Question about Maytag MSD2756G Side by Side Refrigerator
Icemaker the water is not getting to the icemaker. the water is just sitting in line half way. What can be done to get the icemaker to make ice.
    President:
  • 1,218 Answers
Good day,
THe best procedure is to go step by step. Should get you there.
First step is to take a small paper cup of water and fill the cavity until it is near full. With the ice maker turned on, close freezer door and wait 3 hours to see if it harvests. If not, the ice maker is bad, and must be replaced. If the cubes harvest then.......
Three possibilities.
1. The water supply from the house is not delivering water to the water valve. Shut off the house at the meter, disconnect the line going to the water valve, and with the line pointed into a bucket, have someone turn the valve back on for a 15 second count. The water should come out smartly. If not, the line and it's fittings will have to be replaced.
2. The fill tube from the back of the machine that feeds water into the back of the ice maker is frozen up. You will have to remove the ice maker to visually inspect that tube. If blocked, it needs to be defrosted, but use caution. Too much heat too fast will start to melt plastic and vinyl parts you don't want melted.
If this is the case, then once cleaned out, you will have to change the water valve located in the back bottom rear of the machine because it is leaking during the off cycle.
3. If everything checks O.K. up to this point, you will have to purchase and install a new water valve, and install it.
P.S. Under very rare occasions the electric circuity in the ice maker will fail to send a signal to the water valve. Although rare, it can happen, in which case the best option is to replace the ice maker and water valve.
Posted on May 07, 2010
Whirlpool side by side with water and icemaker. My water works perfectly fine but my ice maker no longer produces ice. It runs but it's not getting any water to make ice. What can be done to fix this?
There are a couple reasons your icemaker will not fill with water.
First thing you want to check for is a frozen fill tube to the icemaker. The easiest way to check for a frozen line is to remove the icemaker. Once the icemaker is removed look for ice in the fill tube. If there is ice in the tube the (water valve) will need to be replaced. You can melt the ice by forcing hot water up the fill tube.
Another reason could be the icemaker is not sending voltage to the water valve. The fix for this issue is to replace the icemaker. Hope this helps you with your whirlpool fridge!
The reason to change the water valve with a frozen water line is because the solenoid is not closing all the way. This allows water to enter the fill tube of the icemaker and freeze based on the temperature.
May 04, 2017 | Whirlpool Refrigerators
No water being dispense into ice maker. It's doing it usual dumping & everything . The cold water dispenser in the door is working.
Probably a bad inlet valve on the lower back where the house water line hooks to the refrigerator. Its a 2 part inlet valve. Half feeds water to the dispenser and half feeds water to the icemaker. You can't change half--need a complete valve assembly. Not hard to change. Disconnect house line---unplug 2 wiring plugs (4 wires total) and disconnect 2 plastic water lines. Reverse to install---don't get wiring mixed up or reversed.
Jun 16, 2015 | Refrigerators
WHy won't my U Line CO2075DWR won't harvest ice? It makes solid ice.
the sensor that sits on the evaporator may be faulty
Aug 01, 2014 | U-Line Icemaker
No water in ice maker we bought this appliance second hand and installed it this afternoon. There is water in the door dispencer, but not in the ice maker Thank you Johan Kruger
If you just installed this unit it may take time for the icemaker to start to receive water. The water through the door you had to sit and keep button depressed to clear the air from in the line. The icemaker only calls for water for 7.2 seconds. It usually takes a few cycles before ice maker gets water. Give it 24hrs and see if it helps. Make sure the arm on the icemaker is set to on. Usually pushed down.If you have any questions Please comment me back
Jul 28, 2011 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
I have a GE Profile fridge PSS25MGNAWW with an ice maker that is not working properly. The ice maker doesnt fill with water. If I turn the ice maker off then back on it will squirt water in for about...
HI this is just a test the icemaker runs when you first turn it on, its not suppose to fill up the tray, it will fill it when the icemaker reaches the correct temperature, if its not cold enough in the freezer it wont kick on, if its been sitting for several hours and still wont fill or make ice, you need a new icemaker. The new icemaker part # is WR30X10093
Sean
Mar 30, 2011 | GE Freezers
Electrolux side by side with the freezer on bottom. The ice maker isn't working but I have water flow on the dispenser.
If you are getting water to the icemaker then it is not the valve problem. You may want to let the icemaker total defrost for a 12 hours, then turn back on. If it is still not produce cubes, you can remove the white cover to see if the gear's are moving though stages, If they are not then the icemaker is shot. Also you may want to check the water line in the back of the unit. Sometimes there will be a build up of ice in the line that will not allow ice to total get to the icemaker.
If it ends up that you do need one here is a link to get one at half the price of retail:
http://cgi.ebay.com/New-Icemaker-Frigidaire-5303918344-fits-241680501-/300463745119?pt=LH_DefaultDomain_0&hash=item45f508e85f
Sep 16, 2010 | Electrolux EI26SS55GS Stainless Steel ...
Kenmore Coldspot #106.9750610. Icemaker does not
restricted water flow or pressure from house water where your taped into. your shut off or Tap a line may be cloged or if you have a water filter its cloged. It could also be a bad water valve in rear of refrig. start at the sourse of water and work back to frig. A rare thing could be that the timing gear on the ice maker is burnt and not trigering valve long enough to fill icemaker
Oct 30, 2009 | Refrigerators
BCM-95 Icemaker Was working fine until we moved Water does not go in..we have changed the water value and it still does not work.
fi you are using a percing valve you need to change it to a regular 1/2 by 1/4 compression vlve,, go to a half inch cold water line cut a tee in the line install a 1/2 out let pipe fot the ice maker, then install your valve run a 1/4in line to the ice maker, you shoud have no rblems,, it has to have volume with water supply in order to work, a percing valve is just that, it has a needle on the end you clamp it to the pi[e scre in the "t" handle till it perces the pipe, then back it off to open the water suply alot of times this is not enough to supply the water for the ice maker,,
Jun 30, 2009 | U-Line Icemaker
Whirlpool refrigerator stopped making ice.
If there are ice cubes in the icemaker sitting there waiting to be dumped then the problem is in the icemaker. If the icemaker is dry then you have a water supply problem, even if you have a water in the door working.
1.Check the fill line inside the freezer at the icemaker, if it is clogged with ice then remove this ice and replace the water valve.
2. Check the water supply. Turn the water supply off, disconnect the water line from the Ref, turn the water back on an fill a small glass. If the water supply is good the solenoid on the water valve should be checked. This is done with an OHM meter.
If you got this far and need more info to DIY - ronbuice.com
Dec 13, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Icemaker
You might have a frozen line. Also and this seems more important to you its prob to cold, Trust me to cold of a refrig will cause hollow ice cubes first leading to a frozen line. Clean your coils, if you have another refrig empty out into that, unplug it leave doors open a couple days. If you can get to water line use a hair dryer from a distance defrost line, turn down freezer half knotch 1 full one at maximum. should fix issues, especially if filter already changed. If this all check prob a clogged line, not just frozen.
Mar 15, 2008 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Maytag MSD2756G Side by Side Refrigerator Logo
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
