Question about Garden
Need to change the drive belt on a john deere 155c
Need to change the drive belt on a john deere model 155c lawn tractor
5 Suggested Answers
  • 548 Answers
SOURCE: can't get front wheel off my john deere lawn tractor
remove the cap on wheel then there is a ring or cotter pin to remove then pull wheel off
Posted on Aug 22, 2009
nova2nv
  • 197 Answers
SOURCE: John Deere Lawn Tractor LX176. Battery discharge
Locate voltage regulator above battery to the left as you sit on machine,its behind frame that supports steering wheel.Once you have found it use a light to shine on harness and follow the brown wire that leads into regulator.The plastic around that wire should not be burnt or showing any other color.The LX series machines had a problem with brown wire coming loose and causing the charging light to stay on.Remove plug from reg and use small screwdriver to clean out wire and work it a little so it makes good contact.
Posted on Nov 13, 2009
farmerbear
  • 490 Answers
SOURCE: need mower deck belt diagram for L-130 John Deere
I have found the manual at JD's website. Click the link and scroll down in the left column until you find the heading for replacing the belt. I contains big, clear photos. Here is the link:
http://manuals.deere.com/cceomview/OMGX21647_K3/Output/Index.html?tM=HO
You can copy it into your browser window or type it in. I sure hope this helps you out. If I can be of any further assistance, please let me know:)
Posted on Aug 21, 2010
125 electrical drawings
Here's the link and I'm sure you will get the solution of your problem.
John Deere 102 115 125 135 145 155C 190C Lawn Garden Tractor Technical...
Sep 14, 2016 | John Deere Garden
155c john deere lawn tractor
Take the spark plug out and see what it looks like. If it's dark, sooty or wet smelling like gas, then you have a spark problem. Might need new plugs, a new coil or charging the battery up.
If the spark plug is dry and is a light tannish, brownish color than your problem is not getting gas. If that's the case, take off the fuel supply line to make sure you have gas to the carb. If that is fine, then you might need to take the carb a part to make sure you don't have plugged jets or passageways in the carb itself. If you want to find out quick, you can squirt a little gas into the carb intake and see if the the engine pops off. That will tell you as well.
Good luck
Jul 15, 2013 | Garden
Need instructions for changing a drive belt on a john deere LT155 lawn tractor. When mowing up hill the forward motion is slipping even though i am not loosing traction. if i come off the pedal and start...
I have googled LT155 and came upon john deere LT155 lawn tractor(noncurrent). It took me to John Deere's site. I put in your model number and it had several catagories. I would try the alphabetical list, go to B and look for traction belt.
Good day.
Oct 14, 2009 | John Deere Garden
Belt change on a hydrostatic 265 John Deere
Instructions for changing main drive belt on John Deere model 265
HELP !!!!!!!!!!!!!!!!!!
Jul 12, 2009 | Garden
Garden Logo
433 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
