Drum is not spin but just in normal wash speed
  • 1 more comment
  • zou_tong May 07, 2010
    itès kenmore,model C45192
  • yadayada
    yadayada May 11, 2010
    thanks for that, now just wait, this is the free forum and it takes time..
  • yadayada
    need the make and the model number
  • 141 Answers
The spinning coil may be short circuited or cut off check the spinning coil if it is OK means check the power supply and main board as well the wires connections
Posted on May 08, 2010
On spin cycle sounds like change or rocks spinning around in drum.
Could be a bad bearing or something loose on the drum that doesn't rattle until you get up to spin speed. Look for something like pins, nails or screws stuck in the holes of the drum, or possibly under the protuberances (fins) inside the drum. Does the sound occur all through the spin cycle or only at top speed?
Jul 08, 2015 | Washing Machines
The drum only turns at normal wash speed when it should be spinning.
not familair with this mech check motor capasator or modual
Apr 18, 2015 | Speed Washing Machines
The drum on my dryer seems to be stuck and is not spinning, the belt is on and seems to have the proper tension. Can someone help me get this dryer running again?
inspect the tumble dryer drum shaft - see image
inspect the dryer belt tensioner - see image listen for sound when electric motor is running
25302111-r0o5diaoq3uxmfwmdgmcujgm-1-0.jpeg 25302111-r0o5diaoq3uxmfwmdgmcujgm-1-2.jpg
Dec 01, 2014 | Frigidaire FGX831FS Washer/Dryer Laundry...
Final high speed spin very noisey
Something is causing the drum to be way out of balance. Does it bang and make noise when it's spinning empty? Probably not. Is something stuck on the side (inside of course) of the drum, causing it to shake when spinning? If not, a spring or shock absorber (connecting drum to sides, bottom or top of machine) has broken or come loose.
Nov 23, 2013 | Malber WD1000 Front Load Washer/Dryer
Frigidaire FTF2140ES washer does not spin at any speed setting. Tumbles normally during wash and rinse. Pump operates and drains normally during the spin cycle, but drum remains still (no attempt to spin).
Usually on these models it is your door switch that is defective. There are two sets of contacts one too lock the door and the other gives contact for the spin cycle.
Jun 11, 2011 | Washing Machines
Very loud noise during spin cycle - drum still spinning at normal speed. sounds almost like a broken belt - are there more than one belt?
only one belt on machines, ur looking at one of the following
  • loose counter weight
  • something stuck in drum, eg bra wire, sock
  • bearings failing
  • broken shaft
  • machine not level maybe?
Sep 23, 2010 | Frigidaire GLTF1670A Front Load Washer
Haier HWc1460tve wont enter spin mode, water pump etc ok, drum turns but wont go faster than distribute speed for whole of spin programme
check the sensor that normally is attached to the motor. If it has come loose, speed becomes erattic .If good, suggest brush check as well.
Sep 08, 2010 | Haier Washing Machines
Washing machine
Here is what I suggested to another person with a similar request......
Not knowing what model machine you have, I would hazard a guess and say it is your break solenoid or break arm or a variation on a break system.
After the spin cycle, the break solenoid or break motor engages a break arm to stop and lock your spinning drum. The loud clunk is normal especially in Simpson and Hoover top load machines.
You can check this by putting the machine on a spin cycle. Once the machine gets up to speed, open the door. You will hear the clunck and then the drum stops abrublty. When you close the lid again, you will hear the solenoid release the drum, and then the motor starts spinning the drum again.
If that is the case, it is normal and no need to worry about it. However, if you did not have the noise before, then best to get a repairer to check it out.
Regards
Ash
Nov 08, 2009 | Washing Machines
LG Tromm WM2277HW during high speed spin makes noise
I had exactly the same symptom...grinding noise only during high speed spin cycle.
I took the top and back panels off to see how the drain hoses etc. connected. Not wanting to take it apart further, I eventually just took the washing machine outside (I knew I was going to be dealing with water!), pulled the debris catcher front side bottom, and let rip with a garden hose inside the drum with the catcher out (leaving an open drain that could flow unimpeded).
Water flowed quickly out of the open drain, and lo and behold, a small drill bit came out with the water flow. This bit, presumably had gotten through the drum grating, and was resting on the bottom of the housing, scraping and grinding when the drum was spinning.
Aug 16, 2009 | LG Washing Machines
Both drum and agitator spin during wash cycle. Is this normal?
What is the age and model number of the washer? It could be as simple as a problem with a part inside the agitator or it could be a bad transmission. A complete model and serial number from the washer not the book.
Jan 10, 2009 | Washing Machines
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
