Question about Canon EOS 400D / Rebel XTi Digital Camera
XTi 400D flash
I've had my XTi for about a year and a few weeks ago the flash popped up and when I pushed it down to lock it, it popped back up again and now it won't lock down. Any suggestions?
  • dr syn Mar 28, 2008
    Bayareabiker-
    Thanks for getting back to me. I think that is the problem I just wanted to make sure I wasn't overlooking something. Thanks again
    Dr Syn
    Problem Solver:
  • 8 Answers
It appears that the small hook that holds the flash down is not latching properly and perhaps needs replacement. If your camera is still under warranty, call Canon Customer care. Even if the warranty has just expired (like 1 or 2 months), they generally honor it and get the service done free of cost.
Posted on Mar 28, 2008
SOURCE:
I have problem, my 400D auto pop up does not work please help me
there is a sensor under the lip of the hot-shoe, you need a very small screw driver to lift up the piece that pushes down on the tiny button that tells the camera that there is already a flash mounted. this was caused by leaving the external flash on too long. try it, good luck. the sensor button is tiny., may need magnifying glass.
Dec 29, 2012 | Canon EOS 400D / Rebel XTi Digital Camera
My camera rebel xti flash will not work all of a sudden, what could be the problem and how may I fix it?
Does the flash pop up when you try to take a picture in low light in the Green Box Mode? If the flash does not pop up the problem may just be that something sticky is keeping it down. If it pops up but does not fire, the problem is usually either a bad flash tube or the wiring to the flash has broken where the flash head pivots up and down.
When the flash is fully charged the capacitor retains a voltage of over 300 volts even when the camera is turned off and the battery is removed. I've seen several cameras where the owner tried to repair the flash and ended up burning out the entire Main PC Board.
Bob Kilbourn www.camerarepairs.com
Sep 29, 2011 | Canon EOS 400D / Rebel XTi Digital Camera
How do you get to the video mode on the canon 400d rebel xti
There is no video mode on the Xti. The first Canon Digital Rebel to be equipped with video was the T1i, which came out almost 5 years later (2 years ago).
Feb 15, 2011 | Canon Rebel XTi / EOS 400D (body only)...
The built-in flash on the Canon Rebel XTI won't flash.
i am having the same problom try this i just found this ... http://www.fixya.com/support/t1021194-flash_not_working
Aug 20, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
EOS Rebel XTi 400D flash not popping up
Flash will automatically pop out only in AUTO mode, if the camera needs some additional lightning. In manual modes, you should use the flash button located at the left down side of the flash compartment, to manually force the flash to pop up
Jul 13, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
My camera is a Canon 400D. I put an external flash on it just few moments ago (canon speedlite 580EXII) and the flash wouldn't go off when i took pictures. So i took the flash off, but now the flash on the...
Hi Chrissy, I had observed the same problem - after an external flash had been removed from the camera, internal flash didn't pop up. Tried to look at the Google and finally found the solution. It helped me and could help you as well:
The usual reason is that the camera thinks that there's an external flash mounted on the hot shoe. Check the external flash detect switch. It's located under the right side of the shoe (there is a metalic piece which is kind of "elastic". Just try to push it and release several times, may be put the screwdriver softly under it and out... It helped me. Here is the picture of location of the detector.
Jan 11, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Built-in flash does not work
DO NOT MESS with a new camera (or any other new equipment).
Take/send it back to the vendor, The purchaser has rights also. Number one it must work.
I don't know your location but in UK (& Europe) we have very strict consumer legislation.
Mar 30, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Canon Rebel XTi/EOS 400D
I made the mistake of putting ahotshoe protector from my old camera on the new EOS 400D. It stopped the flash from popping up. I took it off and things now work.
Mar 11, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Flash doesn't work
I found the answer and fixed my flash. Look on http://photo.net/bboard/q-and-a-fetch-msg?msg_id=00ODWf
This will describe how, if you have been using a speedlite alot, than the little tab under the shutter release side of the hot shoe can get bent down thus constantly pressing down (toward the bottom of the camera) the small button which deactivates the pop-up1.gif flash even when the speedlite is not attached. Just bend the tab up a little with a jewler's screwdriver, turn the camera off and on and voila!! Fixed!!! Dan describes pushing the tab down, but on the xti, the tab needs to be bent up to release the flash deactivation switch and fix the problem. Thanks to Dan D on photonet for saving me a service call.
Dec 02, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Canon EOS 400D / Rebel XTi Digital Camera Logo
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
