Question about Minolta magicolor 2400W Laser Printer
Will Not Connect
When I powered off this printer last night, everything was fine. This morning I get power off/communication error. I have deleted the printer & removed the driver. Now, the driver is saying the printer is not communicating. I have moved the the USB to various ports with no luck. I have powered down & rebooted. Right now, it's stuck on "connecting". Is there a way to replace the USB cable? I don't have anyway to see how the panel it goes into opens...
  • 1 more comment
  • Renee Jolley Mar 27, 2008
    Have solved this with a screwdriver & wrestling match.... thanks....
  • mresat Jul 01, 2008
    I have the same problem.... How did u fix it....
  • Renee Jolley Jul 01, 2008
    I had to pry the panel off with a screwdriver & replace the USB cable - It still doesn't work quite right - I can't have anything running when I use it - and sometimes I still get a communications error - I'm thinking it's the actual board inside - if I can find it to replace it, I will....
Hi, I have the same problem. How did u fix it? Which parts have the problem....
Posted on Jul 01, 2008
  • Jack B Jan 30, 2012
    First, check if the printer works when connected to another computer.
    If it does, then your usb drivers in your PC are most likely causing the problem.
    You need to remove the drivers and then let windows reinstall them.
    How to do it, check the link:
The printer only prints the centre 15 cm section of the page. It completely cuts off the top and bottom.
Try unplugging your communication cable and turn everything off. Turn everything back on and plug in the cable. If that doesn't work delete the printer from your printer list and re-install it. Usually in this type of scenario it's a communication issue.
Feb 21, 2015 | HP Color LaserJet 9500HDN Printer
Insignia tv issues
Your Insignia TV probably has had an internal power supply failure
Oct 13, 2013 | Insignia Televison & Video
Cant get the power to turn on,worked fine last night, it got unplugged, this morning plugged in, won't turn on and the power button just flashse
Flashing is either an error code or the set trying to boot up--some of the Mitsubishi sets if power removed will blink for a minute and then stop--then the set can be turned on.
a model number?
Apr 28, 2012 | Mitsubishi Televison & Video
Does not seem that there is any electrical current. Checked all the fuses, they are fine. It doesn't seem like a battery problem as there is absolutely no current. Drove it last night everything worked. ...
Is the battery dead? Your alternator may be bad. If you drove it last night you may have driven on battery power and not realized it. You should have gotten some kind of warning message. Need to know if the battery is dead.
Feb 03, 2011 | 2001 Pontiac Montana
107.08 service printhead error message appears on screen - only installed printer 2 days ago.
Take the back panel off and reseat the ribbon cable in the top middle of the system board..Just got off the phone with tech support and it worked...
Nov 19, 2009 | Lexmark C543dn 26B0000 Workgroup Up to 21...
Blinking panal lights/no responseno communication w/computer.Help
hi you can try these steps:
  1. Turn the product off.
  2. Unplug the power cord from the product.
  3. Wait 30 seconds, and then connect the power cord to the product.
  4. Turn the product on.
  5. Make a color copy by pressing the Start Copy Color button on the control panel.
  • If the copy job is successful, you do not need to continue troubleshooting.
  • If the error message displays again, proceed to the next solution.
  1. Disconnect the power cord from the product.
  2. Press and hold # and 3 while reconnecting the power cord to the product, and then release both buttons.
  3. Try making a color copy by pressing the Start Copy Color button on the product control panel.
    • If the partial reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, proceed to the next step to try a semi-full reset.
  4. Disconnect the power cord from the product.
  5. Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons.
  6. Try making a color copy by pressing the Start Copy Color button on the product control panel.
  7. the # and 6 will reset the whole printer as it is factory, I hope it will work fine!!Best of luck!!
Jul 03, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Tv wont turn on worked fine last night
If there is no power at all, then the problem is likely the power supply unit.
The PSU must be tested, then eventually replaced.
May 30, 2009 | Spectroniq PLTV3250 32 in. LCD TV
Dell printer power button flashes
no the printer is perfect , but many times this error occurs after changing the cartridges.
first remove all the external connections from the printer.OFF the printer remove the power plug.hold for a minute.then plug the power cord and then ON the printer ,connect the printer to the computer by USB wire as regular.and then check by giving printouts.if it still shows the same error.
then try this
1)right click the my computer icon
2)click properties and then click hardware n go to device manager.
3)uninstall all usb ports and then scan for hardware changes
4)ur pc will detect your printer and ask for printer drivers
5)re load drivers and your pc will communicate with your printer
6)for reloding install the cd follow the instructions on the screen and click next
7)restart when the printer is loded.connect the wires and cords properly.
Oct 23, 2008 | Dell 924 All-in-One InkJet Printer
Minolta magicolor 2400W Laser Printer Logo
85 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
