Question about Sony Cyber-Shot DSC-F717 Digital Camera
When I activate the power switch the camer will not turn on. Batteries and charge are good. I have tried new battery but the "on" green light will not activate. What could be the problem?
  • 10,594 Answers
Problem could be dirty contacts in battery compartment in camera or blown chip fuse in power supply board or defective system control chip on main board of camera, too many possibilities for no power problem.
You need to take camera in local camera repair shop as it will take apart and checked by qualified tech to fix its issue.
Hope this info will help you.
Let me know if you have additional question.
Thanks.
Posted on May 07, 2010
Why won't batteries charge?
Those chargers are designed to turn solid green when the batteries are fully charged. When batteries are less than new and have some time on them they will not charge as much as a new one. It is conceivable that either the battery condition is not the best there is or that perhaps there may be something wrong with the charger.
I suspect it is the new batteries not being so new.
Aug 29, 2015 | Shoprider Sprinter XL4
I have replaced joystick, batteries, motors and the chair still losing lights will go about 1/4 mile and loses all green lights with in 1/2 mile loses all the yellow lights, drove on 1 flashing light for...
Janice check your charger it could not be charging the batteries. Now always charge your batteries overnight while you sleep When you get up lights on the charger should be red and green if they are red and yellow then the charger hasn't fully charged the batteries and overnight should be more than enough time to charge fully. This could indicate a bad battery remember new doesn't always mean good. Like they say always charge before use and this goes for new batteries too you need to charge new batteries nightly for 10-15 days before they start operating at 100%. If when you plug in the charger before bed and the lights are red and green then there is a problem with the charger or the batteries or the charger circuit Hope this helps you
May 23, 2011 | Spirit Activecare /wildcat Foldable Power...
I mistakely deleted pictures from my camera (Kodax Esay Share M340) Move picture to internal memory.How can i get the pictures back
If Try one or more of the following
Ready light does not turn on and the camera does not work.
Ready light blinks green.
  • Camera is operating normally.
Ready light blinks amber.
  • Wait. Resume picture taking when the light stops blinking and turns green.
Ready light blinks red and camera turns off.
Ready light glows steady red.
Ready light is off or glows steady green.
Mar 10, 2011 | Kodak Cameras
Need charging instructions for Air Hogs Havoc heli. Is remote control switch to be turned on during charging? What position is channel switch in? Is Heli on/off switch set to charge? I have no...
1.Take out charging wires. 2.turn off your heli and insert charging socket into your heli's socket. 3.the charging green light will light up while charging. 4.charging complete, the green light will turn off. 5.pull out the wires and you are ready to fly. Let the heli's battery cool down for approx. 15 minutes before charging.
Feb 19, 2010 | Spinmaster Air Hogs Battling Havoc R/C...
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
Nov 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
Only 1 battery charges
The lights are working, the batteries aren't. Red indicates power to the charger, and it should be on all the time. Green indicates a full charge, usually. If one or both of the batteries are totally dead, then the charger can't "see" them, and you will get a green light, but you will have dead batteries.
All power chairs use sealed, deep-cycle batteries. Deep cycle batteries, are designed for slow amperage dischare over a long time period, unlike a car battery that throws out a lot of amperage for turning the motor over. That's called "cold-cranking amps", and you can load-test a car battery to see if it will throw out a ton of amps for long enough to start a car. There is NO load tester made, or possible for a deep-cycle battery. A load test requires a 24-hour time period, and a complicated formula.
So, your course is to get some fresh, gel-sealed-batteries. You will need type U-1. Specify, gel-sealed-batteries when you go to the battery shop. A fresh set should get the chair up to about 12-16 mile range, which would be about 3-4 hours running constantly at high speed. Good luck.
May 11, 2009 | Invacare Pronto M51 Power Wheelchair
Will not turn on the green light only turns on for
To reset the camera, remove the batteries and leave them out for approx. 1 hour then replace the batteries. See if the camers works again.
Mar 08, 2009 | Nikon Coolpix L11 Digital Camera
Camers will notturn on
What kind of batteries are you using?
Jun 07, 2008 | Fuji FinePix E510 Digital Camera
Camera wont turn on
goto http://www.digitalcamrepair.com/self_diagnosis_page.htm
for self diagnosis.please let me help you before leaving a bad feed back.
Apr 30, 2008 | Kodak EasyShare C533 Digital Camera
Sony Cyber-Shot DSC-F717 Digital Camera Logo
64 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
