Question about GE CleanSteel GSL25JFTBS
Our GSL25JFTFBS side by side is freezing food on the fresh food side. it is set to the lowest setting and still freezing the food (especially on the top shelf)
    Novelist:
    Champion:
  • 246 Answers
You need to turn the thermostat up to a 'higher' setting.
good luck!
Posted on May 07, 2010
Whirlpool ed25rf refrigerator side freezing on bottom
your evaporator motor may be going bad also check to see if your condensing unit and fan motor are clean this can cause similar problems.
Dec 11, 2013 | Whirlpool 25.2 cu. ft. Side-by-Side...
PSC23NSTESS FREEZING VEGTABLES
Side by Side ModelsIf foods, such as fruits and vegetables, in the refrigerator are freezing, it can be caused by several things. First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenheit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • If food in the bottom of the refrigerator is freezing, this could be caused by a refrigerator not having enough food to absorb the cold air.
  • If food in the door is freezing, move the door bins up or down so they are one notch away from freezer vents (Side by Side models only).
  • The fresh food control should be at the normal setting of 5.
Freezer on Top Models
First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenehit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • Since the cold air coming into the fresh food section originates in the freezer above, the rear of the top shelf will be the coldest spot in the fresh food area. Avoid placing delicate items that freeze easily on the back half of this shelf.
  • If food is freezing in the produce (fruits and vegetables) or meat pan, it may be that the temperature controls are not set high enough. Since cold air naturally falls, the pans can get too cold if the refrigerator is not running long enough to maintain good air circulation. Adjust both controls up one notch.
Nov 01, 2012 | GE CustomStyle PSC23NSTSS Stainless Steel...
When The Temperature Setting Is On 1 The Food In The Freezer Dosent Stay Completely Frozen But When i move it up to setting 2 it freezes things in the fridge...and theres water leaking out the back
Do you just adjust the fresh food side or do you adjust the freezer setting too? Post the model # . does the unit have knobs or buttons for setting temp? Does food freeze in one particular part of the fresh food side or evenly throughout?
Apr 15, 2011 | Refrigerators
Refrigerator freezes food regardless of dial setting. Control board?
Thank you. The part number you need is 240383703 at $146.18 thru Sears and is the control for the refrigerator not the freezer. The refrigerator control operates the opening and closing of the damper door which lets air pass from the freezer to the fresh food. The control is keeping the door open longer than it should. Hope this helps. Worth the repair and has been one of the most common problems with this model.
Feb 04, 2010 | Kenmore 52642 / 52644 / 52649 Side by Side...
Ge fridge GSS25LFGww, fridge part freezing food
Hi, Change the controls back to normal settings. Make sure the freezer is getting 0 to 5 above. If the freezer is getting cold enough, try and turn the cold control to 1 and see if the refrigerator shuts off. It sounds like the cold control in not working properly and will need to be replaced. NOTE: The freezer temp has to be right temp or the fresh food side will not work proper.
I hope this helps. Please let me know if I can assist you further.
Vic
May 30, 2009 | GE GSS25JFM Side by Side Refrigerator
Fridge keeps on freezing everything inside of it
This refrigerator only has one thermostat located in the fresh food compartment it is designed to activate the sealed system (cooling) until it reaches approximately 37 deg f in the fresh food compartment. The damper controls how fast the cold air can move from the freezer compartment to the fresh food compartment. Allowing you to control the temp in the freezer by controlling the flow of cold air to the thermostat.
You have one of two problems.
#1 your thermostat is no longer opening when it achieves set temp. fix = replace thermostat pn 61005798 $35
#2 your damper arm or assemblie has broken. Fix = Replace damper or broken arm and actuator.
damper assembly pn12001377 $44
damper actuator pn 61002000 $2
damper arm pn 61001999 $2
thermostat actuator arm damper arm
damper assembly both pics
Apr 06, 2009 | Refrigerators
Freezing in frig.
Check the air dampers at the bottom of the fresh food section.They may have been moved to a open position. If so close them up some.
Otherwise the cold control thermostat may need to be replaced.
Mar 21, 2009 | GE GSS25SGMBS Side by Side Refrigerator
Gss25tgmaww set on lowest level 1 1 fresh food freezing, too cold. thanks Frank
You may have an obstruction blocking the vent from the freezer to the refrigerator which should open and close to allow more or less cold air in. This may be stuck wide open.
Jan 07, 2009 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Fresh food side freezing
the air damper is stuck open or tempature control is bad. look thru the vents(use a mirror) on the left rear(top side) of the fresh food compartment (right hand door) to see if the air damper is open/closed. i am sure it will be open since your freezing food in the ref section. if it is open ,watching with your mirror turn ref (fresh food) control off. the air dmper should close, if not damper could be stuck(ice build up,piece of foam,ect) if you can determine damper door is free, then best thing to do is replace controlassy.(120.00 or so) good luck
Nov 06, 2008 | Frigidaire FRS3R5EMB Side by Side...
Refrigerator kenmore
fresh food thermister should be checked. also the damper assembly that regulates cold air from freezer to fresh food side.
Aug 27, 2008 | Kenmore 53642 / 53644 Side by Side...
GE CleanSteel GSL25JFTBS Logo
178 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
