Question about Dryers
No heat All working fine just no heat
  • 1 more comment
  • Kelly
    Kelly May 11, 2010
    There are several things that can cause the problem. 1. Thermostat 2. Heating element 3. Temp control 4. Timer 5. Motor switch You did not mention Gas or Electric in your question. Additionally if you provide your make and model number we can probably give you some great tips on how to troubleshoot and repair your Dryer. Thanks for using FixYa. Kelly
  • Dan Webster
    Dan Webster May 11, 2010
    model number? brand?
  • john andrew manchook May 11, 2010
    Electric? Either the safety switches are tripped open or the heating element has a break. You can check for power to the heating coil with multitester to see if you have power there first. If you do and no heat...its the element. No power? You should go back and check the two switches and see which one has power still. The other one is bad and should be replaced. Be careful working around the electricals and the moving parts! Good luck....let me know how you do ok?
  • 784 Answers
Need to replace heater element.
Posted on May 08, 2010
Subaru A/c stopped working after flipping it to heat
Did you turn the temp switch back to the blue (or cold) end? If it's still in the red section, if will only blow heat.
Mar 10, 2015 | 2003 Subaru Outback
Heat not hot
Sounds like ur heater core went out! Better get checked out!
Nov 01, 2012 | 2003 Buick Century
My dryer runs fine, just wont heat, was working fine this morning, but on my second load of the day it stopped heating, cleaned all the lint from front-even pulled out and cleaned the lint from the back...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Apr 30, 2011 | Bosch Nexxt 500 Dryer
Oven will not heat up. microwave works fine. all the led light up fine. was working fine for the last 4 years. checked the circuit breaker and it is fine. is there a thermal fuse i can check. where...
oven will not heat up. microwave works fine. all oven will not heat up. microwave works fine. all the led light up fine. was working fine for the last 4 years. oven will not heat up. microwave works fine. all the led light up fine. was working fine for the last 4 years. checked the circuit breaker and it is fine. is there a thermal fuse i can check. where is it located
Jul 19, 2010 | GE JKP86 Electric Double Oven
Front heat not working, but rear is fine.
Vacumn hose to operate flap is damaged or somebody kicked on outside of plastic cowl holding flap in place on floorboard,or cable going to slide mechanism,not funtioning....if flap in open position going to get cold air ,has to shut,to bypass fresh air intake,an let only heated air through.....
Oct 24, 2017 | 2004 Kia Sedona
Stove top works oven wont heat on 465
the ignitor needs replacing, that's the glow that you see. it's not getting hot enough to open the safety valve.
Dec 07, 2008 | Whirlpool GS460 Gas Kitchen Range
Dryers Logo
Top Dryers Experts
