Question about Fisher and Paykel DD605HSS 23 in. Built-in Dishwasher
Lights come on with f1 spanner sign flashing and bleeping
  • 784 Answers
There is a leak causing the bottom housing wet so the floor sensor triggers. Dry out the bottom housing F1 will be disappear. However if the leak is not fix, the sam problem will happen again. The leak is from improperly being sealed between the top lid down against the top edge of the tube during operating.
Posted on May 08, 2010
F1 flashing with a spanner showing
Hi..
F1 code indicates a leak,you will find the water under bottom drawer.Might be the lid probably not sealing well. You have to seal it well properly to fix this error in your dishwasher.
Thank u !!
Jun 17, 2010 | Fisher and Paykel 24 in. DD-602 Built-in...
The unit flashes F1 with a spanner sign showing on both drawers
Refer your problem with fisher and paykel DD603 dishwasher. Please clarify how are you able to assess the motor is driving in top gear. Which lights are flashing?
Is this problem in both drawers or just one?
May 30, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwasher is beeping. Also has an F1 with a
paano maviverify ung friendster ko e ayaw mabuksan
Jan 27, 2010 | Fisher and Paykel Dishwashers
HI my fiser and paykel dishwasher is flashing f1 and is showing a spanner whay does this mean
The F1 error means a flood switch has been activated in the drawer. The spanner means you need to call a technician.
The possible causes are that the solenoid that controls the water inlet does not shut off or the sensor that detects the water level is not working. Also it is possible the water pressure is not optimum for the setting on your unit.
Nov 05, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Anti Braking Light Bleeping -VW POLO 2001
abs control module could be bad or wheel speed sensors but if the light goes out on its own id say the module
Jul 27, 2009 | 2002 Volkswagen Golf
Hi,my vw bora tdi has awarning light on the dash board,it bleeps for about 5 seconds then a message on the dashboard reads ENGINE WORKSHOP!and glow plug light keeps flashing,brake lights are working ok.
when the glow plug light keeps flashing.Thats telling you that you have a fault with one of the sensors.Take it to a garage and get it checked out with a diagnostic scan.
Jul 17, 2009 | 2003 Volkswagen Golf
Starts bleeping 10mins into cycle
http://www.manualnguide.com/dl/12334/ Check on the troubleshooting page as to what certain flashing sequences mean and that may help
Jan 08, 2009 | Baumatic 23 in. BDW5 Built-in Dishwasher
Fisher and paykel dishwasher
F1 is a flood code meaning excessive amounts of water have collected on the bottom catch basin.
If a flood condition is detected, both draws will activate the drain motors and flash F1.
Remove the bottom drawer by pulling the lock pins on each lower side corner. Slide down and remove front cover. Release the drawer slide clips and remove drawer then dry the catch basin.
There are three possible scenarios for this error code;
1. Defective lid motor(s)...Each drawer has two lid motors, attached to the cabinet on either side of the drawer, that pull the lid tight to the drawer when the cycle is started. (this was very common on early models)
2. Something too tall was placed in the drawer preventing the lid from closing completely.
3. (only seen this once) the drain hose developed a crack causing water to leak only when draining.
Jul 03, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Machine emits continuous high pitched bleep and power light flashes blue/red
If working OK, probably means that the temperature alarm goes off because is getting hot the PC. I suggest to check why is that happening. All fans working OK? is the CMOS temperature alarm set too low? check your motherboard instructions booklet- It will tell you what the beeps mean probably in the last pages. Good luck
Sep 28, 2007 | Sony VAIO PCV-RX511 PC Desktop
Fisher and Paykel DD605HSS 23 in. Built-in Dishwasher Logo
149 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
