Question about Cell Phones
I have purchased a freestyle 610 cordless phone and cannot register it. It is flashing Base 1. I have followed the online instructions, but when I get to Search 1 it goes back to flashing Base 1. PLEASE help.
    President:
  • 1,469 Answers
trying to register your freestyle 610 cordless. For it to work properly and stress free, you need to contact the service provider of the phone. that way they can give you the right step to take on how to register it.
They are the only ones that can get access and license on how to register cordless phones like this.
Just get in touch with them and they will help you out with less stressful effort. And calling them has no charges at all.
Take care.
Posted on May 07, 2010
  • vivsie537 May 13, 2010
    Thanks for your reply. Service provider is BT and I can't get through to them. Would you have a number I can use from Ireland, preferaby with a human being on the other end?
How do i reset the BT XD 1500 as had to replace hanset and can not get to work with the base?
uk-surplus.com/manuals/freestyle2200.pdf - United Kingdom
user guide above. please download
Please follow the instructions in the manual and no doubt you will get it all working again.
You most likely simply need to reset and re-register it with the Base.
Aug 12, 2010 | British Telecom Freestyle 2200 Trio...
Only bass set going extra hand set not working
This is because the extra handset might have not been registered with the base unit.The headset should be register to use the headset with that base unit.
To register the handset to base unit please follow the instruction:-
On registration the handset is allocated a handset number for use on the new base unit, the handset numbers are 1-5.
1. Press and hold
d65e3ff.jpgon the base unit until 608a95f.jpgstarts flashing. Registration mode will remain active for approximately 3 minutes.
2.Press and hold both
19efd34.jpg together until you hear a long beep.
3.Select the base unit you wish to register by pressing the corresponding number button 1-4.
4. When PIN is displayed, enter the units PIN number (0000 for this model).
5. If the registration is successful the handset will return to standby mode in a few seconds.
Thanx
Jul 22, 2010 | Doro DECT 540 Cordless Phone
Setting up my outgoing message: just purchased Uniden cordless DECT 1580. Manual says select command 8. How do I find Command 8? thanks, joan
please follow the instruction to register the handset to base
To register a DCX150 accessory handset:
1. Charge the handset completely.
2.Place the handset in the base cradle for about thirty seconds. Handset Registering will appear in the LCD.
3.When the handset has registered to the base, the LCD will display Registration complete then show the handset ID number.
If the display shows Registration failed, repeat the process again.
To register a DCX200 or DCX300 accessory handset:
1.Charge the handset completely.
2.Disconnect the base AC adapter. Then press and hold find while you reconnect the adapter. Keep holding find until the charge LED starts to blink.
3.On the handset, press and hold # until the handset beeps and displays Handset Registering.
4.When the handset has registered to the base, the LCD will display Registration complete then show the handset
ID number.
Thanx
Jul 21, 2010 | Uniden Cordless Phone
I would like to download the instructions for BT Freestyle 610
Here is a link for the PDF copy of the manual for the BT FREESTYLE 2200
http://phone.manualsonline.com/mdownloads/5411906d-1f70-4188-978e-24deb187931d.pdf
This link is for the BT FREESTYLE 610
http://dl.owneriq.net/c/c5950504-b4f5-46b9-92ea-f80a826cb3de.pdf
Please let me know if this helped you by clicking on the thumbs up icon!
Jan 21, 2010 | British Telecom Freestyle 2200 Trio...
Not registered
hello there i think this is because you need to register the second handset with the base here are the instructions
REGISTRATION
Registration links the base to a cordless handset. Once a handset is
registered it can use the base’s phone connection. A cordless handset will
not operate until it is registered to the base. During the registration
process, keep the handset near the base.
1. Press the flash/program button on the base until LINK HANDSET shows
in the display. 2NO is the default setting.
2. Press the 1 number key or press the MESSAGES/CID (or) button
on the base to scroll to 1YES.
3. Press flash/program to confirm handset is linked to the base. WAITING
HANDSET REGISTRATION shows in the display.
4. Press the flash/program button on the handset until LINK BASE? shows
5. Press 1 on the handset keypad or cid/vol (or) button on the
handset to scroll to 1YES.confirmation tone when the handset is successfully linked to the base.
6. Press flash/program on the handset again to confirm. You will hear a long
please leave rating if you find this usefull hope this helps thanx for using fixya!!
Jan 26, 2009 | GE 27958GE1 Cordless Phone
Need help registering the GE additional cordless model 27911.
I had the same problem but I fixed it by:
1. Disconnect the battery on the handset.
2. Wait 1 minute and reconnect.
3. Register handset.
Jan 10, 2009 | Uniden Cordless Phone
BT2200 how do i pair a phone with the base station? I lost the manual that says how to do this
Here are the instructions for registering a new handset for the BT Freestyle 2200.
Nov 08, 2008 | British Telecom Freestyle 2200 Trio...
Validation
I would assume this could have been a product that was returned to the company that you purchased it from. Follow these instructions. 1. 1. Disconnect power from the base by pulling the plug out of the back of the unit. 2. Press and hold the Page button and while holding the Page button reconnect the power. 3. Continue to hold the Page button until the charge/in use light flashes rapidly. 4. Release the Page button. 5. Press and release the page button on the base once. All handsets are de-registered and HANDSET NEEDS REGISTRATION shows in the display. Then From the Handset Setup Menu: 1. Press the caller ID-volume ( 6 or 5) button to scroll to the REGISTRATION sub-menu. 2. Press the mute/program button to enter the menu. REGISTRATION 1YES 42NO - - -shows in the display. The default setting is 2NO. 3. Use the touch-tone pad to select 1 for YES or 2 for NO. Or use the caller ID-volume ( 6 or 5) button to scroll to 1YES or 2NO. 4. If you select YES, press the mute/program button. HOLD BASE PAGE FOR 5 SECONDS, THEN PRESS HANDSET PROGRAM shows in the display. (Your handset should be held near the base during registration process.) 5. Press and hold the page button on the base unit until the charge/in use indicator flashes. Press the handset mute/program button. REGISTERING shows in the display. HANDSET X REGISTERED shows in the handset display, where X is the handset number. You may now rename your handset. (Refer to Step 3 & 4 of Handset Name Section) NOTE: IF you are re-registering the handset through the handset menu; to rename your handset you must go to the Handset Name Section and start from the beginning step. I understand that you have tried the registation process. Sometimes with electronics, you have to start from ground 0, before it will work correct again. If there are further questions or comments, please post here. Please rate this solutn through fix-it. Thank you
Jun 22, 2007 | GE 28111 Cordless Phone
BT Freestyle 2200 I am having problems obtaining a dialing tone on both of my handsets. When I press the green button for a line out it just beeps 3 times and cuts off. There is charge in both the...
hi just want to help others as desciption aint complete above
Registering a BT Freestyle 2200 handset
1. If there is a handset in the base remove it whilst you are registering the new handset.
2. Press and hold the PAGE button on the base for about 10 seconds until you hear a beep and the In Use light starts flashing.
3. On the handset to be registered, press and hold redial & CALLSd buttons together until display shows 65-.
4. Enter the base number. If this is a new handset then the base number is 1, the display shows 65-1 then PIN. which is normally 0000
5. Enter and registration starts. When the handset beeps and returns to standby registration is complete.
Nov 08, 2006 | British Telecom Freestyle 2200 Trio...
Cell Phones Logo
48 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
