Question about Refrigerators
LG Fridge making intermittent sound - like something hitting fan
LG Fridge just 1 1/2 years old. Just recently there is a noise coming from the back of the fridge that sounds like something is hitting a fan. Similar to the sound that a hockey cards makes when kids put it on their bike so that the spokes hit it. The noise stops as soon as you open one of the doors (split doors). The noise seems to be intermitent - not happening all the time. The fridge is 22cu bottom mount freezer.
    Novelist:
  • 184 Answers
GAIN ACCESS TO THE FAN IN THE FREEZER(EASIER SAID THAN DONE) AND INSPECT THE FAN BLADE AND FAN SHROUD. HAVE REFRIGERATOR TURNED OFF AND MANUALLY ADVANCE FAN BLADE. WATCH FOR SLIGHT CONTACT BETWEEN THE FAN BLADE AND OTHER OBJECTS NEAR IT-ELECTRICAL WIRING, FAN SHROUD, ICE CYCLE,ETC. ADJUST FAN BLADE OR OBJECT TO INCREASE CLEARANCE.
Posted on Mar 27, 2008
Magic chef 10 cu fridge makes ticking noise but works fine
Some times refrigerators make a noise that sounds like a tick. It could be caused from the refrigerant flowing through the lines. This usually happens when the refrigerator first starts up and goes away after a few minutes. the other possibility is a fan motor blade taping the shroud from time to time. The refrigerant issue is not something that can be fixed. The fan blade issue could be fixed by moving the fan blade back or froward on the shaft a slight amount. If you have a 10 cu ft refrigerator it may not have a fan.
Apr 05, 2014 | Magic Chef Refrigerators
Fan make noise
There are 2 things in that area that can make a noise, the ice maker,and an evaporator fan,depending on the model.The fan is an easy fix if the blade is just hitting something ,but you have to be abit mechanically inclined to get to it.The icemaker has a little motor that sometimes gets stuck in the ice harvest mode,then you just have to unstick it ,also depending on what kind of fridge you have..everything else is down at the bottom,compressor,condenser,ect. In any case you probably want to call a tech unless its old,because repairs would be more than it is worth.
1. Open the freezer to see if the noise gets louder. If the noise becomes louder with the freezer open, the noise is likely caused by the evaporator fan. If the evaporator fan is the culprit, replace it to get rid of the noise.
2. Take raer panel off inside freezer and check there is no ice build up which is hitting the fan
3. Pull the refrigerator away from the wall, and check the condenser fan at the back of the fridge. A metal panel may cover the fan, which can be unscrewed. Listen to see if the fan is the source of the noise. If it is, the fan may need to be cleaned or replaced.
4. Unplug the refrigerator, and listen to the back side of the fridge. The fans will immediately stop running. If the back of the fridge continues to make a noise after the fans have shut off, the sound is most likely coming from the compressor, which is located at the back of the fridge, near the bottom. If you have a compressor problem, you either have to replace the compressor or the entire refrigerator.
Oct 04, 2012 | Refrigerators
Buzzing sound in fridge
I had something similar in my White-Westinghouse fridge a few years ago. The bearings in the fan motor that circulates cold air went out. Unplug the fridge and remove the grille assembly at the back of the freezer. The fan will be behind it. Try spinning the blades with your finger. If they turn hard or if you feel excessive resistance, the motor is bad. Also, check to make sure insulation hasn't gotten into or is rubbing the blades. It's an easy fix if it's not under warranty. Usually two screws/bolts hold the motor in place, and a two-wire electrical connector. Don't forget to turn the fridge back on after checking it.
Oct 02, 2012 | Frigidaire Refrigerators
How do I stop the loud knocking noises coming from my refridgerator?
Pull the fridge away from the wall and inspect the compressor. Your description sounds like the compressor is hitting something. It is rubber mounted and usually can be pushed away from whatever it is hitting.You do not want to jamb something to stop the noise, as the compressor needs to move freely. Many compressors shake during start up and shutdown, and this is considered normal. Abnormal if the compressor hits something during this movement.
Feb 05, 2012 | Kenmore Refrigerators
The refrigerator make noise. It seem to be from the motor. It is only 1 year old.
I think that sound come of the fan in the freezer. This sound is intermittant. It's possible that problem is cause by a defect bearing?
May 19, 2010 | LG LRDC22744 Bottom Freezer Refrigerator
My 10 year old amana fridge makes a noise from the fan in the freezer it sounds like something is hitting it ,but on inspection I see nothing hitting it
Look closer because ice can build up and the fan just barely hits it making the noise. If the fan blades are not hitting anything, replace the fan motor as the bearings are getting worn out.
Dec 30, 2009 | Amana ABB1927DE Bottom Freezer...
Hi I have a GE Fridge Model Number GTS18HBSW and it just started to make this loud noise. seems like it is coming from the fan or back of fridge only 3 years old. Any suggestions
Any noise in the fan needs to be corrected soon. It could be something trapped there or it could be something is wrong with the fan or the fan blades. To lose the operation of that fan will stop cooling and chance damage to the compressor from over heating. I recommend that you unplug and pull away from wall. Remove cover that covers compressor and fan and find what is causing this to prevent further damage. Let me know what you find and if you need additional help please let me know, Thanks, Sea Breeze
Aug 26, 2009 | GE GTS18HBSWW 28" 18.2 Cu. Ft. Top-Freezer...
Growling noise coming from back of fridge
Try lubricating all fan bearings that you can get to. Make sure fan blades not hitting any thing.
Aug 27, 2017 | LG LRBN22514ST Bottom Freezer Refrigerator
Refrigerators Logo
1,012 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
