Question about Daewoo Televison & Video
I have model dth-29g2k-100d, where i can find help to solve problems with memory?All the time it lose any information about tv settings. And when i want to start it doesn't work.
4 Suggested Answers
  • 3 Answers
SOURCE: lcd tv magnavox
You might have a timer set on the options menu. look under the sleep mode.
Posted on Mar 25, 2008
SOURCE: help with NEC model # DTH-8D-1
voice mail
Posted on Apr 09, 2008
SOURCE: My Samsung T.V screen is
I have that problem with my Samsung TV!!! I unplugged every input and just used the TV through Internet TV and the screen still shakes. I have had the digital board replaced and that just made it worse
Posted on May 04, 2011
I have jvc CRT TV model AV-14FMG6B but not working because of timer led blinking continuously how to solve plse help me
Unless you get tv out of timer mode you will not be able to do anything. Try unplugging it for a few hours to see if the memory circuits lose the setting and maybe you can restore normal operation.
Sep 10, 2015 | JVC Televison & Video
My Technika TV model X22/14C-GW-TCD-UK loses all of its channels when I turn it off. I have to retune everytime I turn the TV back on, Any Ideas welcome, many thanks
All sets use a eprom in some form or another that stores the memory of what up/down channels are programmed into the memory of the set-I will presume no box is used in line with this set for signal---very rare for this problem to even happen---next try when turn on to direct enter a known channel and see if set goes there--then manually add it in the menu---if set does not lose that memory at worst you can manually add every channel one at a time.
Oct 30, 2012 | Televison & Video
Unable to get TV sound and dvd sound through the surround sound speakers with samsung compatible tv and blu ray player
Hi,Even though you have not mentioned about the cabling connections you have done, for the sake of correct connection I describe all the possible cabling alternatives to you..You can select whichever you want..
TO WATCH DVD ON THE TV:
** Receiver's "AUDIO and VIDEO OUTPUT as " 2xRCA Audio+1x Video " or "Optic Cable OUTPUT or " HDMI Output " of your Home Theater Receiver (whichever you want ,based on the existing sockets and necessary cables on your hand )
** AT TV side : you need to connect "Audio+ Video input s " as can either be : 3xRCA jacks or "Optic cable input " or HDMI IN connector of your TV ,
** than just switch to DVD mode on Receiver and play DVD
You can use "HDMI" connections as well but sometimes HDMI creates problem on Audio..
TO LISTEN YOUR TV ON SURROUND SYS.
** AT TV side : you need to connect "Audio Output " as can either be : 2xRCA jacks or "Optic cable output" or HDMI connector of your TV ,
** to Receiver's "TV input "or "AUX input" or "Optic Cable input"
or HDMI of your Home Theater Receiver (whichever you want ,based on the existing sockets and necessary
** than just switch to respective SOURCE mode on
Receiver corresponding the connector you have used on the back of Receiver ..
Pls remember.."IN " goes to "OUT" or vice versa..all the times..
There you go..Both Tv and DVD sound are on the
Receiver as SURROUNDING SOUND .By this means ,whatever you watch on the TV will come thru your Receiver's SURROUNDING SOUND speakers as well .
Hope this helps!..if more help requires pls let me know.
Take care
Aug 17, 2011 | Televison & Video
Just says no program information AV1 and no signal. Tried removing red, yellow, white wires and turning it on and off again. This problem occured after I hooked up my camera to the TV. What is the...
After a month or more of seeing "No program information" on my 32" LG TV and not being able to solve it I recalled that I'd unplugged the TV around the time the problem started.
When you first set up the TV you have to go into the settings and tell it what TIME ZONE you are in. Apparently when the TV is unplugged it erases the time zone information.
I went into the settings a few minutes ago and told the TV that I was in the Eastern Time Zone. Voila!, the TVGOS (i.e. the program information) immediately started working again.
If you're getting "No Program information" check your TV's setup settings.
Hope this helps!
Jan 09, 2011 | LG 42LC2D 42 in. LCD HDTV
My Samsung T.V screen is constantly shaking at very low rate.I have recently bought Airtel DTH & i assume that after that my T.V started this problem.I am not sure about it,because when i detached DTH...
Sep 14, 2010 | Televison & Video
Need code to make universal remote work on sony tv
hello sir,
i m having problem please n please solve it........
i hv recently buyed a new LCD Sony Bravia KLV32BX300 ON 2nd FEB. 2011 and im having Airtel digital tv HD alos and i have connected LCD and DTH with HDMI cable ok....then problem is that how to make my DTH universal remort to operate my tv remort sensor..how to sync..my sony remor with dth remort..and i have try my best but im faild i know my dth remort code that is [OK+2] HOLD THESE buttons atleast 3 sec. ...............tell me what was my sony bravia pairing code.........please please nnnn please
Oct 25, 2009 | Sony Bravia KDL-42V4100 42 in. LCD TV
How to connect (yellow, red & white) to component video
Connect either DVD player or DTH with the TV. There is only one input on your TV.
May 27, 2017 | Akai DVD-3850S DVD Player
Universal remote code for Zenega receiver
Zenega DishTV STB CD-1004is SRU 5130 Philips Universal Remote.
If you have bought the above universal remote and didn't know the code for your Zenega STB, use the manufacturer code for HANDAN which is 1184
Oct 27, 2008 | GE JASRM24912 Remote Control
Input setting
When you turn off the set, are you turning it off by running the power through a cable or satellite box? If you are shutting down the set from the AC mains side the set can lose all of its user set-up. In most TV models, the main power supply must have the AC mains connected.
The power supply goes in to a standby mode when the TV is turned off by its own power switch (not by the AC mains). The supply puts out enough power to keep the uPC and the user memory active.
If the set is properly turned off and it is losing its user set-up, it is possible that there is a fault in part of the uPC circuits. Depending on the model of set, there may be a lithium battery, or memory capacitor, or an EEPROM for keeping the user set-up memory.
Jerry G.
Apr 18, 2008 | Polaroid FLM-2011 Television
Lcd tv magnavox
Mar 20, 2008 | Polaroid FLM-323B Television
Televison & Video Logo
95 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
