Question about Dehumidifiers
Will not turn off keeps running - Dehumidifiers
  • 43,501 Answers
There are many reasons for a dehumidifierwill not turn off keeps running - 2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Posted on May 08, 2010
I have a dehumidifier model AHM65LKM1 65 puts when I turn machine on it keeps tripping
Dehumidifier tripping AFCI - DoItYourself.com Community Forums
www.doityourself.com > ... > Electrical - AC & DC
Oct 1, 2011 - My dehumidifier is on a 15 Amp circuit with an AFCI breaker. ... What I mean by that is that it can run without tripping for days or only a few hours ...
Sep 27, 2015 | Dehumidifiers
My Kul Dehumidifier filter keeps freezing up? is there anything I can do to keep this from happening?
Turn the knob to a lower setting so that the unit cycles on & off. This will give it time to warm back up and melt the ice in between dehumidifying runs.
Aug 30, 2015 | KUL 50 Pint Dehumidifier"
The fan never stops running. The dehum. works fine that is the only problem. Is it the way I have it set how can I change that?
Bob, some humidifier fans run a lot, because they are designed to keep the air moving and when the humidity level rises, the compressor turns ON to extract the humidity. If you're operating the unit in a continual mode, it's not unusual for the fan to run almost constantly.Especially, is the humidity extraction level is set at or above 50%. Lowering it to 35% will cause it to extract more humidity and will turn on an off less.
Hope this helped you and thanks for choosing FixYa.
Sep 19, 2011 | Whirlpool AD50USL Dehumidifier
Why does the fan run non stop? the compressor runs and shuts off but the fan just runs on high and low. I have 3 other dehumidifiers that the fan runs only when the compressor runs...why doesnt the...
Depending on the time sequence you have this unit set to run, Fredrich's are designed so that the fan runs almost constantly, to keep the air moving. When it senses a rise in humidity above the level you have it set on, the compressor turns ON and runs until the level of humidity is lowered. This is especially true, if you are operating this unit in continual mode.
Hope this helps you and thanks for choosing FixYa.
Aug 14, 2011 | Friedrich D50C Dehumidifier
My dehumidfier won't shut off. I check everything out and it's good but it just won't shut off it keep running.
It may be, that you have it running in continuous mode, rather than timed mode. Also, most dehumidifiers fans will run almost continually, to keep the air moving, so the humidity sensor can pickup and increase in humidity, if there is one.
If the above doesn't seem to be the problem with your unit, turn The Master ON/OFF Switch to OFF and unplug the unit for 12-15 minutes. This will give the electronics time to reset themselves, if necessary.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
May 23, 2011 | Fedders A7DH45B2A Dehumidifier
Compressor stops at proper humidity % but the fan keeps running.
Dehumidifiers are built that way. They keep moving air so it is able to keep any change of conditions moving around the room. On a dehumidifier, it the fan stops, your unit will short cycle becasue water will naturally evaporate from the water tank and it would turn on, then off, then on then off. The way it runs now is fine. Running the fan 24 hours on your dehumidifier cost nickels a day. Just let run.
Sep 28, 2010 | Danby DDR2504 Dehumidifier
Zenith ZD30 dehumidifier - 1 1/2 years old stopped working had a half bucket oc colledted water in bucket when it stopped. I checked the fuse on the circuit board and have continuity.
Unplug from wall. Take the front cover off and disconnect the 2 wires that attach to the humidity control dial. Plug back in. If it works, the problem is the humidty control dial (mine just went bad). With it unhooked, it will run constantly, but will still turn off when the bucket is full. To turn off, simply unplug.
Jun 16, 2010 | Dehumidifiers
My dehumidifier only the fan runs
Are you sure you have the humidity level set low enough for the compressor to turn on? If not, the fan may run anyway.
Your unit may be designed to run the fan continuously despite the fact that the room has reached the set humidity level. This design feature is intended to keep the air moving which helps mildew problems in both the room and on the surfaces of the dehumidifier itself. Check your manual.
Aug 31, 2009 | Dehumidifiers
Dehumidifer seems to run constantly
With that low of a setting it will most likely be kicking in alot more often. Most people run their dehumidifiers between 60-65%. It is a matter of preference. Also some basements hold out moisture more than others. There could be alot of variables affecting this. One thing you need to make sure is that you have the correct placement. Make sure you dont keep it near the sump pump or any other standing water because those areas have more humidity due to the water being there. Also make sure it is not in an area like a laundry room because when your washing machine despenses water it is despensing moisture into the air. I try to keep it at a central location if at all possible and away from areas that have water. If you found this solution helpful please rate it when you get a chance. Thanks - Tech101
Sep 06, 2006 | LG Goldstar LD65EL Dehumidifier
Dehumidifiers Logo
102 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
