Question about Nikon FE 35mm SLR Camera
Nikon fe release to open the back will not open. The crank is stuck and will not go up or down.
  • mlee738 May 08, 2010
    The crank is partially extended, and I am pushing the release towards me when lifting up. The crank will not go up or down. The shutter is also stuck open and it seems the rewind button is stuck in on the bottom.
  • kakima May 11, 2010
    Is the crank partially extended? Are you turning the catch around the crank before trying to pull/push it up/down?
2 Suggested Answers
SOURCE: Film rewind crank stuck in up position nikon n2000
take camera and accessories to nearest dump and toss it in the heap of other unusable Nikon junk
Posted on Feb 06, 2011
How do i open the back door
You lift the rewind crank as per almost all other SLR's but there is a safety lock around the base of the crank which you must slide rearwards (counter clockwise) first.
Make sure that you have fully rewound the film before opening the camera.
Please take a moment to rate my answer if it has assisted you, if you need further assistance with this problem then add a comment instead and I will reply as soon as possible with further help.
Oct 05, 2010 | Nikon FE 35mm SLR Camera
I cant open the camara take off the film inside
After rewinding the film, nudge the little switch between the ISO dial and the rewind crank counterclockwise and lift up on the rewind knob until it catches. Then pull up a bit more and the back should spring open.
Dec 27, 2009 | Nikon FE 35mm SLR Camera
Move it a bit (some half circle)back and forth. The slot may be in wrong position related to the roll inside. It should click in when you get the slot in right angle.
Aug 02, 2009 | Nikon EM 35mm SLR Camera
Film speed selector stuck
Try to rotate the lock body anti-clockwise. Do not use muscle power, just try to rotate softly the locking body.
Oct 10, 2008 | Nikon FE 35mm SLR Camera
Shutter won't open and film won't advance
You might have a dead battery. Check that.
Philip
Sep 28, 2008 | Nikon FE 35mm SLR Camera
Film advance lever and shutter release button are "stuck"
No, it is not the battery. My guess is that the film leader did not stay in the take-up spool and is now bunched up around it. Try rewinding the film carefully as you normally would but remember that you are only rewinding a small portion of the length. You can even just open the film door and start over. You will only loose 3 or 4 frames on the roll.
Apr 27, 2008 | Nikon FE 35mm SLR Camera
CAN WORKOUT HOW TO OPEN NIKON FE CAMERA
Sept 19th, 2008
On the bottom of the Nikon FE, there is a silver button to push in, and this releases a lock for the film.
Then on the left side, on the top, there is a white arrow and a silver lever tucked in. Wind your film, this it's all the way back in the canister. Then the black lever by the speed film (ASO) numbers, pull that back toward you. This will release the black 3/4" knob upward, and by gently pulling this upward, your door will release and the film canister will be allowed to come out. Just besure to wind your film back in the cansiter, before you open the door, or your photos will be over exposed. Best to do this in a darker area or shaddowed area, just for protection.
Good Luck. I've had mine since the mid 1970's and love it for double exposures and the special filters I have for it. The Hot Shoe for the flash attachment, just burned out on me a couple of days ago.
Mar 02, 2008 | Nikon FE 35mm SLR Camera
Nikon FE 35mm SLR Camera Logo
135 people viewed this question
Top Nikon Photography Experts
Ric Donato
Bart Pulverman
Are you a Nikon Photography Expert? Answer questions, earn points and help others
