Question about Hayward H250FDN Low NOx Natural Gas Pool or Spa Heater
Header cracked on hayward pool lo nox h250fdn heater. need to replace the header. Please help?!
  • 64 Answers
Headers on hayward heaters are usually warranted for 10 years, except for freeze or chemical damage. You may want to contact a local warranty station to see if you can get it replaced under warranty.
Posted on May 19, 2010
Hayward H250FDN blue temperature control will not respond (MODE and RED up button are OK)
up and down button at same time with either mode or enter at same time for seven seconds that should unlock
May 16, 2014 | Hayward H250FDN Low NOx Natural Gas Pool...
Hayward h250fdn control stucked with code sb
possible bad sensor temp sensor also check safety circuit and gas and ignitor
Oct 13, 2013 | Hayward H250FDN Low NOx Natural Gas Pool...
When heater is running smell way to much gas
have gas pressure checked if ok check pressure on back side of gas valve also check connections after gas valve
Aug 15, 2013 | Hayward H250FDN Low NOx Natural Gas Pool...
Bd error code on hayward h250
bad board wont power up also check transformer
Apr 08, 2013 | Hayward H250FDN Low NOx Natural Gas Pool...
I want to go over 104 degrees
cannot just can go to calibration and cheat 4 degrees
Jan 12, 2012 | Hayward H250FDN Low NOx Natural Gas Pool...
I AM REPLACING THE HEADER IN H250FDN HEATER. NEW HEADER INSTRUCTIONS MATCH OLD HEADER AND NUMBERS MATCH ON OLD AND NEW BUT NEW HEADER IS DIFFERENT. OLD HEADER HAS 2 LIMIT ON BOTTOM NEW ONE HAS 1 ON BOTTOM...
As long as it still has 2 hi limit switches, this will be easy.
You will need one wire going from one limit switch to the other. (on any terminal)
take either of the incoming wires from the old limit wiring and connect to second terminal on either limit switch.
Now take the last remaining wire and connect ot to the last terminal on the second limit switch.
Basically, you are just creating a bridge. Power will go into first limit switch, then go into the second limit switch via the first wire indicated above. Then the power will go back out to the pc board. If a high limit switch trips, then power is cut off (cicuit opens) and it tells the cpu there is a problem and shuts down the heater.
So to simplify: connect the wire in between the two limit switches. Then put the other 2 wires anywhere.
May 04, 2011 | Hayward 250fdn Low Nox Nat Gas Swimming...
Heater leaking at manifold
1. Check o-rings at connections and replace if required. 2. Check header for cracks. 3. Remove heat exchanger and check for leaks. Replace parts as required.
Apr 19, 2010 | Sta Rite Sr333na Max E Therm Pool & Spa...
Hayward H250FDN Low NOx Natural Gas Pool or Spa Heater Logo
194 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
