Question about Coleman Sport & Outdoor - Others
Can't crank up top on 2001 coleman bayside elite camper, it is stuck halfway open and won't go down or up
5 Suggested Answers
SOURCE: 1995 Coleman Utah pop-up won's stay up
I had the same problem on my 1997 Coleman Fleetwood Bayside. I took out the spring pin from the crank shaft using a finishing nail and a hammer. I then put a 9/16th" socket inside to hold the nut in place while I used a pipe wrench on the outside of the crank shaft to turn it about 1/4-turn clockwise. Voila! Now it works.
Posted on Jun 17, 2009
SOURCE: hard to crank up
May sound a bit tacky but all pop ups are a bit tedious to crank up. In the event this IS NOT your first time to own or operate a pup. I apologize and suggest you post your problem on the pop up times and or the pux webpages. Both are reliable sources for people who have pop up up or small campers.
Posted on Jul 28, 2009
  • 13 Answers
SOURCE: I have cracks on my coleman pop camper rubber roof
Roll with a fibrous roof coating. make sure it has the fibers or else it will not adhere to the cracks or metal.
Posted on Oct 27, 2010
jyackle5
  • 8197 Answers
SOURCE: Need owners manual for 2000
On the link below is all the coleman tents. Please look and find your tent for the manual.
http://www.coleman.com/coleman/manuals/manuals_resp.asp?category_id=2200
If it is a traler please go to this link to find your manual.
http://www.popupportal.com/index.php?action=media;sa=album;in=69
Posted on Jul 31, 2011
Where can I find an water heater access panel for a 2002 coleman bayside elite pop up trailer?
try the manufacturers web site and the contact section or technical advice section or simply call on the phone listed on the coleman site and ask directly
Jul 07, 2016 | RVs
On my 2001 kia sportage the back two windows won't go down and the right front window is stuck halfway up
make sure power windows lock out switch on driver side not on position, that will cause power windows not work or you have faulty power window relay.
Sep 11, 2012 | 2001 Ford Explorer Sport Trac
Need 2000 owners manual for coleman niagra pop-up camper
Try this link
http://www.popupportal.com/index.php?action=media;sa=item;in=2985
Apr 23, 2012 | Coleman 10' X 10' Sundome Tent 9160K101
My Keurig is stuck. The top of the handle won't go in :( it won't close. Stuck open.
Remove the Kcup basket and clean. Rest and strat over. Pull down and reset handle.
Jan 21, 2012 | Keurig Elite B40 Coffee Maker
Coleman bayside 1997 pop up camper, had to remove some motor part related to cranking up. won't stay up unless motor part is put back in. help? female with trouble and wanting to camp this weekend
Sounds like the motor also holds up the top.
can you try to use something loke a broom stick thick piece of wood to hold up the canopy top till you get a chance to get a new motor.
You would prop up the top with a piece of wood right in the same area as the framing.
Tie a piece of string or bungee cord to hold the stick in place,to ensure the top dosent come down on you.
You might need to cut the stick to leanth as well as using more than one piece of wood.
Gool luck,Gary
Sep 21, 2011 | Coleman Water Sport
I need the threded rod assembly that cranks up the hard top on my coleman popup camper 1994 i think
IF YOU HAV THE OLD 1 . CHECK AROUND TO YOUR LOCAL CAMPER , OR MACHINE SHOP OR WELDING SHOP, IT MIGHT BE REPAIRABLE.. IF NOT CHECK THE WEB FOR CAMPER CLUBS OR FORUMS .. JAY
Jul 23, 2011 | Emerson THREADED SHAFT UP RATED - 1.00 HP...
Jul 11, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
Jun 07, 2009 | Coleman Sport & Outdoor - Others
Broken cable in older Coleman pop-up camper...how to replace it? Can't see in body of camper where the cable needs to go through to the posts that raise the top.
This camper uses the Coleman lift system which uses a threaded rod that connects to a tracked distribution block to which all four cables are connected and then routed by pulleys to all four corners of the popup.First raise the popup to it;s full height by using automotive jacks and poles once extended securely clamp the poles to the telescoping up rights This IS SUPER IMPORTANT FOR YOUR SAFETY. Next get under the camper find the broken cable unbolt it's routing pulley(s) pass the broken ends out the pulley(s).Next unbolt the end from the distribution block. followed but unbolting the cable from in side the telescoping column;carefully note the routing in side the column. Buy or make up an exact length cable of aircraft grade stainless steel twisted wire cable of the same gauge. Reverse steps to re install,take lowering strain on crank make sure crank handle is captured by anti free wheeling device on camper un clamp poles remove, lower and raise top by crank to ensure smooth working. You're finished.
Apr 19, 2009 | Coleman Sport & Outdoor - Others
Sport & Outdoor - Others Logo
191 people viewed this question
Top Coleman Sport & Outdoor - Others Experts
David Payne
David Payne
Vernon Taylor
Are you a Coleman Sport and Outdoor - Other Expert? Answer questions, earn points and help others
