Question about Samsung HP-R4252 42 in. Plasma HDTV
Any image (even the unit's menu) is superimposed by couple wide horizontal half-opaque stripes of color sparks
  • 178 Answers
If i am correct in my assumption of what you are trying to say, you are seeing a random pixel discharge. may look kind of like snow. Early on Samsung had us to adjust the different voltages used to drive the panel, but in my experience this rarely worked and the set came back for repair. Later on Samsung began to authorize panel replacements for this problem. If it is in warranty get it to a shop fast, also check you r warranty, some of the plasmas had a longer warranty on the panel part.
Posted on May 07, 2010
  • zapdbf May 07, 2010
    I re-read what you wrote, i may have given you the wrong answer, your set may have a problem with the panel driver ics this is a more common failure and not as expensive to fix. Sorry. either the upper or lower sub y boards.
    e-mail me a picture that would help ldb@zapdbf.com
Tip
How to set convergence on Projection TV ' s
I have given an general explanation on most projection TV ' s
  1. Enter the menu on your TV. Use the remote control and bring up the menu.
  2. Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  3. Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  4. Press "Enter." A crosshair pattern will appear on your screen.
  5. Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  6. Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  7. Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  8. Repeat these steps for all colors.
on Mar 18, 2010 | Televison & Video
It has tripple vision and looks like a bow tie.
hi, sounds like a convergence issue. try this...
  • Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  • Enter the menu on your TV. Use the remote control and bring up the menu.
  • Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  • Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  • Press "Enter." A crosshair pattern will appear on your screen.
  • Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  • Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  • Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  • Repeat these steps for all colors.
  • good luck!
    Feb 02, 2011 | RCA HD61W66 61" Projection HDTV
    How do you set convergence
    What is your Make and Model number?
    Prints B&W in Horizontal Stripes
    I received an answer elsewhere. Thank you.
    Jan 26, 2010 | Canon Office Equipment & Supplies
    Stripes printed on every picture
    go through your printers software in your start menu and clean the heads.
    Aug 21, 2009 | Canon PIXMA MX850 multifunction InkJet...
    Striped color distortions on Nokia 300 Xa flat panel
    This is power supply problem.
    1. First u replaced the power out put capacitors , 6V, 12V, etc.
    2. cheak the diodes.
    Oct 17, 2008 | Computers & Internet
    Horizontal Striping Problem on a Dell 5100cn
    As you have just replaced the drum you may have a faulty drum unit put old one back in a test if lines go way then return drum to store and get a replacement. If they do not go the check the toners and the fuser unit.
    Thanks J
    Jan 21, 2008 | Dell 5100cn Laser Printer
    Dell 3100cn printing horizontal stripes
    Sounds like a bad imaging drum to me...
    Aug 14, 2007 | Dell 3100cn Laser Printer
    Samsung HP-R4252 42 in. Plasma HDTV Logo
    154 people viewed this question
    Henry  Thomas
    Henry Thomas
    Jerry Greenberg
    Jerry Greenberg
