-Gas-Saw-Type-2.1.59.1.html
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best. Fuel components and part numbers are listed but may be on different illustrations. They are also beneficial with disassembly/reassembly:
Poulan.com (all models)
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on May 07, 2010
Where to get replacement fuel line for edger
Your local hardware store and ebay has a great supply as well.
Apr 20, 2014 | Poulan Pe550 Gas Edger
Fuel lines have deteriorated and need to replace
I just took mine to a local Poulon Repair shop about 16 miles away and they replaced the lines and the grommet and only charged $6. You can find someone in your area through the Poulon website:
http://www.poulan.com/service-locator/
Aug 23, 2013 | Poulan 25cc 2-Cycle Gas Powered String...
Replace fuel line on poulan 1975
Hi Will...
I think this is what you need
Please take time to rate me
Bud
Mar 17, 2013 | Poulan 14" Chainsaw
Remove gas tank poulan 25
Have the same question on a 2450 poulan, my gas line rotted and need to somehow replace it.
Jan 21, 2013 | Poulan 14" Chainsaw
How do ireplace gas filter in poulan 2055 chain saw?
the fuel line rots apart you need to replace the line pull the old hose out take a new hose cut down about a half inch cutting the line to about 1/3 slide a stiff wire down the hole and out the gas cap slide the hose over the wire and slide it back til the cut back end pops out put the filter on the end and pull it into place cut to size and install on the carb
Sep 01, 2012 | Poulan 2050 2055 2975 2150 2155 2175 Air...
I have an 18" Poulan chain saw, 25th Anniversary
Yes there is.If you can get the broken pieces out of the tank.there should be a filter on one of the broken lines.you will have too buy some gas line 3/16.take some wd-40 and spray the line.this makes it easier to slide through the hole in tank.then loop it around to gas cap hole and reinstall filter.then make sure filter is at bottom of tank and hook back to carb.
Nov 24, 2010 | Poulan P4018WT Wild Thing 18Inch 40cc...
Ive replaced the fuel lines that have rotted out. but it doesnt run like it did before. what should i look for
Depend on for how long the saw has been used.When the time past over the head cylinder cloaks with heavy carbon sediments that avoid a proper spark gas mixture.
1-Try to change the spark plug.
2-Made a good gas oil mixture.
Oct 12, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Fuel lines have rotted off. need to replace then
Mr Tittle;
It isn't good but it's all there is.
What little fuel system system detail there is can be found here:
Poulan.com
If it is a 2375 WildThing find 2375LE Gas Saw Type ?. The last digit of your serial number should be a -1 or -2, the type.
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The filtered hose from the fuel tank connects directly to the carburetor input connection.
  • If the saw is equipped with a primer, the output line from the carburetor connects to the suction side of the primer bulb (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill the bulb as the bulb reinflates).
  • The pressure side of the primer returns any excess fuel to the tank as it is depressed.
HTH
Lou
Oct 24, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I need a repair manual for a McCullough gas, 35 chain saw
Mc chain saw fuel lines rotted away need to know where they go
How the primer lines go! There are 2 outlets on carb. two tank lines two primer lines
Jan 11, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Poulan ES350 16" Chain Saw Logo
1,184 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
