Question about Dell Inspiron 1545 Notebook
Touch pad not working on dell 1545 - Dell Inspiron 1545 Notebook
  • 345 Answers
When touch pad does not work it is because of service not running or corrupt drivers. Service is most likely dell event service. If you go to dells site and search for touch pad not working it will give you detailed instructions on how to fix. i had same issue with my sony laptop where it just stopped working and also my FN button was not working. Hope this helps.
Posted on May 08, 2010
My touch pad will not work on my dell inspiron 1545 and when I go to the touch pad settings the enable/disable option the enable box is checked! The only way I can get the pointer to work is to plug in an...
just check if it is having the issue while adapter connected to it or without adapter as well. we need to check if it is earthing issue or the issue is with touchpad itself.
Oct 11, 2013 | Dell Inspiron 1545 Notebook
My touchpad will not turn on. I have tried power reset with power plus center and tried reloading website too avail - nothing works I even tried a new battery - nothing... Any suggestions???
The touch pad of laptops can be disabled by a sequence Fn+Fx key. On my Toshiba it is Fn+F9. It can also be disabled/re-enabled from the touch pad configuration panel.
Oct 07, 2013 | Dell Inspiron 1545 Notebook
My touch pad not working probably .
Adel Heider,
You may want to first download the driver and install it into the system from the link below.
Inspiron 1545 Drivers Download Page
http://dell.to/14IpAJU
Erratic Pointer Movement
Here are some easy steps to take to determine the problem with a touch pad demonstrating erratic pointer movement:
  1. Get the latest driver from support.dell.com - Most problems can be corrected with a simple driver download. This should always be one of the first steps when diagnosing any touch pad problem.
  2. Check for hand and finger placement - The most common cause of random pointer movement is that the touch pad senses a finger or part of the hand near the surface of the device.
    • Have the customer attempt to use the touch pad normally but to pay attention to the location of his or her hands and fingers. Are any straying too close to the touch pad?
    • Adjust the Touch Sensitivity and TouchCheck settings in the Touch Pad Settings section of the Dell Touchpad Properties.
  3. Try an external mouse - Does this problem happen with an external mouse attached?
    • The Device Select section of the Dell Touchpad Properties has options to enable or disable the touch pad or external mouse. Try several combinations of these settings.
    • If the problems only occur when the touch pad is enabled and do not occur any time a mouse or other external device is used, then the issue is related to the touch pad.
  4. Check for mechanical problems - If the problem cannot be corrected by adjusting the settings mentioned above and only occurs with the touch pad enabled, then this could indicate a mechanical problem.
    • Press down on the palm rest on first the left side of the touch pad and then the right. See if the cursor starts moving on its own.
    • Run Dell 32-bit Diagnostics and try to recreate the problems there. If either of these situations occur, then replace the palm rest.
No Pointer Movement
No pointer movement from the touch pad (or track stick, if available) usually is the result of one of two things: The touch pad has been disabled in the driver interface, or the touch pad cable is damaged or disconnected. Follow the steps below to determine the problem.
  1. Connect an external mouse - In either situation, an external mouse should still function. If it does not, try booting into Safe Mode and testing both devices again.
  2. Enable the touch pad in the driver settings - Using the external mouse (or key strokes if no mouse is available), go into the Dell Touchpad Properties. Go to the Device Select section and enable the touch pad. If already enabled, get the latest driver from support.dell.com.
  3. Test the device in Dell 32-bit Diagnostics - To eliminate a potential software problem, run the Dell 32-bit Diagnostics and test the device here.
  4. Check for mechanical problems - As a last resort, press down on the palm rest where the touch pad connector is located on the system board. If the pointer reacts in some way, then the cable may just need to be reseated. Otherwise, replace the palm rest.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Sep 07, 2013 | Dell Inspiron 1545 Notebook
Dell XPS M1530 Vista originally installed - Fresh installed Win7 and now touch pad does not work - the right button works, and sometimes the left, but the touch pad does not. I've install the latest...
If you've reinstalled the drivers for the touchpad, the issue is likely the hardware- if in warranty, contact Dell tech support- if not, you may need to purchase the palmrest assembly and consult support.dell.com for the install instructions
Oct 24, 2010 | Dell Inspiron 1545 Notebook
Touch pad does not workonmy laptop dell inspiron 1545
Sounds a lot like you just have a broken touch pad. somebody has to openthe Laptop and replace the part. The part is available on ebay. Here's a guide on how to disassemble a Laptop. Maybe a tech savy friend can do it for you. If you want to pay to have somebody do it for you there are third party Laptop Repair Services.
May 04, 2010 | Dell Inspiron 1545 Notebook
The touchpad on my Inspiron 1545 isn't responding.
butlerp934
If you reinstalled the drivers then most like there is a problem with the touch pad its self. If you are still under warranty I would call Dell Tech Support to get the touch pad replaced on the system.
Issken
Jan 11, 2010 | Dell F3534 Touchpad
I spilled coffee on my Dell Inspiron 1545 laptop, so now the touch pad doesn't work. How can I take the touch pad out & clean it or replace it.
You might be able to find a cheap replacement palm rest (which includes the touch pad) on E-Bay or similar site. Just search your model number.
As far as replacing it yourself, I recommend having someone that works on computers regularly doing it, unless you are completely comfortable working inside the laptop. If you are (and you take all necessary precautions), here is the Service Manual from Dell which includes disassembly instructions for the palm rest.
http://support.dell.com/support/edocs/systems/ins1545/en/SM/index.htm
Oct 26, 2009 | Computers & Internet
Touchpad not working properly
The touchpad is on its way out sorry to say
Aug 27, 2009 | Dell F3534 Touchpad
Dell Inspiron 1545: I accidentally disabled the touchpad and can't get it to enable again.
ok so if your touch pad isn't working you need to get in to your control panel there look for device manger then look for the disable touch pad and enable it hope this helps
tip plug in a external mouse so you can get to the control panel
Jul 29, 2009 | Dell Computers & Internet
Dell Inspiron 1545 Notebook Logo
302 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
