Question about Maytag Atlantis MAV6451 Top Load Washer
I'm working on a Maytag Atlantis Model #MAV6451AWW. It went into a spin and started smoking. I've took off the belt but it looks ok except maybe for a ltille slippage mark. What else could it be?
  • 269 Answers
It seems as though the drum is stuck or at least starting to get tight,can you turn the drum and motor freely by hand.
Posted on May 07, 2010
Maytag mav6451aww squeals loudly during spin cycle
The squeal you here is from the drain pump going out. I have replaced so many of these it's not funny. The new pumps are redesigned. All you need to do is remove the belt from the bottom, open the access panel on the rear left side (as you look at from the rear), remove the three bolts and pull the pump out. put the new one on in the reverse order. Here is the new pump.
Oct 22, 2012 | Maytag Atlantis MAV6000 Top Load Washer
Maytag washer model MAV6451AWW - water does not shut off when filling. This started happening after I replaced the main control knob (knob works ok now) could I have loosened another connection which...
This problem is caused by a faulty water level switch.
It is a diaphragm like device with a small clear plastic tube attached between the switch and the bottom of the washer's outer tub.
As the water level increases, pressure increases on the air in the tube. When the pressure reaches a certain level, it activates the switch to turn off the water and signals the timer to start the agitate cycle.
Look for any obstruction or defect in the tube. The switch can be checked for continuity with a multimeter. If it has no continuity the switch is defective..
Please leave me comment, if you need further assistance
Rnj VINODKUMAR
Oct 16, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Burning smell and smoke
Sounds like the belt has burnt off. You can check this by tilting the machine back and looking under it. Sometimes the belt gets hard and just starts to slip, then it will smoke and burn off. If this is the case, Just replace the belt and this will fix it.
Feb 02, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Grinding Noise during spin and wash cycles but it' working ok
#1 issue have had with those as a repairman is the pump.the spot welds break and the pump rubs metal to metal also the belt can wear and flap.you can get somthing in the inner tub in those little holes[ie..nail]and when the tub moves it drags.to look at pump,belt motor pulley.tilt washer back .rest on wall and you can inspect all from there.God bless,tom
Jan 03, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Mav6260 washer will not spin
the belts on these units will streach, and alot of the early unit had bad belts.
the unit should spin with or with out water in the spin cycle
also the thrust bearing on these units go bad often.
this is a magic chef washer with the maytag name on it.
Apr 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag atlantis washer
I am also expiriencing the same situation.
I took a look at the machine and it appears to be in good working order.
But the belt does appear to be in need of replacing. I have ordered one and should find out everything will be back to normal once it is installed.
The worn belt would explain a lot.
- Light load are fine due to the lack of power needed to spin the contents.
- Heavy loads need the maximum amount of power it can get to spin.
But does not because the belt is slipping further into pulley grooves and is probably partially slipping, due to the wear.
Dec 02, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Maytag washer will not spin
If your washer does everything but does not spin, it is your outlet filter which is blocked. Locate this and clean out, it has to work fine. Refer user's manual.
Jun 02, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Atlantis MAV6451 Top Load Washer Logo
102 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
