Question about Champion G5NG853S Household Juice Extractor
Juicier will not work at all
I have been using my juicier for months and I had problems before with circuit breaker on outlet I have been using replaced before jucier worked fine then after using juicier several months in a role the breaker on outlet starts to kick of several times yesterday I was trying to get through with my juicing so I continued to use it everything was fine monday of this week I had these problems used juicer Wednesday it was fine. I started to use it today nothing it will not turn on at all.
    Brigadier General:
  • 4,088 Answers
Try the juicer on another circuit to see if the breaker failed altogether on the circuit you were using. It's possible that the machine is drawing more power than it should and may need to be checked by an appliance service dealer. An electrician can also check the power draw at the breaker to see if it is being overloaded. If the machine itself is defective, it should receive professional service. Good luck!
Posted on May 07, 2010
Yesterday by juicer kicked of the kitchen breaker? Twice.
You may just be overloading the circuit. Easiest correction - unplug something else that's running (or turn off a light) on the same circuit and see if the breaker still shuts off.
But wait - also important - was there any burning smell? If so, this is dangerous. It's a short circuit that occurs when a "hot" wire (black) touches another hot wire or touches a "neutral" wire (white) in one of your outlets. You should not use that outlet and have an electrician look at it. Or it could be a ground fault (similar to the short circuit - when a hot wire touches the ground wire on the side of a metal outlet box which is connected to the ground wire. For either of these, you need an electrician.
Apr 05, 2017 | Juicers
Is it possible to blow a fuse in the JEX 328?
yes it has a thermal fuse inside, small as an aspirin rated at 8-10 amps about $ 5.00 us we have replaced most with a reset button circuit breaker , best idea I came up with for $ 12.00 us
Mar 25, 2014 | Waring JEX 328 Health Juicer
Cuisinart juice sqeezer throws circuit breaker
Is this a new juicer, have you used this before without the circuit failure?
Most circuits in the house will be are 15 amp breakers. If the appliance has a high amp load then this can cause it to switch the breaker turning on or off.(due to to voltage spikes) I have a waffle iron that does the same thing if my refrigerator cycles while the iron is on.
There are a few things that could cause this. But before anything else I would try the juicer in a different plug that is on a different circuit, like the living room for example. If that works well then I would start looking at you may need to replace the circuit breaker, they do go bad.
Apr 05, 2012 | Cuisinart Juicers
Loud "pop" noise as if
The reset button is actually a circuit breaker in miniature but there may be a thermal fuse to protect against fire in case of failure of the circuit breaker.
If you are game, open the housing again and look for a device you don't recognize that is in series (in line) with a wire; it may be in an insulating sleeve and not immediately visible, appearing only as a thickening of the wire. This could be a thermal fuse.
They are not supposed to open under load but only when the temperature exceeds a limit and these do not reset. Unfortunately, these are now all coming from China and are not very reliable so may open even when the design temperature is not exceeded.
If concealed, you would need a simple multimeter to determine if it had 'opened' by checking for the continuity of the wire stretch.
Blenders in general are 'universal' motors which can use AC or DC and this type employs carbon brushes which do abrade with time and when they have become too short, they can become intermittent and cause such a popping sound too. Brushes are replaceable so you might check Waring's website to see if they offer a fixed-price replacement or brushes as replacement parts.
I would be prone to see the Waring restored since most replacement blenders are from China and have often more than just one problem even when new. One given to us as a present smoked while crushing ice so we retrieved our old Oster from its stash and tossed the oriental wonder.
Jan 09, 2011 | Waring Juicers
Motor failure
First, turn off the power at the circuit breaker and look for a small reset button. There should be one. If not, leave the juicer on off - and turn the circuit brkr. back on, and try again. If this still doesn't work. Check and see if you're plugged into a GFI receptacle, which has a little reset button on it. In fact, you can check this first. Good Luck to you! Feel free to contact me again if this doesn't work for you. - Jim
Mar 29, 2010 | Breville BJE200XL 700 Watts Juicer
Need Power Juicer manual
If you go onto the website powerjuicer.com scroll down to the bottom of the screen and click on customer care. You can then select the option Power Juicier Manuals and select the model you have and print it. Hope that helps!
Nov 09, 2008 | Jack Lalanne Power Juicer 250 Watts
I bought a home with no home inspection and i have a little electrical problem in the basement area. the house was built in 1978. it looks like one of the previous owners did the basement.basement looks...
POSSIBLY THE EASIEST THING IS FIRST TO DETERMINE ALL THE THINGS THAT ARE ON THE CIRCUITS IN QUESTION AND WORK FROM THERE , AT LOWE'S OR HOME DEPOT OR A GOOD ELECTRICAL STORE YOU CAN PURCHASE A DEVICE CALLED A CIRCUIT FINDER THAT WILL HELP YOU FOLLOW THE CIRCUIT FROM THE PANEL TO EACH PLUG IN OR LIGHT FIXTURE , WHEN YOU GET IT ,It WILL COME WITH DIRECTIONS ON ITS USE IT SIMPLY PLUG IN OUTLETS IT WILL SAY TO PLACE OVER BREAKER BUT SINCE YOU ARE WORKING OUT OF A FUSE PANEL DO THIS PLUG INTO OUTLET YOU THINK IS THE FURTHEST FROM PANEL AND PLACE DEVICE OVER OUTLET NEXT CLOSEST CHECKING BACK TOWARD IF YOU NEED TO PLUG INTO LIGHT FIXTURE USE THE SCREW IN 2 PRONG PLUG LIKE YOU WOULD SCREW IN TO HOOK UP A EXT CORD ETC CHECKING FOR PROBLEMS ALL THE WAY BACK TO AND INC THE FUSE PANEL BY DOING THIS YOU SHOULD BE ABLE TO DETERMINE THE CIRCUIT ROUTING AND HOPEFULLY FIND THE PROBLEM ,HOPE THIS INFO USEFUL
Oct 20, 2008 | Champion 2000+ Household Juice Extractor
Will not start
Junk it and buy an Omega, they at least have a decent circuit breaker. Mine quit after starting it and the breaker won't reset. Fixed it with a car fuse.
Jul 14, 2008 | Juicers
Juicelady juicer dead after 10 uses
This may sound silly, but have you tried plugging it in to a different outlet in your kitchen-i.e. (as in an outlet that is on a different breaker? or fuse?) I thought our slow cooker was toast--& it was the outlet, not the unit. When we are busy or tired & frustrated sometimes we can overlook the simpilest things.
Is it possible you have a defective cord? Taking it to a repair place is your best bet if either of those ideas don't help. Call to get an estimate first--call around to parts & repair depots in your city/area, as the cost can vary widely. Some are very reasonable while others make you wish you'd replaced it instead!
Or ask around for a retired repairman that does repairs occasionally. They often charge a lot less-but you may have to pick up the part once he/she's identified the problem. Also--trade schools that teach repairs to small appliances may fix it for a nominal fee--or even just for the cost of the part--if a part is involved.
Hope this helps...
Jul 02, 2008 | Juicelady JL500 Juice Extractor
Champion G5NG853S Household Juice Extractor Logo
194 people viewed this question
Top Champion Juicers Experts
David Payne
David Payne
ray gallant
Are you a Champion Juicer Expert? Answer questions, earn points and help others
