Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Magnet seal hot to touch - Whirlpool GS6NBEXR Side by Side Refrigerator
    President:
  • 949 Answers
This is a sign the condenser is overheating and can lead to a loss of cooling. I put together some instructions on what to do. Take a look at the link below and let me know if it works for you.
http://www.fixya.com/support/r4694132-hot_door_seal_rail_divider_strip_between
Posted on May 07, 2010
Stoves 720ef bottom door not touching seal at top
Try adjusting the hinges also check magnetic seals on door itself as well.
Feb 22, 2013 | Stoves 720EF Electric Double Oven
Kennmore side by side refrigerator 5525 55271 the magnetic door seal seems to be hot.
Here is a tip that I wrote about the reasons why the sides and/or seals couldbe getting hot on your refrigerator.
RefrigeratorTrouble The Outside of Refrigerator Hot
heatman101
Sep 01, 2011 | Kenmore Refrigerators
The fridge seal magnetic around the doors on both the fridge and freezer are extremly hot to the touch.
Hi and welcome to FixYa, I am Kelly
Your condenser coils are HOT so the front of your unit it HOT. Either the condenser coils are blocked with lint or the condenser fan has stopped running You can place a floor fan pointed at the bottom rear of the unit to cool things off and get by until you get any needed parts or complete the repairs but.. you need to find out what is going on in the condenser coil area. Lint or fan issues. One of the 2. Get rid of the lint, clean and lubricate the fan motor with turbine oil or replace the fan notor. Those are the remdies.
Thanks for choosing FixYa,
Kelly
Aug 09, 2011 | Refrigerators
The center wall that runs vertically between the freezer and refrigerator compartment is very hot on the end that is exposed when you open the refrigerator door (hot enough that the magnetic strip that...
Well, that is were a heating wire runs to evaporate condensation at the seal. So it is normal that it gets slightly hot, but if really hot, then call for service
Jun 18, 2017 | KitchenAid Superba® Architect® KSRP22FSMS...
What causes the metal strip that the door magnets use to get hot.
Here is a tip that I wrote about the reasons why the sides and/or seals could be getting hot on your refrigerator.
Refrigerator Trouble The Outside of Refrigerator Hot
heatman101
Jan 28, 2011 | Amana Refrigerators
The refridgerator door is not sealing properly and the magnetic seal between the refrig door and the freexer door is hot.
Heat the seals with a hair dryer and then pull it tight - strap it tightly shut - you can also use some super glue to keep it in place while it dries.
Gary @ Fix Ya
Sep 09, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Replace seal
Take the door off. You will find a 1/4" screw every 3" to 5" all the way around the door. Remove every one of them. It amy take a couple trips around to get all of them. Before you attempt to install the gasket, soak it in hot water for about an hour (while you are removing the old gasket). This will soften the rubber so that you can work with it. After you have replaced the gasket and re-installed the door. Take a rag soaked in hot water and wipe it slowly around the gasket. This will warm it again. Now take Vaseline and smear a small amount all around the gasket. Close the door and let sit for 15 to 20 mins. Now take a dollar bill, open the door and close it on the bill so that a end of the bill is sticking out. Now pull the bill out slowly. The gasket should have a snug grip on the dollar. If not re-heat it then close the door so that the magnet will pull and stretch the gasket until it touches the box. Do this all around the door to insure that the rubber of the gasket has expanded and allowed the magnet to reach the fridge case. If you take your time, you should have no problem. Good luck
Please rate solution
Sep 07, 2009 | Candy CPCA270FFK Bottom Freezer...
My Subzero bar frig feels quite hot around the edge that touches the rubber and it is making the rubber warm as well. Everything inside is cold, and it is making ice as usual. I think I sense a smell of...
as with alot of refrig units the rubger strip has a warming coil that keeps the door from sticking they keep an even warm temp so as opening and closing the door easy there could be a burn spot in the strip and causing the strip tp be warmewr than it should be almost hot should call a fridge expert after you convince your other half there is a prob normally most fridges have a plan magnetic strip to seal the door
Aug 22, 2009 | Refrigerators
Fridge Condensation
Check the seal of the rubber gasket, if there are improper seal of the magnet, pour hot water along it to soften the rubber. (be careful when handling hot water). When the rubber is soften, try to stretch it a little by pulling it. close the door and the magnet will keep the seal in place.
May 09, 2009 | LG LRFC25750 Refrigerator French Door
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
70 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
