Question about HP Pavilion dv6000z Notebook
Partial Screen Black-out on Bootup
I own HP TouchSmart tx-2 Notebook PC (1115AU) and the problem is that whenever I turn it on, there are two straight, horizontal white lines that divide the screen into 3 equal rectangles. The bottom two show nothing from the desktop as they are totally sky-blueish in color. The top part of the screen appears normal. A series of several on and off of the power switch (sometimes up to 6-times) will eventually correct this problem and the PC boots up normal.
The PC is around 15-months old and have had this problem for the past 6-months. May the Gurus out there extend a helping hand.
  • HP Master
  • 2,007 Answers
Bad screen
bad connectors to screen
bad driver chips driving said screen.
we do shop tests to find, it using parts and tools you dont have.
as you can see net bunnies can not do the work
called diagnosis.
here twist the screen gently , lines change right?
and tells you ? bad connections.
Posted on Apr 17, 2017
    New Friend:
  • 64 Answers
Hi, it may be happening due loose wire of laptop screen or any other hardware issue, you can't do it by own either you go at local repair center or call remote tech support provider.
For any Tech Query, Dial: +1 (844) 355-5111 (toll-free)
  • 167 Answers
SOURCE: Screen Problem...
I had a similar problem with one of my laptops, there is a ribbon cable that connections the LCD screen to the board inside the laptop case that gets a little loose. In my case it was a easy fix because the button panel on my laptop popped right out and I could take the end of a pencil and push the connector back down into the socket; not all laptops make it that easy for you. If you laptop is still under warranty I would make HP fix it; there is also a chance the LCD screen could be burning out.
If you're not squeamish about fixing it yourself my recommendation is do the work at your own risk. The only hard thing about taking apart a laptop is putting the each screw back in the original location; many laptops have more than 5 different sized screws holding it together. Furthermore, you don't need to dismantle the whole thing; worst case there are 2 - 4 screws that hold in the keyboard and 2 - 3 screws holding in the forward button panel. Near each screw hole is an indicator what it is for; on my laptop it shows the letter "K" to represent the keyboard screw holes. I'd usually stay away from taking out the screws from the 4 corners of the laptop...
If your keyboard has a trackball there is a mini ribbon that is fragile connected underneath, so after removing the keyboard screws be careful not to pull farther then the slack allows.
If you're lucky you won't have to monkey with any of this and the forward button panel will just pop out. Laptop designers are making it easier to "replace" laptop screens and keyboards because it is a common problem. I'm positive if you're able to secure that connector you won't have that "frosting" effect you see now.
If you have anymore questions just let me know...
Posted on Nov 27, 2008
  • 17 Answers
SOURCE: Hello I have a HP touch screen Tablet PC. Since
Bad LCD....need part# 441758-001 (LCD+Digitizer Glass), order from a company called Smart Micro in Dallas/Addison TX
Posted on Sep 10, 2009
  • 120 Answers
SOURCE: black screen on booting my Compaq 610 notebook
If it seems like you're accessing the hard drive (drive light comes on, flickers intermittently, then goes off, it's a good chance your screen is bad.
First thing to do is plug in an external monitor and start up the laptop. If it comes up with windows, you know it's the screen.
To find out if it's the backlight, or the lcd, toggle the monitor function and shine a flashlight on a slight angle to the screen. If you can faintly see what was displayed on the external monitor, then the backlight inverter is probably bad.
If the external monitor didn't come up, you're probably looking at a motherboard.
The good thing is that all of those are covered for one year under Compaq's warranty, on a new machine.
If you are able to use the external monitor, back up your data, because HP/Compaq usually reformat the harddrive. Additionally, if you've added memory, pull the cards. They want it sent back the way it came from the factory.
Posted on Jan 09, 2010
SOURCE: HP pavilon tx 1000 won't turn on half the time or black screen. – Join this group on Facebook, lots of people are posting and petitioning on lots of different websites. It be nice to have our numbers on this group.
Posted on Jan 22, 2010
SOURCE: Touchsmart tx2z Screen Flickers and Freezes
it seems the touch part is off center because when i touch the screen it reacts one finger over
Posted on Aug 28, 2010
Sounds like your display panel has burned out. It can be replaced but check various shops as the cost can vary dramatically. Good Luck
Apr 22, 2014 | HP TouchSmart 310-1020 All-in-One Desktop...
Touchsmart icons partial fill the screen
To add more icon on the touchsamrt applications
Follow the steps in the below video.
These icons in the touch smart applications are usually referred has tiles
Apr 27, 2010 | HP TouchSmart IQ804 Desktop PC
Hp tx 1000 black screen please hel
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer
Nov 28, 2009 | HP Pavilion Tablet Notebook
When computer opens, incomplete Touchsmart windows appear
it mean your windows is corrupt just format & reinstall fresh copy of windows.
Jan 07, 2009 | HP Hewlett Packard ALL-IN-ONE-TouchSmart...
Have you checked on the hibernation settings?
Dec 20, 2008 | HP TouchSmart IQ770 PC Desktop
HP Compaq nx6310 Notebook PC recovery disc
You can try pressing the F8 key at bootup to get the boot screen, and select the option " use last known good configuation" and press enter. if that dosn't work, you can do the same thing only select SAFE MODE and press enter, an that should get you into windows. then you an go t Start/accessories/systemtools/system restore, and restore th system back to a date before your problem started.
Dec 16, 2008 | HP Compaq nx6310 Notebook
HP Pavilion dv6000z Notebook Logo
141 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
