Question about Soleus PH413R01 Air Conditioner
Blower wheel I need a replacement blower wheel only. Soleus is useless, saying I need to have a licensed HVAC tech phone in, and even then, they probably can't supply this part.
    Genius:
  • 1,036 Answers
This is how manufacturers are making more money - by tightening release of spares.
If you can't get spares without jumping through their hoops, try looking for these spares online. You might find a supplier in China with no problem supplying you.
Best of luck.
Posted on May 07, 2010
Location of blower motor in 1987 t600 kw
Search Results Blower Motor (HVAC) on HeavyTruckParts.Net
https://www.heavytruckparts.net/search.php?qsearch...KENWORTH
$350.00 1993 KENWORTH T600 Blower Motor (HVAC) .... Plastic; Blower Wheel, OEM# 589540 Peterbilt, 2000 1987, All w/Bergstrom A/C 4-1/2? Dia. (CCW) ...
Search Results Kenworth T600 Blower Motor (HVAC) on ...
https://www.heavytruckparts.net/search.php?...Kenworth...T600...
Search Results for Kenworth T600 Blower Motor (HVAC) on HeavyTruckParts.Net. Easily find what you need from thousands of parts available. HTP.net has ...
Viewing a thread - Kenworth cab fan - AgTalk Home
talk.newagtalk.com/forums/thread-view.asp?tid=447803...flat...1
Jan 21, 2014 - 9 posts - ‎9 authors
Feb 03, 2016 | Cars & Trucks
Hello, I have a carrier 58sta in the townhouse were renting. A few days after moving in the furnace was getting louder and louder each time we run the ac. It now sounds like a jet engine when it starts and...
the electrician might be able to help somewhat but an hvac tech is the person to call. It sounds like you have multiple issues if the thermostat is acting up that bad replace it!! but that wont stop the noise from the furnace thats either the blower wheel or the motor. ive seen filters get sucked in the blower wheels and destroy them then they make a buch of noise. if the filter hadn't been changed in a few years then the motor is probably going bad. you could check to make sure there is nothing in the blower wheel. make sure the power is off open the bottom compartment of the furnace use a flashlight and look around then stick your hand in there and feel around, if there were animals before sometimes a blanket of hair can develop on the blower wheel. make sure you dont touch the capacitor which looks like a little siver can near the blower motor it can shock you even with the power off. good luck
Jul 20, 2010 | Carrier Heating & Cooling
Who has the parts for a Soleus Air MAC -12 portable A/C
If its the part that turns the louvers on the output the part number on the back of it is 24BYJ48A. Its a small stepper motor. Unfortunately I too need one and haven't yet found a supplier in the US.
Good luck
Ron
Jul 14, 2010 | Soleus LX-120 Air Conditioner
UNIT WILL RUN FOR 15 MIN WITHOUT PROBLEMS THEN THE DISPLAY WILL GO BLANK AND UNIT WILL THEN BLOW OUT WARM AIR.
Check the condenser coil blower wheel. Soleus Air units use a cheap plastic wheel that comes apart after the warranty period. The condenser coil is the backside coil that is rejecting heat through the exhaust when unit is cooling.
The display going blank is a symptom of unit overheating, it's can't exhaust the heat buildup at the condenser, therefore the cabinet overheats.
If you find the blower wheel in pieces, I have a parts source for you:
www.shop.soleusparts.com
Jul 13, 2010 | Soleus LX-120 Air Conditioner
Soleus 14000 btu air 12000 btu heat
Hi
Your text "will not blow out" indicates lack of air flow.
There are two posiblilities:
The upper blower wheel has failed (evaporator coil) OR the lower blower wheel has disintegrated (condenser coil in cooling mode) - which is very common on this Soleus Air model. The blower motors are very good and rarely fail.
Unplug from outlet, remove the six phillips head screws which secure the back to front of the appliance. Look for many broken pieces of your blower wheel.The proceed to www.soleusparts.com and order a blower wheel replacement kit(s).
Problem solved!
Jun 17, 2010 | Soleus LX-140 Portable Air Conditioner
HVAC Blower Motor Replacement
Ain't nothing to it. Slide out the blower and take it outside. Use some rust buster to get the blower out. Don't beat on the shaft. Spread that shaft and the wheel won't come off. Use a rubber mallet. Most generic blowers have white as a common wire and the speeds are black-hi blue med and red, for low. 2 brown wires will go to the capacitor. other wires will reverse direction. Wash the housing and blower wheel good. any wire unused will be taped off to themselves. Nothing to it.
Mar 11, 2010 | Carrier 38CKC042 Air Conditioner
I need to replace a heater blower motor on a 2004 chrysler pacifica and picture schematics etc;
  1. Disconnect and isolate the negative battery cable.
  2. Remove the passenger side cowl trim panel. See: Body and Frame\Interior Moulding / Trim\Trim Panel\Service and Repair\Cowl Trim
  3. Pull back the carpet to access the front upper screw that secures the air inlet housing.
  4. Remove the recirculation door actuator.
  5. Remove the recirculation door actuator wire lead from the routing clip located on the lower air inlet housing and position the wire lead aside.
  6. Disconnect the blower motor wire lead connector from the blower motor resistor or power module, depending on application.
118348823 Lower Air Inlet Housing
  1. Remove the one screw (from the top) that secures the lower air inlet housing to the upper air inlet housing.
  2. Remove the four screws (from the bottom) that secure the lower air inlet housing to the upper air inlet housing and remove the lower HVAC housing.
118348824 Blower Motor Wire Lead Grommet
  1. Push the rubber blower motor wire lead grommet through the opening in the lower air inlet housing.
  2. Feed the blower motor wire lead through the opening in the lower air inlet housing and remove the lower air inlet housing from the vehicle.
  3. Position the recirculation-air door as necessary to access and remove the three screws that secure the blower motor to the lower half of the HVAC housing.
  4. Gently flex the recirculation air door far down enough to remove the blower motor and wheel from the HVAC housing.
118348825 Blower Motor Mounting Tabs
  1. Remove the blower motor and wheel from the HVAC housing. Note the position of the blower motor mounting tabs.
INSTALLATION
  1. Position the blower motor and wheel to the lower half of the HVAC housing. Align the blower motor mounting tabs to the correct location on the HVAC housing.
  2. Gently flex the recirculation-air door far down enough to install the blower motor and
Dec 02, 2009 | 2004 Chrysler Pacifica
Soleus air heat pump soleus lx 140 quit working
Hi
The Soleus Air condenser blower wheel is all plastic and I have seen many of them disintegrate from normal residential use. It's just a weak part.
Go to shop.soleusparts.com and buy a metal blower wheel replacement kit. Problem solved!
May 19, 2009 | Soleus LX-140 Portable Air Conditioner
Soleus PH413R01 Air Conditioner Logo
186 people viewed this question
Top Soleus Heating & Cooling Experts
Michael Galve
Michael Galve
Coss
Dennis Boxerman
Are you a Soleus Heating and Cooling Expert? Answer questions, earn points and help others
