Question about Sony FD Trinitron KV-32HV600 32" TV
When I turn it on, the standby just flashes 6 times over and over. sometimes 7 times...no picture, no sound! Would it be cheaper to get a new tv than fix this one?
5 Suggested Answers
Vrya
  • 62 Answers
SOURCE: Sony KV 36 xbr800
Hiii...
I'm not sure about the chassis number of your tv set..
but I can give a solution for your proble....
It might be the problem at A,B,M board there's no +5V or over voltage +5V...check the IC504 at A board looks like a ic regulator 5V..check c530(470uF/25V),check c540(1000uF/16V)..
Posted on Feb 19, 2008
johnychel
  • 796 Answers
SOURCE: no picture
can you please mention your tv model
Posted on Jun 12, 2008
  • 4234 Answers
SOURCE: my KV-36HS500 won't turn on it sounds like it
The 7 blinks indicate that the horizontal deflection has stopped. This can be because the horizontal output transistor has shorted (common) or other defecive parts. If you are familiar with working inside of sets where potentially dangerous high voltages exist and can solder, let me know and additional details and instructions will be provided.
Dan
Posted on Mar 23, 2009
  • 4090 Answers
SOURCE: tv does not come on standby light flashes 6 times
like the 2000 others there is a fault on the power board and thepossibly even the sustain boards these that causes the relay to go into protection mode.in all cases all 3 boards need ro be changed in accordance with manufactureres recommendsations and then a whole retuning game is started that rewuires special tools and skills
This is not just a simple fuse or board change, it requires knowledge of circuitry to check voltages from a service manual and also resetting of the convergence chips by generating a hatch pattern on screen to realign all the guns. Parts about $300, labour depends on who does it. It is not a DIY as many on here who have tried have found out the hard way. Quick fix is a quick kill and you start all over again, shelling out for the same parts and making the same mistakes. Unlike PC's , these units do not suffer board change jockeys well.
Please rate my help++++Thanks for using FIXYA
Posted on Nov 19, 2009
Tv flashes red then shuts itself off after only on for 3 min
I have not repaired this particular model. But sometimes there is an IC they refer to as a standby IC. It may also be known as a controller IC. I call it the powerline regulator. And in one case the older Sony Projection TV had an audio output IC with a standby built into this IC. So,this advice is refering to a standby IC. And this IC may be in another form already mentioned. Please visit a Sony Tech. The work inside a projection TV is very complicated, you will need to see the specialist. Give them this note and go from here. Let me know how they handle the repair.Thanks for asking and good luck!
Aug 02, 2010 | Sony KP-65WS500 65" Rear Projection...
No picture
Jun 12, 2008 | Sony FD Trinitron KV-32HV600 32" TV
Sony Trinitron Wega Standby blinks & the TV won't turn on
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 12, 2017 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Samsung HLP4674W - changed bulb - still no picture - lights flash
If the lamp has been replaced I would think the Lamp ballast would be most likliest followed by the color wheel and then the Digital board. You can get any part needed for your model at www.tvrepairworld.com just leave them a email they respond quickly.
Aug 28, 2009 | Samsung HLP4674W 46" Rear Projection HDTV
KV-40XBR700, won't come on, standby light blinks 7 times.
sony KV40XBR700 tv no picture but sound is on, standby light blinks 6 times
Jul 20, 2009 | Sony KV-40XBR700 40" TV
Blinking/standby timer
Sony Trinitron TV. Worked well last evening. Now picture won't go on. When power is turned on, standby/timer red light flashes, but picture or sound does not work.
Jul 01, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
PFM-42b1e LEd flashing 6 times... 1 sec. picture with green stripes... and then it turned to standby
I have a sony tv PFM-42B1 when I turn it on it go to standby an a red light flash I count count 14 time but I heard that it only support to flash 1 to 6 time how do count the flash
May 06, 2008 | Sony PFM-42B1 42 in. HD-Ready Plasma...
Timer Standby light flashing No pitcher
Sony
Model # KP-53HS10
Serial # 9718217
MFG 2000
Plugged in TV. Timer Standby Light just flashes continusly. No Picture and No Sound.
Apr 02, 2008 | Sony KP-51WS500 51" Rear Projection...
Blinking Standby Light
KV32hs500 tv won't turn on. Standby light blinks 7 times, stops and then 7 more times, etc.. The tv will usually come on after about 2 hours or so of being off. Plays fine when on but once it gets turned off the problem happens again. Any suggestions? T.V. is 5 years old.
I have a similar problem . mine blinks 6 times or 7 sometimes also,and comes on with sound ,no picture for about 2 seconds then shuts off. Anything?
Jan 31, 2008 | Televison & Video
No picture on tv but have sound
how many times it flashes?? if its more than 6 times you have a problem. just lick the red wire that goes to the picture tube.if it does not kill you, you are lucky
Jan 07, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron KV-32HV600 32" TV Logo
26 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
