Question about Acer AL2671W 26 in. LCD Television
Acer model AT3201W no picture?? Sound is great, everything is connected tightly. Checked the manual ...no help..
  • 3 Answers
There are several things that could be the problem, as usual. However I did manage to get a set working with the following characteristics:
- Set powered on ok and displayed the Acer logo fine.
- All of the inputs had very low brightness and poor colour.
- The backlight was working and appeared bright.
- The picture was barely usable with brightness/contrast set maximum.
I figured the issue here was a loss of the picture settings in the eeprom in the unit. So I set about to find how to get to the factory menu to set these things. This assumes you can get a menu to display on the set.
To enter factory mode on the remote control press menu/menu/234/menu. You will see the menu displayed with some info in the top bar that is normally not shown.
Then on the front of the TV press Volume- and Channel+ at the same time and hold until the factory menu appears.
You may see that the RGB gain and bias values are low or 0.
If that is the case set the colour temperature mode to Standard and then adjust the RGB gain and bias values to the following:
R gain: 434
G gain: 482
B gain: 484
R bias: 270
G bias: 270
B bias: 264
Then set the colour temperature to Cold and enter the following values:
R gain: 434
G gain: 482
B gain: 484
R bias: 270
G bias: 300
B bias: 310
Similarly, for Warm adjust the values to:
R gain: 434
G gain: 482
B gain: 484
R bias: 300
G bias: 280
B bias: 264
Then, if this was the problem, the picture should be fairly adequate.
Hope this works for you...
BTW I must give some credit here to another poster who provided a similar solution to a different problem here:
http://www.fixya.com/support/t154524-tv_losing_its_channel_memory
Posted on Sep 13, 2010
  • tasdavo Feb 24, 2011
    Hey guys Im in Australia and was given one of these flat screens but the previous owner played with the settings for RBG gain and bias. SO hence a bad picture. Ive tried the settings suggested but on this model they only go up to 255 for each . Any help would be greatly appreciated. Cheers Dave
  • Craig Townsend Nov 05, 2011
    Craig here again.
    I should add to this that there is a set of parameters for each of the video sources that the TV has, and that will be the input source that is selected before you enter the factory menu. You will probably need to adjust all of the input sources when you reprogram the TV. Some of the modes have settings that go only to 255, in which case I generally set them to 127 for half-range to start. I recall that the source that you are adjusting will be indicated in the banner at the top of the factory menu.
How do i repair acer flat screen tv model At3201W that turns on When goes black
Back-light problem.Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis.If you wish to get some details; check the site linked here.Surf the site with patience.Pull up older posts.It will be best to replace the inverter board as card basis.
Sep 21, 2014 | Televison & Video
Have great picture no sound. The buttons turn volume up and down but I can not get sound
If you are using HDMI cable make sure it can transmit audio as well, as some cables don't do this I believe. Other wise, replace it.
Jun 30, 2014 | ViewSonic N4285p 42 in. LCD TV
I have an AL2671W26 Acer Tv when I turn it on everything is fine for about 30 seconds, then I loose the picture, but the sound it there. Any thing I can try would be greatly appreciated. Thanks Cindy
Thanks. i am also searching same fault in my lcd
Sep 11, 2011 | Acer AL2671W 26 in. LCD Television
How much is the screen for a acer lcd tv model no:AT3201W
this model is no longer available in market anymore.and therefore no branded new parts available.
but my friend told that price of screen grew up last days,at least more than 40$.as my idea is you better try on new model.you can find screen from your electronic goods dealer and i recommonded buy new model.you may repair this,but in future,parts may not available of all.before you buy new one,think twice is this model suitable for future,and how many years.
Thanks
i think this may help,if yes please accept,or not and ifyou need more,contact me again.
good luck
Dec 06, 2010 | Acer Televison & Video
I have an ACER AX1700 which I connected to my TV with a HDMI cable. I get no picture and no sound. How do I get the pc to recognize the TV through the HDMI cable. I have checked the display settings and it...
hi to get picture plug in the hdmi cable into tv and pc then press FN key plus the key that has a picture of one or two tv screens along the top of the keyboard and i think for sound you will need an audio jack 3.5mm cable to connect to tv and the mic jack on your pc..im running a vga on my pc to vga on my tv and i needed an audio cable for sound or you might want to select your menu on your tv and select pc or hdmi not sure though thats what i do and it works great...hope this helps
Aug 07, 2010 | Acer Aspire AX1700-U3793A PC Desktop
TV doesn't work right.
t-con board has failed
Sep 17, 2009 | Televison & Video
I have ab Acer LCD TV AT3201W and in the manual it says that it is HDTV Ready. What does this mean?
HDTV ready means that your TV is capable of displaying a high definition picture. A standard television broadcast is shown in 480i. High definition starts at 720i. Only an HD ready TV is capable of showing a picture that is 720 or above. So, if a person wants to upgrade to high definition offered by their satellite or cable company, or they want to enjoy a new Blue Ray disk player, they have to have a TV that is HD ready.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Jul 14, 2009 | Acer AL2671W 26 in. LCD Television
At power up tv displays Acer logo then goes to black
will not turn off power with out unplugin it
Mar 01, 2009 | Televison & Video
I need a sound card
if u have a sound driver u install
it then check the setting
Jun 07, 2008 | Acer Computers & Internet
No audio
Hi
Pls check if the audio settings on the monitor are correct. Along with the monitor menu button, there will be another button for audio for some models. For other models the audio option will be available in the menu button itself.
Pls check with another set of powered speakers and not headphones.
Also check for the drivers and any driver updates for your sound card.
Hope this helps fix your problem.
Jan 28, 2008 | Acer AL1717 17" LCD Monitor
Acer AL2671W 26 in. LCD Television Logo
1,085 people viewed this question
Top Acer Televison & Video Experts
Gareth Cockram
Gareth Cockram
Rommel Balcita
Martin Murray
Are you an Acer Televison and Video Expert? Answer questions, earn points and help others
